Question about Sport & Outdoor - Others
We just got a Seascape Hot Tub with no instruction booklet. We can not get it too heat or the jets to work. We see functions F1 thru F8 when we hit the jets button. What do the mean? Are there any instruction manuals online we can look at?
  • haljeanine Jun 18, 2009
    I do not see a model No. it just says Seascape by Serenity Spas (Seats 5)
    I found exactly what I needed. Thank You!
  • 13,433 Answers
Hey,
do you have a model on that? so that I can find you the right instructions.
Thanks
Ekse
Posted on Jun 18, 2009
My hot tub has an issue. Only half the display is working, there's no heat and the jets wont turn on. If I trip the curcit, I can get the hot tub jets for 10-30 seconds and that's it. HELp
Almost all hot tubs use 230 volt AC power which comes from the power company in two power wires plus one common common wire. You get common 115 volts between a common and either other wire. "Half way" working could well be an attempt to run on only one of the wires. There is also likely to be a ground fault circuit breaker in the wiring which makes sure current going out to the tub is all returned via the wires and not through someone's legs to ground. If you're comfortable with an AC voltmeter check some voltages but understand that 230 volts is way into the killing range. Two people present and well insulated probes are important.
Apr 15, 2016 | Pool & Spa
No display upon turn on
Did you press and hold the FN function key plus the key that toggles the display? In your case it might be the FN+F8 if F8 is the key that toggles the display.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
If your video card is bad you will not see anything on the laptop's lcd screen or the external monitor.
Jun 10, 2012 | ASUS Eee PC 1005HAG Notebook
Emachines wireless not working
Try looking in the program list for the program that starts the wireless. Click Start/Programs and look for the program that drives the wireless and open it.
Maybe you don't have your wireless turned on. Look on both sides and in front for the Wireless Switch and turn it on.
Also once the wireless switch is turned on there are keystrokes that can toggle the wireless on or off. Normally you would Press and Hold the FN function key located at the lower left of the keyboard, then hit the correct F1 thru F12 key that toggles the wireless. The correct F1 thru F12 key to hit will have the wireless signal icon )))) on it. Or it might have the icon of a tower with the wireless signal icon )))). Normally the screen will display Wireless On or Wireless Off when you toggle the wireless.
May 11, 2012 | E-Machines M5312 Notebook
Can't display with my laptop using VGA to 3RCA cable
Can't display where on another monitor or tv? Did you reboot the computer after plugging in the VGA Cable. Sometimes you have to hit the FN Function Key + F1 thru F12 to get the image to display. The correct F1 thru F12 key will have CRT/LCD on it or it might have the icon of a display. Press and hold the FN function key then hit the correct F1 thru F12 Key.
Mar 29, 2012 | HEWLETT-PACKARD ProBook Computers &...
How do I turn off wireless radio?
There are a couple of ways to turn off the wireless. 1) Look for a wireless switch on either side of your laptop or at the front of your laptop. 2) Normally the FN (Function Key) + (F1 thru F8) will toggle the wireless between on and off. To find the correct F1 thru F8 key to hit look for the )))) symbol which denotes wireless. Press and hold the FN key then hit the Function key that corresponds to wireless. Watch your desktop screen because most will display Wireless On or Wireless Off as you hit the keys. If not one sure way to know it is off is look at the computer at the bottom right of the screen near the time, it should go from being a solid green to a computer with a red X on it.
Mar 20, 2012 | Toshiba 156 Satellite P755S5265 Intel Core...
How restart laptop using f bottons
You don't restart a laptop using the Function Keys (F1 thru F12). You restart the laptop by hitting the power button. The function keys will allow you to boot the laptop in SAFE MODE if you repeatedly hit the F8 key until you see the Safe Mode option after you hit the power button. Function keys will also allow you to change the boot order, go into the BIOS or Setup to change things also. You need to state your problem as to what is going on with your laptop.
Mar 19, 2012 | Computers & Internet
Hot tub heating is working but pump has stopped
you may have a system that uses a small circulating pump that circulates the water thru the heater to keep water temp at proper level (this is usually the case with hot springs spas and is because it is the most cost effective way to maintain constant water heat without using a full size pump or two speed pump just to push water past the heater core. therefore the issue is you have a problem with your jet pump and it has nothing to do with the circulating and heating portion of the spa. you can check to see if there are any reset buttons in or near the equipment as well as open enclosures to make sure everything is clean and dry also make use any contacts on spa skirting are secured propertly
Apr 24, 2010 | Pool & Spa
Jets don't work in the jetted tub.
First the obvious, most are electrically connected to a ground fault device, ether an outlet or a breaker. BEFORE ADDING WATER, check these out to make sure they are not tripped. Most all tubs have a minimum water level which must be reached before the jets will operate. This is usually a piece of trim located above the depth of the jets. Make sure the tub is filled to cover this part. If you cant identify the water level device fill the tub so that all the jets are covered by an inch or 2. Some tubs have push button switches or touch pads to control the motor, some have touch sensitive trim. There may be some sort of medallion from the maker on the tub, simply touching it will start the tub. Once you get it going most tubs have a built in timer that turns off the pump in 15 - 20 minutes. For more tub time just hit the switch again but keep in mind that extended exposure in a hot tub can mess with your blood pressure and cause you to loose balance or pass out, hence the 20 minute timer.
Mar 22, 2010 | Whirlpool Safety Bath Walk In Bathtub -...
I discovered tiny ball bearings in my hot tub. Where could they come from? The hot tub is working fine.
The ball bearings from your spa are from a roto head jet. Typically they are from one of the larger sized jets and they make the swivel action in the roto swirl jets function smoothly. You can determine which jet is coming apart by the loose function of the center nozzle. The jet can be removed and replaced to solve this problem. Most jets screw out but when they have deteriorated a lot, you may need plyers to take the jet out in pieces.
Jan 03, 2010 | Qca Spas Majestic Series Aruba Xl Hot Tub
Hot tub has power but nothing else works
MY control panel was replaced ,it cycles but, no lights ,no jets,no heat works..What's the problem .
Oct 01, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Sport & Outdoor - Others Logo
62 people viewed this question
Top Sport & Outdoor - Others Experts
Marvin
Marvin
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
