Question about Apple HP DeskJet 840c InkJet Printer
Service manual the green and orange lights will not stop flashing. I have changed the ink cartridges, disconnected the power and USB, reconnect them again and still lights flash and will not print. Please help
  • jaime
    jaime Apr 17, 2014
    The green light and the two orange lights are flashing continuously and it does not matter if I unplug the printer or clean the heads of the printer cartridges they will not stop flashing and therefore cannot print. I don't know what else to do to fix this problem.
  • jaime
    jaime Apr 17, 2014
    I cleaned the printer and cartridges heads, disconnected the power and the green and two orange lights are still flashing continuously and cannot print anything. I don't know what else to do to resolve this problem.
  • 3 Answers
The ink well in the printer looks like it
has packed up this happend to me
had to get a new printer
Posted on Oct 10, 2014
SOURCE: epson c48 printer
je cherche de epsan c48 merci
Posted on Mar 21, 2009
  • 700 Answers
Reset your counter back to zero. But for some you must also check the waste bin status. Need disassembling this is to ensure ink will not overflow from your printer.
Reseting is only software base. Try this link
http://www.fixya.com/support/t1837800-step_step_use_resetter_software
Post again if you cannot still got it.
Posted on May 31, 2009
pineworks
  • 4041 Answers
SOURCE: HP Deskjet 970cxi wont print
Hi You can Try 2 things.
It could be a ERROR 5100 means that there is some foreign object blocking your cartridges carriage that disables it from moving. Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there
Next try.
It may be a piece of paper or a scotch tape or a staple wire.
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 09, 2010
SOURCE: both green and red light flashing unable to get
How to reset counter on my Epson C-62 Printer I cleaned the Pads
Posted on Oct 30, 2010
nonontech
  • 4737 Answers
SOURCE: THE PRINTER DOES NOT PRINT.
If you can't move the carriage to the center manually, I would suggest you to dismantle the machine and check for broken or obstruction. But first of all, try moving it manually, pull it while you shake it gently. If it could be moved to the center somehow, then Turn back on the machine and check again. Try changing the cartridges or clean the contacts. If the problem persists, I will also recommend you to go for a new machine (if you wish to do) and the model you've mentioned "Epson Stylus NX305 All-in-One Printer" is 100% compatible with your Mac (It supports PowerPc OSx 10.3.9 to 105.x) [Click here for more info].
*Sometimes repairing the machine or replacing cartridges would cost more than the Printer's price which isn't recommended.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Nov 24, 2010
Printer is flashing an alarm and showing a message of "E" and "2"...what does that mean?
Hi-
This is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Steps:
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Hope this helps!
Good Luck!
Mar 21, 2011 | Canon PIXMA MP150 All-In-One InkJet...
I am trying to print and my Canon MP160 is flashing 2 and E. I cannot print what can I do
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
YOU CAN TRY THIS:
Methode 1
button pressing
procedures below.
procedures below.
Hope this helps,
Good Luck
Mar 11, 2011 | Canon PIXMA MP160 All-In-One InkJet...
The screen on the printer is flashing e then 3 then 0. I have unplugged the printer, unconnected the cable then started it all back up but it keeps flashing that
If it is a Canon printer:
Clear the EEPROM
service mode. (Waiting for menu selection)
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
button pressing
procedures below.
procedures below.
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E8 Waste ink absorber full, or platen waste ink absorber full
Direct Printing
E22 Carriage error
E29 EEPROM error
E35 15 USB Host VBUD over current error - USB
Nov 16, 2010 | Office Equipment & Supplies
Flashing Red & Green lights - Samsung ML 2510
Hi
It maybe one of the fuse gone.
You have to change the fuse:
The fuse is 250mAh and 3/4" inch long (20 mm) round glass with metal ends. The electrical contacts are not in the cartridge but inside the printer: There is a plastic fuse holder on the cartridge, even the starter cartridge. You just simply pop it into the holder. This will stop the flashing red LED and the system tray will say the cartridge is full.
Oct 09, 2009 | Samsung ML 2010 Laser Printer
E3 flashes when turned on
hi,
CANON PIXMA MP160 All-In-One InkJet Printer
has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.canon.com/printer/prob676ijt65/solution
prito-i-1
Feb 22, 2009 | Canon PIXMA MP160 All-In-One InkJet...
Canon PIXMA MP150 with E3 Flashing.
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
button pressing
procedures below.
procedures below.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Feb 11, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Canon Pixma Mp150 keeps having E2 flash
Clear the EEPROM:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
button pressing
procedures below.
procedures below.
Thanks, Joe
Dec 20, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canon pixma mp160 flashing E2
Found this on our site:
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
full
Direct Printing
E22 Carriage error
E29 EEPROM error
try this method:
button pressing
procedures below.
procedures below.
Thanks, Joe
Nov 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Canon MP 160 flashing 2E
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
Direct Printing
E22 Carriage error
E29 EEPROM error
try this method
button pressing
procedures below.
procedures below.
Thanks, Joe
Nov 22, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Orange LED blinks 5 times then a 2 second green
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=257&modelid=10239
If you type in 'flashing power light' in the problem box, for 5 you get print head failure, often it means the connectors between cartridge and print carriage are dirty, can be cleaned with a pencil eraser and a soft cloth. there is a sequence of checks and repairs to follow on the canon service page
Sep 02, 2008 | Canon PIXMA iP4000R InkJet Printer
Apple HP DeskJet 840c InkJet Printer Logo
51 people viewed this question
Top Apple Office Equipment & Supplies Experts
jasbo
jasbo
Abdul Mannan
Abdul Mannan
k24674
Are you an Apple Office Equipment and Supply Expert? Answer questions, earn points and help others
