Question about RCA VCA115 VHS-C Adapter
The red flag is stuck out - RCA VCA115 VHS-C Adapter
I have Printer Laser jet HP P2055d error code is 59.f0 i need some one help thank you
Okay let's try this please.
Below is a recommended suggestion to resolve this problem:
  1. Upgrade the FW
  2. Remove the ITB
  3. Remove the fuser and on the left side (front of printer side) you can see the sensor flag holder (image #1 and #2 below)
  4. If the sensor flag/lever is stuck in the up position then reach in and carefully release the part with your fingers. The images below show the sensor flag/lever stuck in the up position. Actuate the flag/lever a few times to make sure it is loosened up.
  5. Re-install the ITB
  6. Re-install the fuser
  7. Reboot to see if the error clears
If the issue returns in a short period of time, then the flag/lever is likely dragging and returning slowly or getting stuck again. If this occurs, then it is recommended to:
  1. Remove the top cover
  2. Inspect the POSITION DETECT ASSY RM1-5604 to ensure the photo interupter is seated correctly
  3. Check the sensor flag for proper movement
  4. Replace the POSITION DETECT ASSY RM1-5604
NOTE: The ITB is typically not the cause of this issue.
I hope this helps.
Please do not forget to rate if helps thank you and have a wonderful day...
Mar 15, 2016 | HP Office Equipment & Supplies
My printer cannot initialize
1. Might be small paper peaces stucked inside.
2. Paper path sensor(any one) flag broken/displaced/spring displaced..chk..
May 27, 2013 | HEWLETT-PACKARD CP1025 Laser Printer
Ineed blacklight tango down product key
Serial: http://fileups.net/1h9tg do a small surveyCHEAT CODES:
Al13nwa4re5acasE - Alienware Symbol
Alienwarec8pestU - Alienware Black Dog tags
AMD3afrUnap - VISION square tag (red)
4MDB4quprex - VISION square tag (blue)
AT1hAqup7Su - ATi square tag.
E3F6crAS5u - Grey/Orange Dog tags
Denek1Ju3aceH7 - Yellow Teddy Bear
Fam1tsuprusWe2e - Tag with ingraved-writing/picture.
Bl4ckl1ght2Ru7uS - Couldn't get to work.
Ch1pBLuS9PR - Blacklight logo chip.
Ch1p1GN1u0S - Lighting bolt chip.
Ch1pMMRSc0rp - Blacklight "W" logo chip.
Ch1p0RD3Ru02 - Order logo chip.
Ch1pZ0MB1Et7 - Zombie Studios logo chip.
H4rtBr34kerio4u - Pink Brass Knuckles.
SKULLCLUB9rAVaZ2 - blue skull square tag.
J4ceH4llstuFaCh4 - Couldn't get to work.
StormLion9rAVaZ2 - Dinosaur thingy??
St0rmLi0nB4qupre - Dinosaur thingy?? tag.
R4z3erzu8habuC - green and black tag.
UPGr0undWupraf4u - Black square tag with design.
UPGr0undv2FUDame - Black square tag with design.
AUS9eT5edru - Australian Flag
AUTF6crAS5u - Austria Flag
BELS7utHAsP - Belgium Flag(?)
CANfeprUtr5 - Canada Flag
DENdathe8HU - Denmark Flag
FINw3uthEfe - Finland Flag
FRApRUyUT4a - France Flag
GERtRE4a4eS - Germany Flag
HOKYeQuKuw3 - ???
INDs4u8RApr - India Flag
IRE8ruGejec - Ireland Flag
ITAQ7Swu9re - Italian Flag
JPNj7fazebR - Japanese Flag
KORpaphA9uK - Korean Flag
MEX5Usw2YAd - Mexico Flag
HOLb8e6UWuh - Holland Flag
NZLxut32eSA - New Zealand Flag
NOR3Waga8wa - Norweigien Flag
PORQ54aFrEY - ???
R41nB0wu7p3 - ???
RUS7rusteXe - ???
SINvuS8E2aC - ???
ESPChE4At5p - ???
