Question about Panasonic KX-T7633 Corded Phone
CANNOT RECEIVE INCOMING CALLS
I cannot receive incoming calls; however, I can make outgoing calls on my handset
feelfemi009
  • 277 Answers
SOURCE: how to erase incoming and outgoing calls in
go to resent calls and delete the incoming and outgoing calls
Posted on Jul 17, 2009
SOURCE: Incoming calls only ring once then hangs up. Can call out/not in
reset your mobile
Posted on Jan 29, 2010
cnavarro
  • 2460 Answers
SOURCE: Incoming calls: When we receive an incoming call,
Extension call forwarding is controlled by a timer, and they put these things in the manual. If your CF after 2 rings is from a call to a specific extension, from that extension, dial *713 and a 2 digit number from 00-99 seconds on the intercom. Start with 18.
If your call forwarding is from intercept, then you have a system programming issue and need to look in the installer's manual or check with your system programmer.
Carl
Posted on Dec 02, 2010
cnavarro
  • 2460 Answers
SOURCE: In our system when we receive incoming calls, its
It's called programming. Somewhere, you have a Programming Manual for your system and in the 400's (ie 411-413) you define the ringing for each extension.. By default it's set to immediate.
This is for the TA series systems. Yours may be different.
Carl
Posted on Mar 10, 2011
ashehri22
  • 37 Answers
SOURCE: Cannot get Dial Tone on
Is it dial lock?
Posted on May 11, 2011
Have a uniden 5.8... The problem is incoming calls do not ring. Outgoing calls work perfectly. The caller hears one ring and then their phone goes silent.
You have probably accidentally activated a blocking function on your phone! Take the portable handset, and remove the battery. Wait five minutes, then reconnect the battery. That should reset the phone to "initial conditions," which are the settings it had when it was new.
Apr 17, 2017 | Uniden Lands Phones
A180 just showing base and no response
Is the ringer turned off? Or is the volume on the ring tone set too low? Another possibility is that the phone isn't set to receive incoming calls - the Siemens phones I've owned allowed one to specify which handsets could handle incoming calls and outgoing calls on each line.
Jun 01, 2014 | Siemens Lands Phones
I get incoming calls but unable to make outgoing calls
Make sure that you have got sufficient credit to enable you to make outgoing calls. You can still normally receive incoming calls with no credit but make any except to emergency numbers.
Jan 12, 2012 | T-Mobile Dash Smartphone
I can not call or receive calls. She says she dropped it but i think she went in the settings and changed to so that she can not receive or make calls by mistake. what is wrong
She might have barred the phone.
This is what to do. Press this code #330*0000# and send. Your will be unbarred.
Regards
Jul 05, 2011 | Cell Phones
Unit does not make outgoing calls nor receive incoming calls. Display seems OK but tiny vertical bar top RH corner doesn't flash 9should it?). Unit is fully charged. Trying to call IT from cellphone gives...
Friend i think u r cell phone setting are mess up
so please go to ur cell phone setting and go to security and then try to find restriction menu and then turn of it if u find it then
u got
three options like
outgoing call
incoming call
messege
phone book restriction
so set it unselect
Jul 22, 2009 | Cell Phones
How to erase incoming and outgoing calls in
Jul 17, 2009 | Panasonic KX-TGA101S Cordless Handset
I9+ phone will not receive incoming calls
check and make sure you ringer is set to something but silent.
Jun 04, 2009 | Cell Phones
Philips VOIP8411B/37 IP Phone - Cannot make outgoing Skype calls
the internet connection's outgoing is too slow. ALl internet connections have an outgoing and an incoming speed. Make sure you are not uploading anything to the internet or get a faster internet service provider
Apr 29, 2009 | Philips VOIP8411B/37 IP Phone
Panasonic KX-T7633 Corded Phone Logo
18 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
