Question about GE Computers & Internet
Tengo un teclado ge67976 pero al colocarlo me dice la pc no reconocer controladores
ThaMp3Doctor
  • 8596 Answers
SOURCE: no funciona mi mp3 Philips GoGear SA178
Go to: (Va a:)
www.usasupport.philips.com - click on Espanol
Enter your model number (Entra su numero de modelo)
On the next page, click on your exact model number without the "B" on the end
On the next page, click on "User's Manuals" - look for "Repair"
En Ingles:
Make sure you back up all songs on the GoGear before attempting this solution.
1) Back up all files on the GoGear
2) Open up Philips Device Manager (Start --> All Programs --> Philips)
3) Click on the Repair Tab, and look for a msg that says connect the player while holding the volume + button
4) Disconnect the GoGear from the computer and turn the GoGear off - hold in the volume + button and continue to hold it as you reconnect the GoGear to the computer; after holding the volume + button for up to 20 or 30 seconds, a window will open up saying that your device is being repaired (now you can let go of the volume + button); after the repair is successfully complete, your GoGear will be good as new
Now you can do the firmware upgrade that will prevent this problem from occuring in the future. Open up Philips Device Manager and click the Update tab. This problem was caused because most GoGear's were designed for Windows XP with Media Player 10 (which is no longer the latest standard).
-Tha Mp3 Doctor
Posted on Feb 11, 2008
SOURCE: Disco duro serial ata
Hola VooDooNOFX
Gracias por la ayuda
No estoy configurando los dos discos duros apartes ni haciendo raid a los dos juntos.
El D.D. de 80 gb IDE ya esta parcicionado y formateado (40 c/u, FAT32), tiene windows xp sp3. Uso teclado PS2.
En el D.D. 250 gb serial ata quiero particionarlo en cuatro partes e instalar windows vista, las otras tres particiones para datos.
Voy a hacer esto: Desconecto el D.D. 80 gb IDE y dejo solo instalado el D.D. serial ata de 250 gb para partionarlo y formatearlo con windows vista; primero sin desactivar la función de raid en la bios y luego desactivandola; que opina.
Posted on Sep 18, 2008
SOURCE: Error al instalar driver de scanner HP Deskjet F380
hi dear
i need ho deskjet f380 All in one
thanks
Posted on Sep 23, 2008
SOURCE: Problema en el ps2
Amigo, creo que solamente se dasabilita eso por el jumper, pero la pregunta es, el board sin teclado conectado funciona, o sea despierta, si es asi, conecta el teclado USB cuando la maquina este funcionando, con el sistema operativo (windows, linux, o el que sea) , si no arranca, puede ser problemas de memoria, prueba cambiarlas y me dices, un saludo Marlon de la Rosa
Posted on Jul 23, 2009
SOURCE: YA INSTALE LOS CONTROLADORES DE LA CAMARA
my web cam not working
Posted on Jan 20, 2010
Tengo un p9000t pero al iniciaqr DVD, TV o simplemente encenderlo aparesce una imagen que dice warning pleasa stop wacht video player en momentos trasmite el canal y el video pero posterior presenta...
Hola buen dia, mira tengo un stereo con pantalla marca planet audio, modelo P9762T. El probleme es que no funciona el touch y el control igual se descompuso, y no encuentro ni el control ni kien me lo arregle del toach, ayuda x favor saben kien lo puede arreglar y en cuanto saldria o ya de minimo el control. Gracias de antemano y saludos
Jul 02, 2011 | Planet Audio P9745B / P9740 Car Video...
Tengo uno de 1 gb pero mi pc la reconoce pero no sale en mi pc. como la cargo? , como le paso archivos?
1) Por favor fije su pregunta bajo computadoras. Y luego corrija al experto ver? la pregunta.
2) Tambi?n use a traductor Google.
http://translate.google.com/#
Feb 14, 2011 | Garden
Tengo un problema con mi lavadora whirlpool duet cuando la enciendo para lavar me presenta un fallo en la pantalla. y sale fallo 22.que es el swich de la tapa.pero se lo cambie por uno nuebo y sigue...
ke tal tengo una lavadora whilpool duet pero al encenderla y poner el ciclo de lavado normal me prtecenta una falla dice falla 11 y no se que es esta falla me podria orientar?
elrayo_0609@hotmail.com gracias
Feb 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
No reconoce la placa de tv
Windows 7 aun tiene algunos problemas con la compatibilidad de controladores, lo mas seguro es que tengas que esperar a que el fabricante de esa placa actualize el controlador pra win 7, que no creo que tarde mucho o la otra opcipon es regresar a vista o xp
Jul 28, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
Problema en el ps2
Feb 01, 2009 | AOpen MX4LS (91.88Q10.001) Motherboard
Hola VooDooNOFX
Sep 16, 2008 | MSI Microstar KT6 Delta (MS-6590)...
Necesito todos los drivers asignados para el Acer TravelMate 3010 (3012WTMi)
https://www.acer.com/ac/en/US/content/support for drivers and support
Mar 07, 2017 | Acer Cameras
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
Top GE Computers & Internet Experts
micky dee
mukhtar21 shaikh
mukhtar21 shaikh
Ricky Ostrom
Ricky Ostrom
Are you a GE Computer and Internet Expert? Answer questions, earn points and help others
