Question about White Rodgers 1F98EZ-1421 Emerson Blue Easy Install Universal 4-Wire
Emerson lM90T Icemaker
It does everything correct except freezing the cubes, Does it take r34 Freon and where do I add it at
    Novelist:
    Scholar:
  • 166 Answers
Refrigerators and freezers have permanently sealed refrigeration systems. It requires special knowledge, tools, and parts to check or charge the system. If you're certain the compressor is running, but it's not cooling, then it's likely you have a refrigerant leak.
If the compressor is NOT running, then you have a thermistor, or temperature control, or defroster control, or other electrical problem.
No, it does not use R-134a refrigerant. That's for auto air conditioners.
Posted on Apr 15, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do remove the pressure ,before you add r34 cooler
you never work from the high pressure side of an a/c system. EPA requires it to be recycled, freon is removed using a vacuum tool on the low port until the system holds vacuum for 5 minutes. Then the recycler is removed and freon is added. You mean R134 right?
Aug 20, 2012 | 2001 Volkswagen Beetle
Sub zero 532, ice maker issue. water enter the cube bin freeze into a block of ice with the cubes embedded. What is the cause of this issue?
There is a few things that you will need to check to isolate the problem. this first thing is locate the fill tube where the water comes into the ice maker. What you are looking for is any ice frozen inside causeing an overspray of sorts. If that checks good, then the next thing is look at the icemaker itself. Look at where the water goes to and freezes. Is it completely full of frozen water? if so then the water valve is sending too much water either because the ice maker called for it or the valve stuck and didn't close when it was supposed to. If its not full, look at the bottom of the ice maker, checking if there are any cracks allowing water to fall into the bin. My personal opinion though would be to change the ice maker and the water valve because of the age of the machine. the bad part is the actual icemaker for that model has been discontinued but I believe you can use a whirlpool style that matches, comes in a kit that has both the water valve and icemaker, and cost almost half the price as the original. that part number is 1129313
May 21, 2012 | Refrigerators
How to recharge air conditioning with freon
if it is a 2000 nav it should not take freon it should be r34 you can buy this at your local walmart you add it to the upper cap in the engine compartment should be rite off the fire wall on that vehical i belive the passenger side
Mar 02, 2012 | 2000 Lincoln Navigator
Model PS26PSTASS SN GL 432433 Behind the bottom drawer the fan unit is frozen. Also the ice maker has water running out and freezing along with it doesn't freeze the cubes properly or discharge them...
The frozen fan is from a bad thermister located located behind the fresh food evaporator coil. The icemaker could be getting too much water or not level. The icemaker can be leveled by placing a washer behind the mounting stud.
Feb 17, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The icemaker will not work
you might need to replace the icemaker or the freezer isnt getting cold enough for the icemaker to operate correctly. if freezer isnt getting cold enought for icemaker to operate correctly you should probably have it checked by a tech. if the icemaker isnt taking water you also could have a bad water valve
Sep 17, 2009 | Refrigerators
Ice maker doesn't turn out the ice/ tray fills with water, and freezes, but doesn't turn out the ice into the door dispenser.
Top 2 possiblities
1/ The motor that ejects the ice is shot.
or
2/ the heater element that melts the ice into pieces.
Here is where you can probably pinpoint problem.
Making Ice When everything is hooked up, the icemaker begins its cycle. The cycle is usually controlled by a simple electrical circuit and a series of switches. In the diagram below, you can see how the icemaker moves through its cycle.
  • At the beginning of the cycle, a timed switch in the circuit briefly sends current to a solenoid water valve. In most designs, the water valve is actually positioned behind the refrigerator, but it is connected to the central circuit via electrical wires. When the circuit sends current down these wires, the charge moves a solenoid (a type of electromagnet), which opens the valve.
  • The valve is only open for about seven seconds; it lets in just enough water to fill the ice mold. The ice mold is a plastic well, with several connected cavities. Typically, these cavities have a curved, half-circle shape. Each of the cavity walls has a small notch in it so each ice cube will be attached to the cube next to it.
  • Once the mold is filled, the machine waits for the water in the mold to freeze. The cooling unit in the refrigerator does the actual work of freezing the water, not the icemaker itself (see How Refrigerators Work for details). The icemaker has a built-in thermostat, which monitors the temperature level of the water in the molds. When the temperature dips to a particular level -- say, 9 degrees Fahrenheit (-13 degrees Celsius) -- the thermostat closes a switch in the electrical circuit (see How Home Thermostats Work for details on this operation).
  • Closing this switch lets electrical current flow through a heating coil underneath the icemaker. As the coil heats up, it warms the bottom of the ice mold, loosening the ice cubes from the mold surface.
-->The icemaker has a heating coil underneath the ice mold.
  • The electrical circuit then activates the icemaker's motor. The motor spins a gear, which rotates another gear attached to a long plastic shaft. The shaft has a series of ejector blades extending out from it. As the blades revolve, they scoop the ice cubes up and out of the mold, pushing them to the front of the icemaker. Since the cubes are connected to one another, they move as a single unit.
  • At the front of the icemaker, there are plastic notches in the housing that match up with the ejector blades. The blades pass through these notches, and the cubes are pushed out to a collection bin underneath the icemaker.
  • The revolving shaft has a notched plastic cam at its base. Just before the cubes are pushed out of the icemaker, the cam catches hold of the shut-off arm, lifting it up. After the cubes are ejected, the arm falls down again. When the arm reaches its lowest resting position, it throws a switch in the circuit, which activates the water valve to begin another cycle. If the arm can't reach its lowest position, because there are stacked-up ice cubes in the way, the cycle is interrupted. This keeps the icemaker from filling your entire freezer with ice; it will only make more cubes when there is room in the collection bin.
This system is effective for making ice at home, but it doesn't produce enough ice for commercial purposes, such as restaurants and self-service hotel ice machines. In the next section, we'll look at a larger, more powerful icemaker design.
Jun 07, 2009 | Kenmore 21.9 cu. ft. Side-By-Side...
Ice maker overflows
The Icemaker may not be dumping the cubes after they freeze then more water pours in on top of them. The icemaker has a heater which turns the cubes loose and allows them to dump. You may find someone to work on an icemaker, not sure. If this is the case, I would replace the icemaker.
Dec 16, 2008 | Amana Refrigerators
Kenmore side by side - icemaker seems to run too fast because the ice cubes are often hollow and they stick together in large clumps. Everything else in the freezer is frozen solid, so I know the freezer...
IF FREEZER IS A THE CORRECT TEMP/ O-10 DEGREES, THE FREEZER IS NOT THE PROBLEM. THERE IS A THERMOSTAT IN YOUR ICE MAKER, IT IS NOT ADJUSTABLE. IT IS A SMALL BI METAL SWITCH THAT TRIGERS ICE MAKER WHEN IT REACHES ITS PROPER TEMP. THE PROBLEM IS, IT IS TRIGERING IT AT TO LOW OF A TEMP.NOT ALLOWING THE ICE TO FREEZE SOLID. IF YOU CAN HANDLE IT CHANGE BIMETAL SWITCH OR CHANGE ICE MAKER ITSELF.
HOPE WE HELPED YOURS TRULY FXIT
Feb 20, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
White Rodgers 1F98EZ-1421 Emerson Blue Easy Install Universal 4-Wire Logo
61 people viewed this question
Top whiterodgers Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a whiterodgers Vehicle Part and Accessory Expert? Answer questions, earn points and help others
