Question about Dryers
Fan will not turn off when car is running
Start car fan comes in strength away and won't stiop running till turned off
  • 1,140 Answers
The temperature sensor/switch is stuck in the closed "on" position. You need to purchase and replace that defective part.
Posted on Jun 01, 2014
  • 420 Answers
SOURCE: Our attic fan hums every 10 minutes or so but the
The fan gets it's electricity from a fuse or breaker that probably also controls some other outlets or light sockets.
Posted on Jun 24, 2010
espressonist
  • 1711 Answers
SOURCE: I have a Casablanca Panama
There are different parts that might became bad and cause your problem like relay contact, starting capacitor, running capacitor. However all these parts are included in one unit the PCB printed circuit board or electronic board? So you need to replace this parts in attached link is also called RMM.
We have here below a link with service manual for the fan at which on the bottom you will find the parts diagram and parts list. You should try to confirm the part code for your model with Casablanca service department before confirmation of order.
Also please note that you will need a little experience with electronics before proceeding with above operation.
http://www.casablancafanrepair.com/HTMLFiles/do_it_yourself/InteliTouchCommonRep/ConversionKit.pdf
Posted on Oct 31, 2010
  • 3640 Answers
SOURCE: I have a remote controlled ceiling fan and light.
remove black box in fan , it is there to reduce the lighting wattage. remove watt governor and rewire lights directly. this should help.
Posted on Dec 12, 2010
  • 122 Answers
SOURCE: the fan sometimes turns itself
there must be loose wiring in switch or in the fan you will need to check the wiring at these two points they may spark and start a fire, if they are all tight your switch may be going bad this atleast is an easy fix, good luck
Posted on Aug 27, 2011
  • 36 Answers
SOURCE: the fan won't turn on at all.
Turn the fan to the on position and feel the motor casing. Is there any vibration at all? If not, refer to your operating manual to see if there's a fuse that can be replaced. Spare fuses are sometimes attached to the cord. Also try slightly spreading the 2 prongs that conduct electricity through the wall socket for good contact.
If you DO feel vibrating, try a maintenence cleaning and lubrication with either Graphite powder, 3 in 1 machine oil or WD40. I will take you through the steps:
1) unplug the fan
2) there will either be flip releases or notches to slightly pry loose the protective fan SCREEN blade housing. Pop this off and clean + dry it, set aside.
3) With fan blaeds exposed, look at the very center of the blades. There will be a large plastic nut that turns counter closkwise to release the fan blades. Do this, clean blades with warm soapy water. Rinse, dry and set aside.
Behind this will be another large plastic nut that releases the back side of the blade housing. This nut should turn closkwise this time. Again, clean, dry and set aside.
4) You should be down to the motor, stand and fan motor stem. Check for residue build up and clean with a Qtip. You can still remove the housing face and clean behind this if necessary. There will be several screws holding this on. Wiggle apart.
5) Lay fan on its back with the fan motor stem facing up toward the ceiling.
6) At the base of the stem, one small tap of one lubricant of your choise. No more than one quick shot WD40 or 2 drops 3 in 1 machine oil.
7) By hand, gently turn the motor stem closkwise to disburse lubricant. Wipe off any excess with a tissue.
Follow the reverse steps to reassemble. If you had latches on the face, line up the notches or the name on the face to be level at allignment. If you had to pry the face off with a flat blade screw driver, again line up the screen guard (face) and pop/squeaze it back together.
This maintence should be done twice per year to assure a long life! They are made to come apart for maintence so don't be afraid. Take pictures as you go for easy referrance. It relieves you of the tension of remembering what went where! Hope this was helpful!
Posted on Sep 22, 2011
Why my A/C condenser fan won t stop running, dodge ram 2008
To clarify, the compressor and fan will run in defrost mode. The compressor and fan runs to dry out the air blowing onto the windshield.
Now if the condenser fan runs in "heat" you may have a problem with the fan relay or the main controller.
Sep 25, 2014 | 2008 Dodge Ram Pickup 1500
Fan wont turn off and drains the battery
replace temperature sensor first ,but usually fans come on only when a car is over heating , maybe replace fan relays maybe sticking .
Mar 28, 2014 | 1998 Ford Taurus
My 99 mazda protege over heated and sprayed coolant all over, my first thought was leaky hose or blew the radiator, but I waited till day light to see if I could tell where it was coming from and nothing...
There are two fans on many cars, but one is for the radiator cooling fan and the other is an auxiliary fan which is energized when the air-conditioning is turned on. Try turning on your air-con and see if this fan comes on. Pressure test your system. You won't know if you have a coolant leak for certain until this has been performed.
Oct 31, 2012 | Mazda Cars & Trucks
No heat till you start driving and then fan will kick on and not shut off but it doesnt overheat
You won't get heat right away. The heat has to have time to reach the heater core. That's where you get the heat for the passenger compartment. But if the fan isn't turning off, then I would have it checked for an electrical problem.
May 05, 2012 | 1999 Dodge Caravan
My cooling fan does not turn on unless i unplug it from the temperature sensor i have replace that sensor 3 times and it still does not work
Does it come on when the AC is on?
Odd .
Fan won't come on till like 230 degrees.
Or run a small ground wire from the relay to a switch inside.
Jun 17, 2011 | 2001 Pontiac Grand Prix
MY 1998 SATURN DOESN'T SHUT OFF FOR 30 SECONDS WHEN U TURN ENGINE OFF HELP
One thing I can think of that will do that, is if some one wire your radiator elec. fan motor direct where it runs all the time, the fan motor will act like a alternator, where it will put voltage out to the ignition system, and till it stops spinning it will power the engine elec. system, one way to check is disconnect the cooling fan elec. plug (harness) and start the engine, if it turn off right away that your problem.
Jul 26, 2010 | 1998 Saturn SL
Car will not start, fan is draining battery I believe, not sure
boost vehicle but before you do that remove the fuse for the cooling fan till you get it to turn over once its running plug said fuse back in and get it to a shop to have them diagnose why the fan is on to long
Jun 02, 2010 | 2000 Volkswagen Beetle
1999 mercury sable ls air conditioning fan
see if you can turn the fan by hand with the car not running. if so chek the temp switch. unplug it and start car fan should start rite away. if not chek fuses.
Apr 25, 2010 | 1999 Mercury Sable
Dryers Logo
Top Dryers Experts
