Question about Craftsman Garden
I have a craftman model 917.270680 that wont move forward or reverse. the pin in the back is engaged. the mower starts and runs fine, and the PTO will engage.
  • 1 more comment
  • rheern Jun 18, 2009
    I chedked, the belt is not on the transmission pulley....I have purchased another belt and will try to get it on soon. thanks!
  • rheern Jun 19, 2009
    The belt was wedged under the pulley, so I did have to pull the deck, when I finally pulled the belt it was worn so I replaced it, and the mower blades, and mowed my grass :-).
  • Dwain Pippen May 11, 2010
    Have you checked the condition of the belt? Is it still on the two idler pulleys by the engine pulley and is it still on the transmission pulley? Did you take one of the rear wheels off before this problem started?
  • 376 Answers
Just because it came off doesn't necessarily mean you need a new, one unless it looks bad. A stick or Sweetgum ball could have flipped it off. Try just putting it back on and see how it does. Easier than dropping the deck and replacing it.
Posted on Jun 18, 2009
Why wont my john deere d140 move when I ngage the double foot pedal
The drive belt may be broken, or it may have slipped off a pulley.
Aug 03, 2014 | John Deere Garden
My cub cadet LT 1050 wont move forward or back but starts and the PTO will run?? need help.
make sure your tranmission is engaged if still not working change fluid and filter if not can you hear pump loudly when you try to move it if so be ready to buy a new pump
Aug 14, 2013 | Cub Cadet Garden
X595 john deere pto wont kick in
These John Deere Garden Tractors have a RIO (Reverse Implement Option) on the PTO. If your PTO is engaged and you back up, the PTO will automatically stop. To reset it, depress your PTO engagement switch to the OFF position. Take your foot off the reverse pedal. Pull up on the PTO engagement switch. The PTO should restart. To use the RIO feature, pull up on the PTO switch for a second or two just before you step on the reverse hydrostatic pedal. The yellow RIO indicator light should come on your dashboard and you can now back up with the PTO still running. Works great for snow blowing when I don't want to keep resetting my electric PTO clutch to keep restarting my snow blower.
If your PTO will not restart, you may have a PTO switch starting to fail, or a likely logic problem in your electric PTO control module, or one of your forward/reverse indicator switches, which is linked to your PTO control module along with the overtemp circuit, is stuck/faulty.
Feb 20, 2013 | John Deere 26HP Hydrostatic 54" Riding...
Engine runs but stalls when engaged
This sounds like a micro switch, or relay issue, it is not stalling it is being switched off, if there are some relays on the back of the bulk head replace them, they are just a push fit.
Feb 26, 2012 | Garden
Lawnmower wont move in fwd or reverse
Is the brake sticking. On my craftsman mower there is a bar under the brake pedal that pushes back a lever when starting. And the lever sticks. I have to reach underneath and pull the lever forward and then the mower goes. I haven't found a solution to that yet.
Apr 04, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
PTO QUIT SHUTTING DECK OFF WHEN GOING INTO REVERSE, THEN QUIT ENGAGEING REVERSE OR FORWARD
What kind of lawnmower is it ? Craftman has a position on the switch which turns off the deck saftey switch that shuts off deck,also it has a switch on shifter wires could have come off or switch could be bad .
May 10, 2009 | Garden
Engine dies when engaging PTO switch on a John Deere GT235. I have replaced the seat switch and the PTO switch.
Check and adjust your RIO switch{reverse implement option}near the trans if so equipped.What happens when you press forward pedal then engage blades?Would also check the lower bearing on your pto clutch to see if its seized up.
Feb 21, 2009 | Garden
Will not go into gear
a hydro uses a foot pedal on the right side , you push forward to go forward or rock the pedal rearward to go in reverse - a regular transmission has a shifter usually between your legs for reverse 1st 2nd or 3rd gear - you also said the blades wont engage . are they electric ( with a switch ) or do you manually move a lever .
Oct 23, 2008 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
160 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
