Question about Panasonic Lumix DMC-FZ18 Digital Camera
Faulty zoom operation
In one direction zoom works fine. In the other, zoom continues after I release the zoom button
  • Official Brand Answer
  • 350 Answers
This is normal. If you hold the zoom for an extended time the lens is slower than the indicated zoom. Forcing the lens to continue to its zoomed direction.
Posted on Apr 14, 2014
When puushing the buttons on x125 will not react try to set program can not page up or down can not get into programs it will not power down
Your system is a bit older and may be reaching the end of its life. PrI or to giving up hope try a hard restart.with the unit turned off press and hold both the zoom in and zoom out buttons.press and release the power button to turn the unit on while you continue to hold both zoom buttons release the zoom buttons when you see a prompt appear on the screen. If this has no effect repeat the process only holding in the zoom out and pages buttons. Lowrance flip flops back and forth on their button configuration for doing hard restarts and I can never keep them straight from unit to unit. Hope this helps.
Sep 25, 2014 | Lowrance X125
Shutter release inoperative
The "button" is actually just a plastic extension for the actual switch on the printed circuit board. You will have to dismantle the camera to gain access to the board and then use a DMM to test the switch contacts.
Oct 04, 2007 | Olympus Camedia C-4000 Zoom Digital Camera
Lumix DMC-ZS19 system error focus
Here's a fix I got from Panasonic, I figured I would post this since I haven't seen this anywhere on the web and this post was the highest hit on google
Based on the information that you have provided, we suggest that you perform the following operation:
1. Turn off the camera 2. While off, turn the zoom button fully to the left or right (hold for about 3-5 secs) 3. Release then turn the camera back on... At this point in time the lens should retract. If it does not, repeat the previous steps however, press the zoom to the opposite direction than you did the first time around. If this does not resolve the issue, we recommend the product be sent to our Customer Service Center.
This seems to work for me. The lens retracted back in place and my camera resumed working.
Sep 16, 2012 | Panasonic Lumix DMC-FS15 Digital Camera
Will a nikon n2000 turn on without a lens and film?
The camera should operate perfectly fine without a lens. It should also operate perfectly fine without film (other than for not taking any pictures, of course).
I know this is stupid, but make sure the batteries are inserted in the proper direction. Then make sure the film advance mode selector around the shutter release button is not in the "L" position. L is for Lock, S is for single-frame, and C is for continuous.
If you need a manual you may download a copy here.
Apr 27, 2012 | Nikon N2000 35mm SLR Camera
My Samsung 5x ES30 Zoom Did Not Operate Normaly
Ensure you're using new batteries and try again.
Apr 02, 2012 | Samsung ES30 Digital Camera
It appears that the image on the screen is zoomed in, but I can't figure out how to "undo" that. Thank you!
If the image on screen is zoomed both in vertical and horizontal direction, your TVs power regulator inside it is faulty. [Overvoltage]. If it is zoomed in vertical direction only, that is only the height of the picture is zoomed, you can adjust it with the remote control button directly on going through menu and get in to the function menu. Normally all TV remote has a special button marked as "Zoom" which on pressing it once the picture get zoomed, again another press the picture gets wide and again an another press picture will come to normal mode. You should select normal mode to retify the problem.
Oct 16, 2010 | Panasonic CT-27SL14 27" TV
Buttons won't work
Either this is the all to common firmware problem that requires an update. The company will do this for $50
or
It is a bad capacitor or button.
Aug 07, 2009 | Olympus FE-230 Digital Camera
Opteka RC-4 Remote Control
Hi guys,
S (shutter release), and 2S (2 Second delayed shutter), are the only
operative buttons for an DSLR. The S (shoot), W+T (zoom control), are for select powershot point-and-shoot cameras.
Thanks,
Buzz
Apr 18, 2009 | Cameras
With fully charged battery 5D has power but will not take shots
This sounds like your release switch is faulty. I have repaired several of these 5D cameras with similar strange symptoms. Basically what happens is the first switch on you release assembly cracks and breaks thus making continuous contact. When this happens it basically locks up your camera. The solution is to replace the release switch assembly. The repair should not cost you more than $150.
Hope this helps.
Wes Kauffman
Jan 05, 2009 | Canon EOS-5D 12.8 Megapixel SLR Digital...
How does zoom work
well, this is pretty simple - find the "zoom" button push it & look thru camera at same time. As for finding the details about your camera, simply visit the manufactures website or just google the brand & you'll find info & instructions that way.
Jun 23, 2007 | Vivitar ViviCam 5100 Digital Camera
Panasonic Lumix DMC-FZ18 Digital Camera Logo
164 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
