Question about APC Electronics - Others
Please clarify my doubt in APC HI800sq is working fine with normal and battery mode, when mains on i checked the battery terminal with tester, the light is up and no shocking, but when in battery mode i cant touch the battery wires or battery lead, if i am touching the battery terminal i am getting shocking,
  • 169 Answers
SOURCE: My Touch Screen Buttons
the flexwire is the problem of your camera and if all wiring be cut the next problem is the lcd monitor would not turn on...go to a service center for replacing or repairing the flexwire...
Posted on Sep 01, 2007
  • 2920 Answers
SOURCE: when I screw cord to dryer it will shock when I touch
yes its normal,,,,you dont touch them after you hook it up they will shock you
Posted on Jan 26, 2009
Dr_Joseph
  • 86 Answers
SOURCE: mouse touch pad problem Lenovo Y410 model notebook
Just above my keyboard there is a little black strip with little lights.
they are control buttons and if you tap one of them it turns the touchpad off and on (so it's very easy to do accidentally).
 If you look really closely at the strip in good light (or restart the laptop to see them flash on and off) you'll see that one looks like a touchpad crossed out. Just press this to get your touchpad back.
If it doesnt solve the problem, I have noticed that the touchpad can be knocked out by a Window Update of something called ideacom. If you believe this could be the problem please clarify.
Posted on Jan 28, 2009
  • 86 Answers
SOURCE: no power after touching solenoid lead to neg battery terminal
Check all fuses and fusible links, most likely one blew when the lead touched
Posted on Apr 25, 2009
  • 33 Answers
SOURCE: Ground Wire is testing as hot
Assuming you are in the United States, the convention with 120 volt ac circuits is that the Black is HOT, the White Neutral, and Green is Ground. Assuming your tester is a neon type light suitable for 120 volt ac circuits, the tester will illuminate when the tester leads touch the black hot and the white neutral, and also when the tester leads touch the black hot and the green ground. the tester should not illuminate when the leads simultaneously touch the white neutral and the green ground. It appears from your description that Your circuit description is operating correctly.. Surprise? ... your tentative assertion "when I touch the black hot wire and the copper ground wire with the tester. This is should not happen, correct?" this assertion (YOURS) is wrong, rather, it would be correct for it to illuminate between the black hot and the green(you say bare copper) ground. It sounds to me, if you need to ask this question, "YOU SHOULD NOT BE FOOLING AROUND WITH LETHAL 120 VOLT HOUSE VOLTAGES AND CURRENTS" I strongly recommend you should hire a licenced electrician. Besides getting electrocuted, you could set fire to the HOUSE, and maybe not when you are looking but when you are asleep, or away from home. PLEASE BE FORWARNED. thank you. Regards --- GooseBay_Camper
Posted on Sep 28, 2009
How can output voltage be adjusted when on battery power?
1. check either it is overloaded or the batteries are weak . check battery voltage to
May 10, 2014 | APC 620VA/390W Input 230V/Output 230V...
Apc hi800sq
follow this steps and fix it. God bless you
Plug the battery backup into a working electrical outlet. If the battery backup turns on when the power button is pressed, then the problem may be that the previous electrical outlet is faulty. Proceed to step three. If the battery backup doesn't turn on, proceed to step two.
  • 2 Reset the circuit breaker on the battery backup. APC battery backups have a labeled circuit breaker button located on the unit near the phone line, fax line, USB, network and coaxial cable inputs. Press the button to reset the circuit breaker. Power on the battery backup by pressing the power button. If the battery backup powers on, proceed to step three. If the battery backup doesn't turn on, proceed to step six.
  • Read more: http://www.ehow.com/how_7266444_troubleshoot-apc-battery-backup.html#ixzz2lwOvPO75
  • 3 Determine if the battery backup is charged and providing battery power. With the battery backup on and plugged into a working electrical outlet, plug a computer monitor into one of the battery backup outlets labeled "battery backup plus surge protection" on the battery backup. (APC power supplies have some outlets that provide only surge protection while the other outlets provide surge protection plus battery backup.) Turn the monitor on. Unplug the battery backup power cord from the wall outlet. If the monitor remains on, the battery is holding a charge, supplying electrical power and the battery backup is working properly. If the monitor goes off, proceed to step four.
