Question about GE Monogram ZGU48N4GHSS / ZGU48L4GHSS Stainless Steel Gas Cooktop
Yellow flame I washed my gas stove because it had cockroaches in it,and now it's flame is yellow in the center and blue from sides,and the yellow flame is too high,it ruins all the pans,what is the solution.
    Sergeant:
  • 230 Answers
The problem is with the orifice leading to the burner. If it is not centred then you will get yellow flame. Or you are impeding the flow out of the burner and it is not mixing properley. I would pull the burners apart and make sure everything is clear and the orifice is centred.
Posted on Apr 14, 2014
2 Suggested Answers
  • 222 Answers
SOURCE: need replacement drip pans for ge xl44 gas stove
u can find the parts only in the service center of GE appliance center.but if ur unit is more than 10 years,im sure no parts available.
Posted on Jul 04, 2009
How do I adjust the flame on a MGC5430 gas cooktop? Flames are too yellow and cause black soot on bottom of pans. Doesn't seem to have an air shutter adjustment
Is this unit set up for natural gas or propane? New stoves usually come with ORIFACES for both gasses. They would install between the on/off knob and the burner tube under the stove top. They may be tapped to the under burner area of your stove. If you lift your top stove cover you may find them. If you don't find them, you may need to purchase the correct applications for your stove. GOOD LUCK FRIEND.
Nov 28, 2014 | Maytag MGC5430 Gas Cooktop
LP gas stove top . burners want turn down to low. Only medium and high flame work on burners.
Has this just recently happened? Check the knobs aren't cracked sometimes the brass spindle inside the knob is not gripping to turn it right down, also check your l p gas pressure it should be 2.75 kpa.
if the flames are big and yellow it's getting too much gas, not enough air.
Mar 13, 2014 | Whirlpool WFG231LVB Freestanding Gas Range...
Black smoke coming from oven while preheating
CLEAN the OVEN put a drip pan under stuff when cooking
Dec 21, 2013 | Premier 24 inch Compact Gas Range w/ Solid...
Just put in a new Caldera LPGas cooktop the flame is yellow and putting soot on pots how can I adjust air to correct this?
you stove may have jets for natural gas rather than bottled gas the calorific value of natural gas is different to propane and the jets are larger because of this. if using bottled gas then you will get yellow flame and soot because there is too much gas to burn properly check your installation manual for procedure to change the jets for each gas
Dec 19, 2010 | Stainless Caldera SSK-305 Steel Gas...
Gas stove burner will not turn on
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
Apr 29, 2010 | Gaggenau 23 in. KG 260 Gas Cooktop
I have a new gas hob which is making the bottom of my pans black like soot?
You must have an improper air/gas ratio. To adjust the shutters you simply open or close them a hair till you get a beautiful blue flame. Improper flame is yellow, good flame is blue. 9916a1c.jpgThis gas conversion training manual shows where to adjust
Apr 22, 2010 | Cooktops
Gas Hob Flame
Hello
Tha sounds to me like the air mixture nedds to be adjusted on the stove, It's not difficult to do, just rotate it until the flames loose the yellow or your pans will be stained with soot.
The should be by the fittings (convertion fittings), you know?
LP Gas to Natural Gas or Natural Gas to LP Gas.
Hope this help
Eddie Rentas
Tupper Lake NY
Jul 30, 2008 | Cooktops
Creda 4 burner, converted to LP
Your flame is perfect if it's just the very tip that is yellow or white. All burners should be adjusted this way, on highest flame.
Mar 13, 2008 | Jenn-Air 36 in. CCG2523 Gas Cooktop
GE Monogram ZGU48N4GHSS / ZGU48L4GHSS Stainless Steel Gas Cooktop Logo
158 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Jim London
Jim London
Are you a GE Cooktop Expert? Answer questions, earn points and help others