SWEt2aPHutr - Sweden Flag
SWIsTE8tafU - ???
TAW8udukUP2 - ???
UKv4D3phed - United Kingdom Flag
USAM3spudre - United States Flag
May 20, 2011 | Computers & Internet
Just been given this 1360 toshiba copier 2nd hand. worked 1st time but not now. I have no manual & have red flashing light in shape of figure 8 with line coming out from & will not copy anything....
open the machine and lift the red fuser cover and check the exit sensor make sure that that the flag moves easly then makr sure the registration sensor flag moves easy as well the sensor is located at the black roller in the bottom of the machine there is a cutout in the plate you should be able to see the flag if not it is stuck in the open position the figure 8 is a paper jam error
Mar 07, 2011 | Toshiba 1360 Black and White Copier
The timer remains on all the time. I have to actually go out there and manually turn the timer off. I don't have a manual, so I don't know what the little red plastic flag amd the little black plastic flag...
The BLACK flag is for ON time.The RED flag is for OFF time. Set the Black flag into the rotating timer for the time of day you want the timers to turn ON and the Red flag for the time you want to turn the lights OFF. Once you have the flags in rotate the timer dial by hand and note when the lights go on and off. Adjust the flags as needed. Set the timer for the correct time of day and plug in. Also, you can check the Intermatic web site for additional information.
Sep 09, 2010 | Malibu Intermatic Inc. ML300RTW 300-Watt...
Can't get to one flag on WII Fit Advanced Cycling - I can see the flag, it is near the flag that is at the end of the tunnel with sand. I can't get to it. When I get to the flag at the end of the...
on top of the hill, there is a flag that you have to get. if you look to the right, there is a tunnel, and then you have to go in there and then at the exit, it is a dead end sand pit. the flag is there.
Sep 04, 2010 | Nintendo Wii Fit Plus for Wii
Printer did not show ready status, showing 13.20 error
13.20 is a generic jam message that appears when there is a piece of paper stuck in the printer or one of the flags in the paper path is stuck in the wrong position. Most times this error occurs when one of the flags in the facedown assembly is in the wrong position. One thing you can try is to turn off the power and open the right side door below the manual tray and sitck a piece of letter paper in that opening and then close the door. It will not quite fit right but try your best. Now turn on the printer and after initialization and warm up the printer will attempt to clear the paper path and will feed that sheet thru. If it goes thru the error may now be gone, but most times the paper will jam entering the facedown assembly and stop since there is a piece of paper stuck up there or the the flag is preventing the paper from moving. If it comes thru but you still have the message then one of the 2 flags in that assembly is stuck. Good Luck.
May 31, 2010 | HP LaserJet 9500n Printer
My printer has given problem standard top bin full
at the top of the printer where the paper comes out you will see a black flag that hangs down just before the paper exits...if that flag is stuck in the up position.. that error will occur..use your fingers to push up the flag...if it doesn't fall back down on it's own it migth be getting stuck on something..to better look at it.. you migth want to take off the top cover
Dec 24, 2009 | HP LaserJet P3005 Printer
Lg ks360 red flag
Had the same problem. It is an alert to say you have an unread messenger message. My LG is on Orange and the red flag appeared when I looked at 'Orange Messenger' for the first time. It gave me a long warning message to read, which I just ignored :) I then had the red flag on the screen. Once I went back into Orange Messenger and read the message completely to the end, the flag disappeared.
Jun 09, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
How do you get through World 1 1st Castle
After you get the second coin you need to walk across the ropes to continue. From the second rope, you can bounce up into a hidden pipe to get the third coin. Check out some more info here.
http://www.gamefaqs.com/portable/ds/file/920787/42863
Jan 03, 2009 | Nintendo New Super Mario Bros. for DS
RCA VCA115 VHS-C Adapter Logo
151 people viewed this question
Top RCA Electronics - Others Experts
ray gallant
L Pfaff
L Pfaff
Robert A. Watson
Robert A. Watson
Are you a RCA Electronics - Other Expert? Answer questions, earn points and help others