  • 4 Charge the battery. Plug the battery backup into an electrical outlet and allow the battery to charge for 16 hours. This will fully charge the battery.
  • 5 Test battery charge. Once the battery is fully charged, repeat step three. If the monitor stays on when power is interrupted to the battery backup, the issue is solved and the problem resulted from an incompletely charged battery. If the monitor turns off when power is interrupted, the battery within the battery backup is faulty and needs to be replaced.
  • 6 Replace the battery backup unit. The unit itself is faulty. If the battery backup is under warranty, contact APC to request a replacement.
  • Nov 28, 2013 | Computers & Internet
    Problem with a APC Back-UPS BR800I with AVR The
    Hi Petkov,
    It seems that Schneider / APC has a remedy for this on their forum:
    http://forums.apc.com/message/35667
    Reply or call if you need more assistance with this -- 407.380.9200
    Oct 08, 2013 | Computers & Internet
    Apc 10kva SUVT10KH4B4S problem after changing battery
    please you know your topology change battery
    Jul 22, 2013 | Computers & Internet
    APC SUVT 20 kVA power-up on batteries but not on mains
    Dear If UPS working on MAINs but just not wakeup on MAINs then only 3 capasitors need to change.. for further you can diractelly contact @ techdata41@gmail.com
    Nov 21, 2012 | APC Computers & Internet
    Apc xs800 new batteries
    I Bought two RBC32's and had to hook them up to the connector and did it wrong on the first try. Make sure you connect the yellow to the Red terminal on one battery and the Black on the other, then connet the remaining red to red on one and black to black to the other. Once I did that and plugged it back in everything worked fine.
    Apr 06, 2012 | APC BX800 Back-UPS XS 800 (APNBX800) UPS...
    I Have an 80KVA APC Symmetra PX and one of the power module is not working I already change position with other power module and still not working
    Hello
    Please clarify. If you change the suspected module position and the module is not working, then the problem is with the module. If you replaced a working module in the non working module position and it does not work then there is a problem with this particular slot. Normally you would replace the faulty module with a working one in its slot and things would be clearer. I do not understand well the way you describe the problem, however each module has a micro-switch on the side which activate the start up of the module. have a look at it. i hope this will help
    May 09, 2011 | APC Symmetra 12kVA Basic System...
    Common Failure mode of APC 500 UPS
    I would recommend replacing APC UPSs with ONEAC ONEPlus Power Conditioned UPSs, which have a perfect ground reference, longer lasting and more reliable batteries, and a 5 Year Warranty (2 Yrs on Batteries).
    www.gryphon-inc.com
    1-800-POWER-OK
    Dec 04, 2008 | APC (BH500NET) UPS System
    Receptacles wired backwards
    "Reverse polarity" is the term used to describe the condition where electrical wires are connected to the wrong terminals of a receptacle; it's a common condition that can be hazardous if the "hot" side of your electrical system gets connected to certain types of lamps or equipment. It's common because it's an easy mistake to make when hooking up wires and because receptacles work fine even when the polarity is reversed. You generally don't know the condition exists unless you look for it. If you think you're home's wiring is a bit haphazard or may contain some conditions of reverse polarity, it's a good idea to check for it. You can buy a simple circuit tester for less than $20. Just plug it into all duplex receptacles; test both the top and bottom. If you discover reverse polarity: 1) Shut off the circuit breaker that serves that receptacle (the tester's lights will go out). 2) Unscrew the cover plate from the receptacle, and use a voltage tester to be sure none of the wires in the electrical box are still "hot." 3) Unscrew or release the wires from the receptacle and re-fasten them to the proper terminals--white to the silver (neutral terminal and black to the brass hot terminal. The bare or green wire should connect to the green screw. 4) Put the cover plate back on, turn the circuit back on, and test the receptacle again. Note: If the tester indicates reverse polarity but the wires are hooked up to the proper terminals, call an electrician.
    Jan 18, 2006 | APC MasterSwitch Power Receptacle - Power...
    Electronics - Others Logo
    41 people viewed this question
    Top APC Electronics - Others Experts
    Are you an APC Electronics - Other Expert? Answer questions, earn points and help others
