Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
Our motor is making a loud noise
How can we fix ? Do we add oil or something ? There is no error message..
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Scholar:
  • 64 Answers
Hi Debra,
That sounds like barrings, so you will need to have a tech out to repair or you can remove the pump and take it to a local small motor repair shop which is sometimes less expensive.
Posted on Apr 14, 2014
  • The Cover Guy
    The Cover Guy Apr 14, 2014
    Hi Debra,
  • Scott Corey-reid Apr 14, 2014
    berringsare going, replace the motor and do a seal change at same time
I have an officejet 5610 all-in-one inkjet printer. There is an ornage exclamation mark next to the setup between the pound sign and the setup button that keeps blinking. How do I get it to quit. I...
The Exclamation mark is an Attention: error indicator. There is a problem that you need to fix. You need to fix the problem. Was there is any message on the LCD screen when you started having the error?
Press Cancel and try printing again since you apparently cleared the LCD message. The problem could be a paper jam, no paper in the paper tray (or the printer can't pick up the paper), an ink issue or something else.
Please add a comment with the error message for additional support. I need more information to tell you what steps are most likely to solve your problem.
Apr 19, 2012 | HP Officejet 5610v All-In-One InkJet...
Loud ticking noise coming from motor
This is probably tappet noise from the top end of the engine. However you should have it looked at quickly as these engines had a severe problem with oil sludging, even when recommended services were done.
This caused all sorts of problems, so see if you can get it fixed before the engine develops something terminal.
http://www.enginebuildermag.com/Article/66958/sludgy_saab_may_rattle_your_chain.aspx
Apr 13, 2012 | Saab 9 Cars & Trucks
NEW AC COMPRESSOR MAKING NOISE
Did you add the correct amount of oil to the compressor? Is it overcharged? Did you evacuate all the air with a vacuum pump before charging? Was the fixed orifice replaced? If you are sure you did the install right and the oil and charge are correct you have another defective compressor
Jan 25, 2012 | 2005 Chrysler Town & Country
Why is my central vac. making such a loud noise. It sounds like jet getting ready for take off. It seems to be getting louder. I'm not using it because i'm afraid it's going to explode or...
The bearing or the motor is warn out they last 15 years in the case. In some rare case the brush ware out or the rely can catch fire, most central vacuum are not made to be oiled! Hot oil will catch on fire. Best to unplug the vacuum unit call a few shops and ask replacement motor cost, if you remove the Vac and take to them it will cost less.
Jun 25, 2011 | Vacuums
My Canon iR 2020 Photocopier machine is giving me message - system eror E001. How do I reset the machine for that eror message to cease?
to reset the error:
Enter the service mode:
press asterix key ( add. functions ) "*"
press 2
press 8
With right arrow, go to CLEAR, press OK, with arrow choose ERR and OK.
Turn off and on.
If these doesn't helps, you need to replace fixing heater.
Jun 13, 2011 | Office Equipment & Supplies
Samsung rm255lash, evaporator fan motor on refrigerator side making loud noise. We took off the panels as best we could but it seemed like it was frozen on. When I open the fridge and hold down the light...
i quick fix would be to take a quart of oil and remove the fan motor and soak it in the oil. This wont hurt it anter a couple of min in the oil, hang up so that all the oil can drain off it, then wipe it down. install motor and try again, let me know.
Feb 21, 2011 | Samsung RM255LASH Side by Side...
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
I have a Cdillac Deville 98 northstar. Getting an Error message - Engine overjeat, Change Engine oil, Check Coolant level and later I get Idle engine message I changed engine oil and coolant recently -1500...
Whatever you do, NEVER allow this engine to overheat and always use the correct antifreeze (DEX COOL) or you will damage your heads severly. The heads were made from aluminum so there is a very serious warping issue on the 1998 Cadillac Northstar engines. There should have been a recall but wasnt, ended up costing me 3 thousand USD to fix the engine problems I had but she now runs fine. I only had the car 4 months before this happened so someone prior to me owning evidentaly let it overheat on too many occassions and I had no choice but to fix cause I was still paying on the car!! Good luck
Jul 12, 2010 | 1998 Cadillac DeVille
My cadillac catera is making a loud clicking noise in the motor and the fuel caplight turns on please help me
First, make sure the cap is on tight at the fuel tank.
Then, investigate the loud clicking noise in the engine.
Check engine oil level and add as necessary.
If this doesn't solve the problem repost your problem.
Jul 03, 2010 | Cars & Trucks
My sharp comfort touch air conditioner make loud noise from fan. It is very loud. I have 2 and both are very loud. I took the unit out of the wall to inspect, and could find nothing obstructing the fan.
Hi, you may want to check the bearings on the fan motor it self. They will wear or get dry and make very loud noises. Check the motor body at each end to see if this motor has oil caps at each end to add a few drops of oil. Some motors do and other motors have sealed bearings and when they go, there is not much you can do when they fail. If it does have a place to oil them, get the oiler at a hardware store. They come in a small plastic bottles that telescope to reach the bearings. This may take the noise away if the bearings are not already gone. Let me no what you find and we can go from there. I wish you the best,
Shastalaker7
Jun 19, 2010 | Sharp Comfort Touch AF-R120EX Air...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
168 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
