Question about Ricoh SP 6330N AllInOne Laser Printer
Sp 6330n error
How do you clear error messages on the Ricoh SP 6330n?
EmmettPinger
  • 63 Answers
SOURCE: Ricoh Aficio SP C210 error message
Try loading letter size paper in tray1 .. Open the front door and the assembly attached to the front door is the transfer roller ASM. mybe you knocked it out of position ..There are green plastic clips that allow someone to the transfer roller unit so its easy to mess up good luck
Posted on May 04, 2009
  • 46 Answers
SOURCE: Ricoh Aficio SP C410DN toner error.
Did you follow the instuctions to shake gently then remove all tags prior to placing the toner? Is it a toner/drum unit. look underneath if theres a green drum. After market toner will not work.
Posted on Aug 28, 2009
newport74
  • 58 Answers
SOURCE: My ricoh sp c811dn suddenly started displaying the
552...... A Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
This code is there to prtect against high temp in the fuser that could cause a fire...best to have a tech look at it
Posted on Feb 26, 2010
Dicedonions
  • 118 Answers
SOURCE: Ricoh SP C811DN error sc549
unplug printer, wait minute, plug in, should reset.
check Ricoh website to trouble shoot if does not reset.
Posted on Apr 29, 2010
  • 903 Answers
SOURCE: how long will a ricoh sp 8100 run with a replace
On most similar Ricoh models, the "replace PM kit" message will keep flashing until the PM kit is replaced, but this shouldn't hinder operation at all. The machine will keep running until one of the parts breaks down, which depends on how old everything is and how hard it is worked.
Basically, the flashing message is a reminder to replace the maintenance kit as a preventative measure, but it does not NEED to be done until something actually breaks.
Posted on May 29, 2010
Why is ricoh 6330n making a loud noise while it is printing?
Check the transfer roller (the sponge roller) there will be a gear on that roller. Lubricate is with some spray on lube.
Aug 11, 2014 | Ricoh SP 6330N AllInOne Laser Printer
The printer keeps printing the same document
do a job reset on machine also clear out print job on computers
Apr 10, 2014 | Ricoh Corp Aficio SP 6330N Laser Printer...
Printer receiving data but does not print
are there any warning lights or message if not could be that print job has an error in file. check computers and clear any print job that is in que then turn copier off and back on and try a different file to print or try print a test page from printer proprieties.
Jan 14, 2014 | Ricoh Corp Aficio SP 6330N Laser Printer...
Reset memory for ricoh sp5100
Not exist memory reset,only Memory Clear.Before execute Memory clear print out all SMC data list.
Enter in SP mode : press Clear(yellow key) press 107 press and keep hold more 3 seconds Stop/Clear(red) key select SP mode select SP 5801 or select using the arrows up/down SP memory clear.Press the OK and execute,when the program has ended normally,the message COMPLETED is displayed.If the program has ended abnormally an error message is displayed.Turn the main switch OFF and ON.Adjust the printer and scanner registration and magnification.Refer to the SMC lists and enter any values that differ from factory settings.Adjust the standard white level,initialize the TD sensor.It is a work from 4-5 hours,good luck.
Feb 08, 2013 | Ricoh Office Equipment & Supplies
Hi, I have a Printer Aficio SP 6330N and it show an error sc542 service call in the menu screen, can you help me please? Regards
This error code means temperature fusing problem. Check all of the connectors on the fuser connector and receptacle, just to make sure that full contact is being made.According to Ricoh direct techs after 100K to 200K copies on a new machine the Hot Roller would start to warp (ever so slightly) because of its thin wall construction (fast warmup time).Replacing the Hot Roller will solve the problem.Please don't forget to rate me if satisfied.
Jun 07, 2011 | Ricoh SP 6330N AllInOne Laser Printer
Apr 20, 2009 | Ricoh Aficio SP C210 Laser Printer
Ricoh SP 6330N AllInOne Laser Printer Logo
43 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
