Question about Brinkmann Gas Camping Stove 815-3795-0 Grill
Black soot on pot or pan - Brinkmann Gas Camping Stove 815-3795-0 Grill
  • 108 Answers
Your using to much oxygen damper your oxygen down and will clear up the smoke
Posted on Apr 22, 2014
How to clean cast iron both pots and pans
Don't..... just rinse with hot water and dry them, the blackening is otherwise known as "seasoning" and protects it from rusting, left to soak or washing with soapy water will rust the cast iron...... if this happens you need to remove as much rust as possible by scrubbing with salt and a cut (half) potato, then wiping with vegetable oil and "seasoning" in a hot oven (do this a few times, the oil will evaporate and bake-on a protective film) think of the edges of your favourite roasting pan....... well used/cared for cast iron will almost certainly look totally black.
Jun 24, 2014 | Lodge Cast Iron Chef John Folses Cast Iron...
Ge 317b6641p001
Does the broiler still work? If not, the broiler element has burnt thru and needs to be replaced. Here is the part to order.
Oct 21, 2013 | Kitchen Ranges
Why is there black soot on the top of my electric stove top
Hello friend, thank you for your inquiry!
From the information you have provided you are experiencing black soot on your Frigidaire stove top. This could be items from your pan or pot falling and being burnt by the elements. You may also want to inspect the area around the stove to assure nothing is falling onto the elements. If you need further assistance please comment back and I would be happy to help you. -Matt
Jan 13, 2013 | Frigidaire Kitchen Ranges
How tp clean black soot off bottom of turkey pot
If you are cooking with propane or natural gas, you may need a new regulator for your range, the black soot is most likely too much gas being used to make the flame. But, as for the soot on the bottom of your pans, try letting the pan soak in a mixture of baking soda and water, then attack it with a brillo pad. Hope this helps!
Apr 10, 2012 | Kitchen Ranges
I am using propane for my cooktop but all my pots and pans have been turning burnt black soot on the bottoms. It's ruining all my other dishes now from the dishwasher spreading it all over, We tried...
You don't have the right Gas to Air ratio..... Not enough air to the burners or you are running to low of gas pressure for propane... Propane takes a smaller orfice or operate than Natural Gas.....
You should have 10" of WC for Propane operation..
You will need a manometer to check it.
The flame should be a blue color with no yellow in it. There should be air shutters right at the orfice to each burners. You will have to play with the adjustment to get the best blue flame with no yellow in the flame.... Hope this helps.....
May 17, 2011 | Jenn-Air JGD8130 Gas Cooktop
Soot deposits from my brand new downdraft jenn-air gas cooktop
Is this on LP or Natural gas? If LP was it converted to LP? In any event,The air shutter must be adjusted on the gas burner tube. You need more air. The valve orifice may also need adjusting.
Sep 28, 2009 | Jenn-Air JGD8345 Gas Cooktop
I have a lot of black soot like substance that appeared in the drain, spray arms, and dripping out of the soap dispenser's. The heating element has a small damaged section. Can a bad heating element cause...
Has to do with the detergent you are using is not completely breaking down the food materials being removed from the dishes during washing. I ran the dishwasher empty through a pot and pans cycle with maximum options and some bleach, Cleaned it to like new condition and from now on I use a detergent that has bleach in it. Cascade has several different products to cover this.
Sep 12, 2009 | Whirlpool Gold 24 in. Built-In Dishwasher...
Black soot on bottoms of pans
Wellif you uninstalled and reinstalled the same appliance it should work the same.. thats weird that it changed. however the black soot is usually from flames that are to high. you could try tightening down the orifice where the gas comes out.
Dec 01, 2008 | GE Spectra JGBP35 Gas Kitchen Range
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
Brinkmann Gas Camping Stove 815-3795-0 Grill Logo
103 people viewed this question
Top Brinkmann Grilling Experts
Paul Carew
Gary Kenady
Gary Kenady
Lyle Siemens
Lyle Siemens
Are you a Brinkmann Grilling Expert? Answer questions, earn points and help others
