Question about Steinel Heat Gun Hg2310lcd 34871 34870 Intellitemp
I have a heat gun HG2310LCD sometimes does not heat but the fan if it works perfectly, which may be the problem?
2 Suggested Answers
dogsled48195
  • 411 Answers
SOURCE: hi i have a steinel heat gun hg2310lcd my stinel
you have a 1 year warrany on this gun this has a elecrionic thermocouple
Posted on Jan 23, 2011
2002 Chev. Traiblazer- heat guage jumps from low value to high values almost instantaneously . The dealer has replaced the water pump and the clutch fan but the problem persists. Sometimes there is no...
Is the engine actually over heating or just the gauge giving incorrect readings?? The stepper motor in the console's temp gauge could be defective. Have someone with a laser heat gun check the temp of the engine around the thermostat to find the correct temp.
Jul 07, 2011 | 2002 Chevrolet TrailBlazer
Tip
F06 error code. Its not what you think
Had F06 error usually when the washer went into spin cycle. Followed all tips on different sights. No real concrete solutions to my problem. Sense my problem was intermittent I ruled out the motor. I started looking at my MCU and found my heat sink was really hot to the touch. I slipped MCU out of wash machine still electrically connected and put my window fan on MCU while operating and washer worked perfectly. I the went down to Radio Shack and picked up a 115v CPU fan ($20) and installed on my heat sink. Just splice fan wires to MCU power wires (wire connector w/ the 2 largest pink wires). Mount fan creatively to heat sink (tywraps, hot glue gun, however) . I saved $150 and the heartache down the road. I think this a common problem for that MCU. Hope this helped. <br /> Robert, Aircraft Technician
on Oct 24, 2010 | Kenmore HE2 Plus Front Load Washer
8975 does nothing,voltage out of switch but does not heat up or blow air
I have 4 dead MW heat guns with the same problem. The most common problem is a blown fuse in the heating element assembly which prevents the circuit from being completed. It is attached inline with the Red wire. Test the fuse with an Ohm meter, then use a jumper cable to temporarily jump the fuse. The fan and heater should then work. Replace the fuse and you will have a working heat gun
Nov 26, 2010 | Milwaukee Tool Milwaukee 8975 - 6 Dual...
Milwaukee 8977 - 20 Variable Temperature Heat Gun blows air but no heat. how do you troubleshoot the circuit board or the heating element?
With out the thing plugged in with an OHM meter the heting element can be checked with the nose removed. Most of the time once the nose is removed the problem is easy to see the end is burnt off the element connection. Remake the connection reinstall the nose and test. The heating element runns right off the switch and the connection there is easy to see with the handle opened. This is simple unit and wires burnt off from being too hot is almost always the problem. look it over carfully and the problem will be seen.
Apr 21, 2010 | Milwaukee Tool Milwaukee 8977 - 20...
Intermittent heat on Weller D550 although lights stay on. When not working, moving the terminals may get it to start working again. Sometimes, just moving the gun will interrupt the heat. Continuity...
Heat gun tips often get bad electrical connection where the nuts tighten to the tip ends. Remove the tip, clean the ends, re-install the tip, making sure the nuts TIGHTEN onto the tip ends. Your problem is common and always caused by a poor connection at the tip ends/nuts.
Jun 20, 2009 | RTO Weller D550 Soldering Gun
My heat element works but not the fan, tested the motor and its fine so it must be the elctronics. The element will burn out if that fan wont work, how can i bypass the electronics or what component may be...
i have fixed one like this and in my case it turned out to be the shaft from the motor to the fan was broken , so i just reglued the fan back onto the shaft with a really good heat resistant glue and it works fine .
May 07, 2009 | Steinel Intellitemp Heat Gun,...
How does it work?
Heat guns look a lot like hair dryers - but, as many instructions thoughtfully point out, should never be used for drying hair! The method of operation of a hot air gun is similar to a hair dryer: a fan pulls air into the body of the tool and drives it across an electric heating element and out through a nozzle. For stripping paint, the heated air is directed onto the painted surface, causing it to soften so that it can be easily stripped off - either by using a stripping knife or hook. For best results it is best to work up the surface with the heat gun above the stripping tool, softening the paint just before the stripping tool reaches it. The tool is used one-handed, with the other hand to hold the stripping tool. Some heat guns can be used sitting on a bench so that two hands are free to use the hot air for other applications.
Aug 27, 2008 | Master Appliance 430/840 DF PROHEAT MASTER...
Fan runs constantly on cool mode
Simple Question: Did you check to see if the fan switch on the
t-stat is in ON or AUTO? If ON the fan runs nonstop. If in auto the fan cycles with the outdoor unit.
next does the fan shut off if you turn the t-stat to off?
A stuck relay should keep the fan running all the time.
Sometimes if the relay is stuck you can whack the side of the Air Handler and the connection will break.
Sometimes instead of a relay there is a stack switch.
It's a little black stack of 3 disks this is a bi-metal switch.
they do get stuck more often than relays.
The fan relay may be on a electronic board. I don't know for sure without seeing your unit.
Good Luck Phil
May 18, 2008 | AmcorAire UCHW-H12AF2 Split System Air...
Do Not Use A Heat Gun On Your Xbox 360! Send It In To Microsoft! Find Out Why Here!
If you are looking for an Xbox 360 3 Red Lights Fix do not use any guide that suggest a heat gun fix!
Although a heat gun is used sometimes you are better sending it in to Microsoft to do the work!
If you buy any guide with the heat gun fix ask for a full refund you will need it!
If you still want to fix it yourself then click the link below and get a FREE preview of an easy 30 minute fix that does not use a heat gun:
Xbox 360 Repair
Mar 15, 2008 | Microsoft Xbox 360 Console
Steinel Heat Gun Hg2310lcd 34871 34870 Intellitemp Logo
23 people viewed this question
Top Steinel Tools & Hardware - Others Experts
Are you a Steinel Tool and Hardware - Other Expert? Answer questions, earn points and help others
