Question about Amana Refrigerators
Spitting sputtering dispenser spits ans sputters air, then it will clear the air and water will come out with lots of pressure and will not stop coming out after releasing the button.
    Sergeant:
  • 230 Answers
Your water solenoid is sticking. It is drawing air back through it when off then the pressure of the water is keeping it open. I would replace the solenoid valve.
Posted on Apr 14, 2014
SolutionGuy
  • 331 Answers
SOURCE: Ice/water dispenser sticks
Something kinda frozen treat probably melted and worked it's way into you dispenser area... seen it before. That's where the "sticky" is coming from. UNPLUG THE FRIDGE! MAKE A NOTE OF HOW EVERYTHING COMES APART! Remove the drip tray (if any)and remove any screws you may find there. Now get a small flat blade screwdriver, and pry the fascia panel off the door from the BOTTOM FIRST (you may see notches under there for a screwdriver to fit into) and work your way around it gently until it comes off. Now remove the screws that are facing you to pull the control panel out. When it's out, it'll see be hooked up to the wiring harness. Look for a small brown micro-switch with either 2 or 3 terminals on it. The switch is brown, about an inch long and 3/8" thick... this is the culprit. From here you can do a couple of things. 1.) replace the sticky switch. 2.) Take the wires off of it and remove the switch completely. Then, using a moistened towel, clean it real well and let it dry completely. Then reinstall it and rebuild the dispenser area. Sounds tough, but it should take no more than 45 minutes to do.
Posted on Jul 30, 2007
SolutionGuy
  • 331 Answers
SOURCE: ice and water dispenser not working but light on constantly
CM, there are 2 things that'd cause this. One is inexpensive, the other is not. First, check the cheap one... That rectangular rubber piece in back of your dispenser area is only a cover for a cantilever device. When you push in on this with a cup, the cantilever swivels back toward you and makes contact with a micro-switch. This switch sends power to the integrated circuit board which, in turn, performs the function you requested (cubed, crushed, water). OK... unplug your fridge. Then use your ears to diagnose this. Push the actuator pad several times in and out and listen for the tell-tale "click click" of the micro-switch. If you hear it clicking, it's good. Plug your fridge back in. Now for the expensive part. If your micro-switch clicks, your dispenser control board is fried and needs to be replaced. (I'm afraid that this is the case because the board controls the light as well as all the other functions.) UNPLUG YOUR FRIDGE BEFORE REPAIRING! To gain access the board, use a small flat blade screwdriver and remove the fascia panel starting at the bottom first. Just begin prying it gently off. Then remove the screws that are holding the board assy in place and gently pull it out. Take note of all of the wiring so you can re-install it correctly. The board number you need is #61005274. Unfortunately, it lists for about $100. A professional repairman would charge you over $200 for the repair, so you're actually saving money here! BTW, we recommend using a Belkin Surge protector for all appliances that utilize electronic controls. (you wouldn't plug you computer directly into a wall outlet, would you?) We regularly use these... http://www.acehardwareoutlet.com/(a1q3xi45sxgfbzm0qejhei55)/ProductDetails.aspx?SKU=3115672
Posted on Aug 01, 2007
  • 87 Answers
SOURCE: Amana fridge water filter squealing
I would suggest that you put the new water filter back in and try dispensing water for about ten minutes. If there is still a high pitched noise then you could try bleeding the water line at different points along the water circuit (with control over the incoming supply). The fact that you are forcing water through the tank should normally resolve any air locks. The water filter could also be bled of air. Hope this is of some help.
Posted on Sep 06, 2007
SOURCE: RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Posted on Oct 26, 2007
  • 1073 Answers
SOURCE: scales floating in water
purge the water in the door for 3-4- mins. and replace the filter
Posted on May 16, 2008
Why does it continue to spit and sputter going uphill?
Spit and sputter can happen because of not enough fuel or air. last thing to check for fuel is the fuel pressure regulator. On the air side would be the the air filter(filthy) or catalytic converters(clogged). on the mechanical side, Could be bad rings, burnt valves. Compression test would find this.
Mar 07, 2016 | 2002 Chevrolet Silverado 1500
Spitting sputtering
Throttle position sensor, if it has one. Oxygen sensor if it has one or choke positioner.
Mar 02, 2014 | Honda Civic Cars & Trucks
Honda Shadow, spits and sputters
Put a spike air filter on my 06 honda shadow spirit 750cc and now it spits and sputters won't go past 35 with out spitting and sputtering
Jul 01, 2013 | Motorcycles
When advancing down highway vehecle spits and sputters then clears up then spits and sputters what is it
When was last tune up? Plugs, wires, all filters & fluids? Especially fuel filter. I'd start there and run a good fuel system cleaner through it.
Mar 15, 2011 | 1988 Ford Ranger
Refrigerators Logo
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
