Health & Beauty Logo
amirali damani jaffer Posted on Apr 14, 2014
I need a user manual for this product-- LED MOTION CLOCK>
Richard prairie
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Apr 16, 2014
Richard prairie
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
2640
Points
8
You should be able to retrieve one online from the manufactor.
Google the manufacture, select the type of product, model number
and type of service you are wanting ie; "Product user manual" etc.
ENJOY!
Can the PnP brand 30w motion sensor led floodlight be set to come on permanently
The specific capabilities and settings of the PnP brand 30W motion sensor LED floodlight may vary depending on the model and design. However, in general, motion sensor LED floodlights are typically designed to operate based on detected motion and have a preset duration for illumination after motion is detected.
If you would like the PnP 30W motion sensor LED floodlight to remain on permanently, overriding the motion sensor function, you can try the following steps:
1. Locate the settings: Check if the floodlight has any accessible settings or switches that allow you to adjust its operation. This could be located on the fixture itself or on a separate control module if provided.
2. Disable or bypass the motion sensor: Look for an option to disable or bypass the motion sensor function. This might involve flipping a switch, pressing a button sequence, or adjusting a specific setting. Consult the product manual or contact the manufacturer's customer support for guidance on how to accomplish this for your specific model.
3. Connect the floodlight to a separate power source: If disabling the motion sensor function is not possible or practical, you can consider connecting the floodlight to a separate power source that provides constant power. This could involve bypassing the original wiring or using a separate switch or power outlet that remains on continuously.
It's important to note that overriding the motion sensor function may affect the energy efficiency and intended purpose of the floodlight. Motion sensor lights are typically designed to conserve energy by only activating when motion is detected, providing illumination when needed. Keeping the light on permanently may result in increased energy consumption and reduced bulb lifespan.
Always refer to the product manual or consult the manufacturer's instructions for the specific model of the PnP 30W motion sensor LED floodlight to ensure you understand its features and limitations.
I need a user manual for my Samsung Galaxy ACE 3 GT-S7275Y
Samsung has the User's Manual on the product page: http://www.samsung.com/au/support/model/GT-S7275HKYTLP . Scroll down to the Downloads & Manuals section. The current link to the manual is http://org.downloadcenter.samsung.com/downloadfile/ContentsFile.aspx?CDSite=UNI_AU&CttFileID=5620248&CDCttType=UM&ModelType=N&ModelName=GT-S7275Y&VPath=UM/201401/20140121173943937/GT-S7275Y_UM_AUS_Jellybean_Eng_Rev.1.0_140120.pdf . (Note: you will need Adobe Reader or a similar product to read the manual.)
I hope this helps.
I need the instruction manual online. I think I find it only to be led somewhere elase.
Midland has many of their manuals on the product page or their support page, https://midlandusa.com/midland/support/ . For the WR300, see the Product Support tab here: https://midlandusa.com/product/wr-300/ . The direct link to the User's manual (in English) is http://midland-new.voltagekc.com/wp-content/uploads/2014/04/WR300-owners-manual-5-4-12.pdf . At least, this link worked for me. The Weather Radio Owner's Manual page gives a different link that also works: http://midlandusa.com/wp-content/uploads/2012/05/WR300-owners-manual-5-4-12.pdf .
I hope this helps.
1helpful
Need a user manual
philips.com has user manual and other info for this unit
I have a w100 tork timer and i would like to know how to repair it and how to position the time pointer.
How to position time pointer
Rotate disk counterclockwise until current time lines up with silver pointer
Place trippers on outer edge of dial > trippers are reversible so one side of tripper in ON > flip tripper over and it is OFF.
Disk rotates with passing time, trippers click lever ON and OFF at set times
How to repair W100:
If dial is not rotating, then clock motor is bad >> W100 uses 120V clock > check markings on clock. Internet shows Tork T101M and T201M clock motors, but unclear if either clock matches W100 timer.
If dial rotates but trippers do not turn Load on-off then buy P-69 trippers
If manual override turns Loan on-off then electric circuit is working
If manual override does not operate Load, then check electric circuit or Load (light bulbs burned out)
If manual override is sluggish or stuck, and doesn't click crisp and clean, then timer is worn out or needs to be cleaned.
Product Manual:
http://waterheatertimer.org/Tork-timers-and-manuals.html#W-series
Link above shows manuals
Manual for W100 does not show specific clock-motor model
To buy parts or another timer
P-69 trippers available on web
Tork T101M and T201M clock motors available on web but unclear if they match W100
http://www.weisd.com/store2/tork/torktimer1.php
Page above sell W-series time dial part #70159 for 72$.
