When forwarding calls to another extension, an alternate voicemail greeting answers if the call is not picked up by a person. It is not the voicemail for that extension, but one of the "main" mailbox voicemail choices that is old and not used anymore. How do I make it the main voicemail greeting that I want?
SOURCE: Changing main greeting
You need to go into Feature 983 system admin. You need to get the password though.
SOURCE: how to chg a norstar mailbox from 'General Delivery' to 'User'
check under the mailbox set up ( where you created it) for that extension that the extension number of that phone is on that mailbox> in other words, you could create mailbox 221, but assign it to 222. The Gen Delivery box is 100 which is the catch all for transfers that cannot be completed.
SOURCE: Unanswered calls will not go to voicemail
Ok, do you know how to get into system programming?
If you do:
-> first dial FEATURE 985 this will give you the DN(Extn) for the voicemail
-> get into programming
-> TERMINALS&SETS enter and put in the extn that is giving you issues
-> then under CAPABILITIES look for FWD NO ANSWER and put in the DN of the voicemail you saw with the Feature 985
-> hit next for the number of rings you want it to ring before going to voicemail
-> hit next and you can now RLS to back out of programming.
Voila, that set will now goto voicemail.
SOURCE: Callers are not prompted to general mailbox
Under greeting table 1 set your greeting attendant assignment as 100,that should send the caller to mbox 100 if they press 0 or make no selection at all
SOURCE: What is the feature code for forward to Voicemail?
Try FEATURE 9 8 4
this forwards all calls that ring on your phone to your voicemail.
To shut it off FEATURE # 9 8 4
Testimonial: "Correct code and thanks for the reply!"
You have probably inadvertently cancelled no answer call forward at the extension in question. You will need to know the port numbers for your voicemail but if you watch this video it will show you how to reset the call forward. There are plenty more handy tips for Samsung telephone systems at
www.AbbeyTelecom.com
