Question about SanDisk Sansa e260 MP3 Player
Under a full charge the mp3 shows only 1/2 charge3d
I have a sansa 260, when I go to charge the battery, and after i fully cxharge the mp3, with my acx charger, the mp3 only shows that it is one half charged, how can i change the charge rating?
    President:
  • 563 Answers
I have over 10 years experience in electronic tech support.
How long is the charge lasting? If you're only getting half of the battery life you use to get, then the unit needs to be repaired. I can do more research into your model, but normally there isn't a way to change the battery charge display. Please let me know if you're still getting full battery life even though the display is only showing half.
I'll use the information you provide to assist you further. I look forward to hearing from you.
Posted on Jun 18, 2009
I recently bought sansa e270 and i am facing problem that i could not charge when it is connectd to the pc. Its showing just connectd, but no symbol of charging. whats the problem,what should i do to...
Hi
Check the Manual
User’s Guide
Hay Don't worry it will work
Note: Some low-power USB ports may not be able to provide enough
charge power. Also note that rechargeable batteries may
eventually need to be replaced as they have limited charge
cycles (which vary with use and settings).
Li-ion Battery
The Sansa e200 MP3 player comes with a replaceable and rechargeable
lithium ion battery. To use the player for the very first time, remember to
fully charge the Li-ion battery. You can charge your Sansa through the USB
port of your computer, a car adapter (not included) USB port, or AC adapter
(not included) USB port.
Please execute the following instructions for charging the battery using
an USB port.
1) Connect the smaller end of the USB cable into an available USB
port on the computer
2) Connect the larger end of the USB cable into the dock connector of
the player
3) The computer must be on for most USB ports to charge your
battery. Your Sansa will show connected and the yellow charging
indicator will appear. The battery level indicator will blink while
charging. You will not be able to play while connected to the
computer USB.
4) To stop recharging, disconnect the cable.
The battery can also be charged using an AC adapter (not included) or
a car adapter (not included) and you will be able to play your device
while charging with one of the adapters. The battery will reach
approximately 70% charge in 2.5 hours and full charge in about 3.5
hours. It is recommended that you fully charge your Sansa e200
before the first use.
Jan 04, 2010 | SanDisk Audio Players & Recorders
Sansa clip won't charge fully
If you have a phone charger with the same connector, plug in you Clip and leave it overnight. This will fully charge the battery. There is not enough power from the USB port.
Aug 08, 2009 | SanDisk Sansa Clip MP3 Player
Battery fully charged
thier is a pic of a batterty in the bottom right corner, it will be fully green when charged. otherwise it will be flashing.
Jun 11, 2009 | SanDisk Sansa Clip MP3 Player
First battery charge after purchase
I would charge the Fuze fully before first use, actually this is what is recommended. You'll know when it is finished, as you will get a full green battery icon displaying.
The players are not fully charged when first shipped.
Mar 26, 2009 | SanDisk Sansa Fuze MP3 Player
Cannot tell when sansa mp3 player is fully charged.
Make sure the hold switch is not engaged - it will interfere with the charging process. Here is a link to the full user's manual:
http://www.sandisk.com/sansa/assets/English/products/Clip/Clip_userguide_en.pdf
-Tha Mp3 Doctor
Dec 28, 2008 | SanDisk Sansa e260 MP3 Player
Sansa e 260
try to wait for it to be fully charged.... then unplug ur sansa from ur computer if it works already... because as i know some sansa are like that... if its recharging it'll totally turned off or locked....
Feb 28, 2008 | SanDisk Sansa e260 MP3 Player
My mp3
While connected to the computer, it uses the computer's power & the battery meter shows full. You need a new battery.
Jan 08, 2008 | SanDisk Sansa m240 MP3 Player
E260 4gb sansa not turning on
some may be due to low battery power or due to software problem...while charging stop once the charge gets full,...dont overcharge the battery,,,,,,the battery life gets reduced
Jan 03, 2008 | SanDisk Sansa e260 MP3 Player
Sansa c240 battery issue
Does it indicate that it is fully charged? If it does, I would return it or have it replaced. You have a 1 year warranty from SanDisk. SanDisk Technical Support 1-866-726-3475 If not, try using a different USB port on the computer, preferably one in the back. Best of Luck.
Sep 14, 2007 | Audio Players & Recorders
SanDisk Sansa e260 MP3 Player Logo
76 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