Page does not include photo, so unclear if dial includes clock-motor, or if voltage is 120V
Tork accessories pdf shows part #70159 as dial for W, with no other information
Same seller shows new W100 sells for $148.
Replace Tork with Intermatic, buy T7401B
Website sells T7401B for $114
T7401B is 120V timer and has 120V clock motor
http://www.1000bulbs.com/product/3377/ELEC-T7401B.html
Manual for T7401B
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/t7401b%20-%20english.ashx
Service Pack problem
******************************************************************* VideoCam Suite 2.0 *******************************************************************
[Table of contents] 1. Notes about operating environment 2. Notes about operation
<><><> 1. Notes about operating environment <><><>
1. [Important] Adobe Acrobat(R) Reader 5.0 or later or Adobe(R) Reader(R) 7.0 or later is required to read the operation manual or the help information on your PC. Get the license for using the operation manual before reading it.
2. AC adapters are recommended when using a notebook PC or a HDD/SD video camera with the VideoCam Suite. If a battery pack is used to power the HDD/SD video camera or the notebook while recording or previewing motion pictures or still pictures, they may not be recorded, previewed, or copied to the PC Hard drive properly.
3. Standard configurations must be used for the fonts and screen settings for Windows(R). Depending on the settings, characters may not display properly.
4. It is impossible to use VideoCam Suite simultaneously with other motion picture editing software or video capture products. Note that this software may not function properly if software with a timer recording feature in the background is running.
5. This software will function properly only when the system time is set to a value within the following range. From 0:00 on January 1, 1970, to 23:59 on December 31, 2037 If the system time is set to a value outside the range listed above, the software may not start or function properly.
<><><> 2. Notes about operation <><><>
1. After installing/uninstalling the application, a dialog box is displayed notifying the user that the system needs to be restarted. Make sure to restart the system to complete the installation/uninstallation.
2. This software can handle only motion pictures and still pictures recorded by this software or the Panasonic video camera packed together with this software. This software cannot process motion pictures and still pictures recorded by any other video cameras, DVD recorders, software, commercial DVD video, or commercial BD video.
3. User privileges for this software - It can be used by only a user with administrative privileges for Windows(R) XP and Windows(R) 2000. - It cannot be used by the Guest users in Windows Vista(R)
4. While recording, if motion pictures cannot be recorded properly for any reason, follow the procedures described in the operation manual to restart the Windows system. Motion pictures may not be recorded properly if any other application software is used while recording the motion pictures. Close all other application software and any resident programs, such as virus scanning software. We recommend closing all other applications and resident programs, such as virus scanning programs, before starting this software. While recording motion pictures on a DVD disc/SD card do not execute the following operation since it may disturb proper recording and destroy the DVD disc/SD card. - Turn off or restart the PC or DVD/SD - Switch users or log-off - Change the screen settings - Use the power saving functions, such as the screen saver, sleep, standby, and pause. - Close this application by force
5. To record motion pictures on a DVD disc or an SD card, check that the motion pictures can be recorded properly. After checking that motion pictures are recorded properly, delete the original motion pictures from the PC Hard drive.
6. When the edited motion picture is output in MPEG-2 format, some scenes may not be generated completely in MPEG-2, and some parts of frames may be shifted or omitted.
7. When motion pictures are copied from a DVD-VR formatted DVD disc to the PC Hard drive, data other than motion pictures cannot be copied.
8. Do not modify or delete any files or folders related to this software. Otherwise, the software may not function properly.
9. This software can only process DVD-Video discs recorded by this software. This software cannot properly process DVD-Video discs recorded by any other DVD authoring software.
10. This software cannot process motion pictures or DVD discs/SD cards that are copyright protected.
- Microsoft(R) and Windows(R) are registered trademarks of Microsoft Corporation in the United States and other countries. - All names, company names, and product names used in this document are the trademarks or the registered trademarks of their respective companies.
3helpful
Changing text on Nexxtech LED Motion Clock
Here's the link to the instructions. Cheers!
http://download.orbyxelectronics.com/orbyx/6311450/manuals/manual.pdf
Top Health & Beauty Experts
Rob Hill
Rob Hill
ADMIN Andrew
ADMIN Andrew
ADMIN Eric
ADMIN Eric
Are you a Health and Beauty Expert? Answer questions, earn points and help others
