Question about Universal CAMPSOR-10 Split Type Camping Oil/Gas Fuel Stove - Silver Red
What type fuel and oil does this take - Universal CAMPSOR-10 Split Type Camping Oil/Gas Fuel Stove - Silver Red
    Master:
  • 752 Answers
My searches of the internet indicate that this appliance is a multi-fuel appliance.
It is supplied with a gas bottle - for use with butane fuel
(see http://www.dx.com/p/campsor-9-split-type-camping-oil-gas-fuel-stove-silver-red-126914#.U0we9nlOVjo )
Read the reviews on that webpage for reviwers experiences with different types of fuel. Diesel doesn't work, it seems, but kerosenr and unleaded gasoline (petrol) work ok. You may need different connector for gaseous fuel and liquid fuels.
Coleman Naptha fuel apparently works well.
I hope this information is some use.
14.April.2014
Posted on Apr 14, 2014
  • Cody Harty
    Cody Harty Apr 14, 2014
    So regular unleaded works
WHATS THE FUEL AND OIL RATIO FOR 25HR 2CYL OUTBOARD MERCURY
need the year of manufacture as some 2 stroke units have oil injection that automatically mixes the oil in the correct ratio for engine rpms otherwise it is 50:1 ( 50 parts fuel to 1 part oil)
oil requirements --certified tc-w3 2 stroke outboard oil ---not ordinary engine oil
reference
google --type in mercury outboard oil to fuel ratio
May 07, 2017 | Mercury Boating
What type of oil do you recommend for my 2005 6.6 Durmax. And should I change the fuel filter at every oil change.
Rotella T 15w40 is the standard for diesel engines. I would highly recommend changing the fuel filter every oil change.
Feb 15, 2017 | Cars & Trucks
How do i mix my 2 stroke for a makita chainsaw how many ml of oil to a litre of fuel
Mix the fuel and oil in a suitable container that is airtight with a secure stopper to ensure the fuel mixture has a long shelf life. Keep the funnel, spout, container, etc., dry and very clean. Storing it all in a large plastic bag serves very well for this purpose.
Any quality engine oil can be used but an oil of the recommended type and viscosity will produce much better results. Purists and traditionalists still like to use vegetable oil but this has a very short useful life and dubious results. Self mixing 2-stroke oils are best and synthetic-based oils are reckoned these days to be superior.
Put fuel in the container first and then add the correct quantity of oil for the number of litres of fuel, close the container and shake with vigour for a few seconds and then transfer the fuel to the tool.
The number of ml of oil to use per litre of fuel will vary depending on the engine type, manufacture and age. The fuel/oil ratio is often marked on the fuel tank or cap, 30:1, 40:1, 50:1, etc.. 50:1 would require 20ml of oil per litre.
Some 2-stroke oil bottles have a useful measuring scale on the side...
Aug 06, 2016 | Makita Garden
When I fuel up my oil pressure goes up i.e. 1/2 tank of fuel over 80 on the oil guage at same time fuel consumption goes up drasticaly
Adding fuel to the fuel tank is absolutely unrelated to to any change in engine oil pressure.
The oil pressure will be higher when the engine oil is cooler and lower when the engine oil has warmed up.
If you are experiencing abnormally high oil pressure on start up I suspect you are running the incorrect type and grade of oil in the engine. Only use the oil specification(type and grade) listed by the manufacturer for your engine and nothing else.. If you are unsure what that is then it is specified in your owners manual for the vehicle.
High fuel consumption has also nothing to do with your engine oil pressure. If you are experiencing high fuel consumption then please read and examine these factors..........................
Finding and Fixing the Causes of Poor MPG
Oct 27, 2015 | 2005 GMC Envoy
Gear oil for 2004 honda crf 100
Fuel and ignition Sparks per cylinder: Fuel supply system: Carburetor Ignition type: Digital CDI Funnel diameter: 0.87 inch Compression: Engine mounting: Transverse Lubrication system: Wet sump Gear box: Manual 5-speed Clutch: Wet, multiple discs, cable operated Final drive: Chain Spark plug pipe type: NGK, CR7HSA Motor oil: Synthetic, 10W/40 Starter: Kick-starter
Jan 11, 2014 | 2004 Honda CRF 100 F
What type of gas to use in a craftsman edger 358.773110
FUELING ENGINE This engine is certified to operate on unleaded gasoline. Before operation, gasoline must be mixed with a good quality 2-cycle air*cooled engine oil. We recommend Craftsman brand oil. Mix gasoline and oil at a ratio of 40:1 (A 40:1 ratio is obtained by mixing 3.2 ounces of oil with 1 gallon of unleaded gasoline). DO NOT use automotive oil or boat oil. These oils will cause engine damage. When mixing fuel, follow instructions printed on container. Once oil is added to gasoline, shake container momentarily to assure that the fuel is thoroughly mixed. Always read and follow the safety rules relating to fuel before fueling your unit.
Sep 12, 2011 | Craftsman Garden
What petrol mix does it use, and what type of oil
Depends on what type of saw it is some very new ones use 50:1 oil fuel mixture older ones use 25:1 mix and the larger the bore or engine capicity you should probably use a little more oil to protect it, Mose saws will give the oil fuel ratio on the gas cap or in the owners manual
Brad
Aug 01, 2011 | Garden
Fuel and two stroke mix pls oil type for chain pls
For almost all modern two-stroke engines, a 50-to-1 mixture is recommended. That requires about 2 1/2 oz. oil for every gallon of gasoline.
  • Use only two-cycle oil for your mixture. This oil is made especially for these engines and can be purchased at gas stations, hardware stores or any other place where you buy regular motor oil.
Mar 20, 2011 | Oregon Cutting Systems Chain Saw Cutting...
WHAT TYPE OF FUEL, STRAIGHT OR OIL/FUEL MIX & WHAT PROPORTIONS ?
Determine if your engine is a two-stroke or a four-stroke. Check the gas tank on your lawnmower or the owner's manual to determine what type of engine you have.
Read the label of your two-stroke oil. Follow the directions on the package to ensure the right mix.
Measure and pour the gasoline in to the empty gas can.
Add four ounces of two-stroke oil per each gallon of gas.
Replace the cap on the gas can and shake the oil and gas to mix. Add fuel to your engine.
Take care.
Jun 01, 2010 | Garden
Lost mine, need fuel/oil ratio and where to add oil for chain
You can down load your manual here: (this is a 2006-11 PP4218AVX and may not be your saw) Oil cap location is correct as is the fuel/oil ratio.
http://weborder.husqvarna.com/order_static/doc/NOUS/NOUS2006/NOUS2006_545137248.pdf
Page 9 has an illustration of the oil and fuel caps.
Page 10 (BEFORE STARTING ENGINE) says the correct mix is 40:1 (1gallon of premium fuel to 3.2 ounces of quality 2-cycle oil).
Richer mixes make for starting more difficult, foul plugs and create carbon build ups on the piston and in ther muffler.
If not correct Operators Manual, you can find the correct OM here:
http://www.poulanpro.com/node4043.aspx
Type 4018 in the search query.
The dash number on the serial is the type. HTH
Lou
Jan 18, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Universal CAMPSOR-10 Split Type Camping Oil/Gas Fuel Stove - Silver Red Logo
89 people viewed this question
Top Universal Video Game Consoles & Games Experts
James Wishart
Are you an Universal Video Game Console and Game Expert? Answer questions, earn points and help others
