Question about Radio Communications
What causes the problem on a MOTOROLA GP-2000 portable radio having a continuous hissing sound from speaker with constant green LED on. Squelch setting is at SQL 3.
SQL set at 3, no amount of re-setting the squelch level can remove the hissing sound and the green LED which is always on.
  • 5 Answers
SOURCE: How to set squelch on a motorola t73xta7ta7bk 2 way radio
That is a Maratrac, the squelch is adjustable thru a variable resistor on the audio/squelch board within the chassis. It is labeled R1132 SQUELCH, and is located very close to the locking handle. Some models have a metal bracket that holds the interface board, (thats the only board in the chassis that is mounted vertically), if you remove this bracket you can see R1132 alot easier, but do not need to remove the bracket to adjust R1132. Clockwise tightens the squelch. One catch though, for this adjustment to work, the radio must have been programmed with the unmuting/muting setting in the RSS, set to And/Or. It comes from the factory set for Std/Std. And in my 15+ years in the business, I have seen only one programmer that changes this setting. Me. Good Luck.
Posted on Feb 26, 2008
  • 10 Answers
SOURCE: Hissing Sound in Creative SBS 560 5.1 Speakers
Have you check to see if you have the correct driver for the sound card. I know for fact that when reload some mother board that have a build in sound card that carries AC97 drivers it will install or download the AC97 driver with no problem,and no error and it will not work because the driver needs to be upgrade. You might need to get a new sound card. simple and done. Or go through the trouble to find the correct AC97 driver.
good luck
Posted on Jun 19, 2008
experttv
  • 203 Answers
SOURCE: Can't power up
The buzzing noise you are hearing is most likely the ballast fire, this is good. You most likely have a bad lamp which is the best case for you. I would recommend pulling the lamp out and looking at it to see if its physically shattered or not.
The instructions for pulling the lamp can be found in your owners manual. If you do not have this anymore just look on the sides or the back of the tv for a small door with a screw or 2 in it. take those screws out and the door should come off, then take the screw(s) out of the lamp and pull it out. if you see glass rolling around inside you will need a new lamp. Let me know and I will help you find a good one at a good price.
Tim Nolan
Posted on Sep 12, 2008
eradiostore
  • 1654 Answers
SOURCE: RPL & TPL tones used in T-5720
The T5720 user manual does not list the TPL codes possible in the radio. However, they are the standard list, with zero being "open squelch" (no code). Here is a link to a Motorola manual which has a list of the PL codes in order on page 43. http://www.thekidshuttle.com/ABC%20Docs/CP100_Manual.pdf
On the T5720, another item to what for is the Qt noise filter. Be certain to set it to zero unless using the T5720 with others of the same model. It can also block transmissions. Here is a link to a user manual for the T5720 http://lib.store.yahoo.net/lib/starbattery/T56XXusersguide.pdf
Posted on Sep 22, 2008
eradiostore
  • 1654 Answers
SOURCE: MOTOROLA RADIUS GP900
Unprogrammed channels will have a constant tone. It is possible your radio is unprogrammed. A dead battery tone is only for a moment, and is usually a medium tone then a low tone, sounding somewhat like beeedeeep.
Posted on Dec 08, 2008
Why static on motorola CLS 1110?
Are you referring to static (random snapping, crackling, popping) that only occurs when you are handling the radio, or a steady hissing sound when turned on? The first may indicate the radio has a defect or loose internal connection; the second is reduced by adjusting the squelch setting. More information is always helpful.
Aug 01, 2014 | Motorola CLS 1110 (1 Channel) 2-Way Radio
MOTOROLA GP-2000
Have you tried a new battery?
Apr 14, 2014 | Motorola Radio Communications
Try to recharge your batteries or replace them!!!Please tell me what you did, if there was a solution by this...then I will review your problem...thnx
Apr 14, 2014 | Radio Communications
Continuous green light at GP-2000 and hissing sound from speaker
Have you adjusted squelch threshold. Green light indicated signal received with noise, squelch will adjust the threshold so light goes off except when a stronger signal is detected.
Uh076sx busy all the time
Have you tried setting the squelch control something other than the minimum level? When you say "busy", are you actually hearing other stations, or just the hiss of an idle channel?
Jan 20, 2014 | Radio Communications
When I turn my cobra 29wxst on, I hear chatter (ppl talking) for a split second then nothing. When i key up, nothing, no swing or anything. However, i get weather. All the basics are covered, coax, ant,...
You've probably already done this, but make sure all the basic settings are correct. CB-PA switch is in CB mode, Squelch is turned to the left, RF Gain is turned to the right, etc. After all that, and you still have nothing, I would try using another microphone. If you have a spare mic or a friend with a spare mic, borrow it. Just make sure its wired the same as yours is. (If it's a cobra 4-pin, it most likely will work.)
Now if that doesn't fix it, then the most likely problem is in the MIC/AUDIO circuit. You'll need someone with experience to replace the necessary parts.
In radio troubleshooting, always start with the basics:
Correct Connections
Proper input Voltage (Power)
Correct Settings (Vol, Sql, RF-G, etc)
Antenna (properly matched)
I hope this helps a little...
Mar 20, 2013 | Radio Communications
It is a Sony model ES48SN1 rear projection When turned on the set hisses for few seconds and then stops. The LED flashes Green-Green-Red continusly. The screen does not do anything
Hello, hope you are well. First, you have displayed the wrong number for the model. It starts with KP. Anyway if you hear a hiss, that is usually an indication of a high voltage leak. If your set has 3 tubes probably one of them is broken. Does it have 3 tubes?
Dec 19, 2011 | Televison & Video
How can i hear what they are saying without that awful loud sound when they arent saying anything. cause when i turn the volume down i cant hear what they are saying
Turn up your SQUELCH button when no one is talking until the static noise just goes away.
Now your set will remain quiet until someone talks.
If you set the squelch too high it will also cut out the people talking, so always try to have it set just slightly above the background static level.
Good luck.
Apr 15, 2011 | Uniden BC350C Base Scanner
Radio Communications Logo
94 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
