Question about HHP IT3800 Handheld
Remove last digit on a it3800
I want the barcode to be read in the system without the last digit of the barode, for all the barcodes types except CODE39. Like if the interleaved 2 of 5 code is 1234567890, the barcode should send to the computer the number 123456789, and so on for other barcode types.
5 Suggested Answers
SOURCE: problem with scanner
I have it connected to keyboard port as they instructed.
Posted on Sep 07, 2007
SOURCE: it3800 barcode scanner problems
Will it scan data into excel or word?
Posted on Aug 05, 2008
thesuperdude
  • 97 Answers
SOURCE: scanner beeps but doesn't enter data into system
Have you scanned the configuration barcodes on the manual? For example if you are using keyboard wedge cable, you will need to scan the keyboard wedge barcode from the manual. Page 20.
http://www.handheld.com/download.aspx?download=/data/ffdefe60-2c7a-423f-a204-ee2450b7c4d9.pdf&filename=IT3800PDF+Linear+Imager+PDF
Posted on Apr 02, 2009
rfmarinho_06
  • 8 Answers
SOURCE: I have an IT3800 scanner and use it in a gift
What you need is to turn on Digit Addenda for the types of barcode you are trying to scan. Here is the user's guide:
http://www.geoti.co.kr/DATA/hhp/IT3800_3900%20Users%20Guide.pdf
Please check page 7-30, where you will find the codes to turn on the supplements for EAN 13 barcodes (those with 13-digit). Also, if you don't want the scanner to insert a space between the main code and the additional digits, you have to turn off addenda separator (page 7-31)
There are similar configuration codes for other symbologies (like UPC A) throughout the manual.
Hope it helps!
best regards!
Rafael
Posted on Jan 28, 2012
You should try downloading the configuration manual from Honeywellaidc, it should probably be there still.
When you have the setup book, search for data transmision options.
Apr 14, 2014 | HHP IT3800 Handheld
I have an IT3800 scanner and use it in a gift shop. My products have "regular" barcodes, those with 5 digits added and ISBN barcodes. My scanner stopped scanning the extra 5 digits. I went to the IT3800...
Hope it helps!
best regards!
Rafael
Sep 01, 2010 | HHP IT3800 Handheld
How do I remove an 'A' from a barcode? The barcode we are scanning has an 'A' encoded in the front of it. We are trying to remove the 'A' from the string so only the numeric characters following it remain.
What format is the barcode?
You should be able to program the scanner to from a leading digit or specific digit. We did something very similar to this, but I don't remember if it was a Symbol or HHP scanner.
Manuals for this scanner. http://www.honeywellaidc.com/Site.aspx/na/en/support/technical_support/retired_products/retired/?product=251
Apr 03, 2010 | HHP IT3800 Handheld
I have a USB LS2208 using C39 fonts. When I scan a barode with a numeric check digit , it is transmitted. However if it has a alphabetic check digit , it does not transmit . How do I stop the numeric check...
Hello **** roche. You said you were using C39 fonts. Does that mean that you are making the barcodes yourself? If so, then you will want to begin and end all of your barcodes with an asterisk (*). This denotes a start/stop function in Code39 barcodes. Without it, the barcode will decode a check digit automatically. This only occurs when making the barcodes yourself as the human data (what you type in) and the input data (what the barcode actually contains) are identical. So, when typing out your barcodes, simply start and end the code with an asterisk. Like this: *ABC-123*. That should do it. If not, please feel free to send me a message or an email and I will be happy to help you further. I hope this solves your problem. Good luck!
Dec 08, 2009 | Symbol LS2208
Scanner beeps but doesn't enter data into system
Apr 02, 2009 | HHP IT3800 Handheld
HHP Handheld IT3800lr-12 - i can't configure it to USB
If you have the manual, try to cofigure it to USB Keyboard and/or to LAPTOP DIRECT CONNECT. This last option is on page 1-7 in the manual I have with me. Please let me know if it works... Good luck!
Dec 15, 2008 | HHP Hand Held Products IT3800LR-12 Barcode...
Ms9535 bt not reading barcodes.
I'm using the same Barcode reader, the Metrologic MS9535 VoyagerBT.
The brief humming noize is called a "Rasbery tone" in the manual. It means that the barcode reader is not configured to read that kind of barcode, a barcode Code if you will.
There are many types of barcodes so you have to go to the Metrologic Website and get the Barcode Configuration tool to configure your barcode reader to read the type of codes you will be using.
Alternatively there is a book with configuration barcodes you can scan to configure your barcode reader manually.
Sep 28, 2008 | Metrologic Instruments MS9535 VoyagerBT...
Bar code reader problem
In the user manual for this device there should be a code book (or code pages), These are a selection of barcodes which you use to configure the device. One of the settings is to omit the barcode header (which indicates a type of barcode for instance a PART number might begin with P or a Serial number might begin with an S) This barcode system may have been initially programmed to omit these code letters Gareth
Jul 04, 2007 | HHP IT3800 Handheld
It3800 barcode scanner problems
May 21, 2007 | HHP IT3800 Handheld
HHP IT3800 Handheld Logo
Top HHP Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Don A
Don A
Are you a HHP Computer and Internet Expert? Answer questions, earn points and help others
