Question about Amana Washing Machines
I have an amana washer NTW4600VQ1, the wash twmperature will not switch to the hot cycle, it will do warm and cold but no hot.
IrishDruid
  • 2712 Answers
SOURCE: Washer will won't run cold water cycle
Some washing machines allow cold water to enter only during certain cycles. Others intermittently allow hot and cold to enter, to temper the temperature of the water. Consult your owner's manual if you are unsure about whether the machine is acting abnormally.
If you're sure the machine is not working the way it used to--or should--check the following.
  • Is the cold water turned on? If not, turn it on.
  • Is the washer getting hot water but no cold water? If so, check to see if the control panel settings are correct.
  • Is there cold water coming through the proper hose? If not, check to see if the screen inside the water-inlet valve is clean. (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If it's clean, you probably have a defective water-inlet valve. If so, you need to replace the valve.
  • Hope that helps! Should you have any further questions, please feel free to post them here.
    P.S. – I would greatly appreciate a FixYa! rating if the solution I provided fixed or helped you fix your problem.
    Thank you for using FIXYA!
    Cheers!
    IrishDruid
    Posted on Oct 12, 2008
    SOURCE: amana washer has no hot water - cold works fine
    There is a solenoid control valve on all washing machines, located where the water hoses enter the machine. If you have a rubber mallet, you can whack the machine gently with the mallet. If the problem is resolved, it was just a stuck valve. If not, then you likely will need to replace the whole solenoid valve control. Typically there are controls for each water supply.
    Posted on Dec 29, 2008
    stradeteox
    • 88 Answers
    SOURCE: Hot water goes into cold water washes
    It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
    During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
    Hope this helps, please rate my solution.
    Posted on Jan 12, 2009
    gdmisp
    • 66 Answers
    SOURCE: hot water doesnt work, switch to warm and warm comes out.
    If the cold works on cold wash but the hot don't work on hot wash . Then yes the switch is bad.give What model is it?
    Posted on Jan 16, 2009
    blueextc3221
    • 15935 Answers
    SOURCE: Kenmore 70 series washer won't fill during rinse cycle
    It appears your timer/main controller has failed in this instance.
    For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
    I recommend both sites because ...
    FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
    PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
    RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
    If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
    In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
    Anything too complicated or beyond your scope should be handled by a professional.
    If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
    Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
    Posted on Sep 14, 2010
    Hot water fills for very short time on "Warm" setting - wash cycle is too cold
    check either ur water temperature switch or and ur water inlet valve with a multi meter for continuity OHMS
    Oct 16, 2014 | Amana NTW4650YQ 3.4 cu. ft. Top Load...
    Cold/cold cyle wash water not cold
    try to do cold cycle first without doing warm cycle first
    Apr 12, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Washer has cold and warm but no hot hot wash
    check water temperature switch and the water inlet valve
    Apr 14, 2014 | Amana NTW4600VQ Washer
    Cold fill washing machines
    If your washer is the type that all rinses are in cold water only this would make sense that in the winter months when the water is at it's coldest the clothes will feel cold after the spin cycle.
    If your washer has a warm rinse cycle and when you select the warm rinse option the clothes feel cold after the spin, then maybe the hot water supply line is plugged.I recommend disconnecting the hot water hose at the back of the washer and check the screen that is at the fill valve on the washer and make sure it isn't clogged with sediment or calcium build up or any other foreign material that would keep the hot water from entering the washer.If all is well there, suspect either the water temp selector switch or the hot water fill valve. Good luck !
    Jan 23, 2010 | Washing Machines
    Hot water doesnt work, switch to warm and warm comes out.
    Jan 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    Should the washer be hot after the rinse cycle?
    Try cycling a cold/cold wash and see how that comes out.. if it comes out hot then your water inlet valve is letting hot water in when it shouldn't.. conversely, try cycling a hot/hot wash and see that it does indeed come out hot... ( quick tests to verify performance)..hope this helps.
    Sep 18, 2008 | Kenmore 3.8 cu. ft. HE3t Front Load Washer
    Water temperature
    It sounds like your water inlet valve (also known as a Mixing Valve on some washers) HOT solenoid is sticking open. When you select either a hot or cold wash cycle, separate solenoids open or close to allow only cold water to enter the washer on the cold wash cycles and hot water to enter on the hot cycles. If the hot solenoid stays open, you will have hot water mixing with your cold water during the cold cycles. The result is warm water. I would recommend you replace the water inlet valve. This is a job the average DIYer can do. Please post back with your model number and I can assist you with locating a part number and/or give you specifics on how to access the valve to replace it.
    Aug 26, 2008 | Maytag Washing Machines
    Washing Machines Logo
    43 people viewed this question
    Top Amana Washing Machines Experts
    Dan Webster
    Dan Webster
    Charles T Nevin
    Charles T Nevin
    Are you an Amana Washing Machine Expert? Answer questions, earn points and help others
