Question about Panasonic Heating & Cooling
Turns off Hello I have a panasonic econavi split type ac . The ac doesn't turn on anymore and I don't know why it's really weird the remote works perfectly I could even use the remote in turning on the same type of ac in different rooms
    Sergeant:
  • 230 Answers
If it is not allowing the a/c to turn on I would check the infrared eye to make sure it is clear. Then make sure there is power to the unit. 24v and 120v. There may be a fuse on the 24v side, usually 2-5amp looks like a car fuse but may be a small glass fuse. Make sure there is power through it. If there are there and it is still not working sorry to say but your board is shot and will need to be replaced.
Posted on Apr 14, 2014
  • 19 Answers
SOURCE: Split system airconditioner Panasonic model CU-A28CKR.not responding to remote
some of the samsung units need to be reset if you have a new remote..contact your nearest agent for that aircon they will give you a code to type in using the remote control.if this does not work you might have to replace the internal pc board.good luck
Posted on Nov 25, 2007
bobotfel
  • 236 Answers
SOURCE: Our AC won't come back on after...
To OzAnday
If the light indicator of your unit have light with power "on", then there is a problem with the unit. May the fuse of your pcb is open or the pcb itself has a problem. You have to call a qualified technician to check.
To floscar
Reset the rest button of your remote control, but if it wont work may the remote itself has a problem or the receiver board.
Posted on Jan 02, 2008
SOURCE: Remote does not turn on or off the Split System Air Conditioner
take your cellphone and turn on the camera,then put the remote in front of the cell and push any button.if you see the light of the remote to the cell then the remote is ok and the problem is to the eye of the plate.its a small plate in front of the split
Posted on May 29, 2009
  • 81 Answers
SOURCE: LG split AC keeps displaying CO and wont't turn off with remote.
The "CO" indicates cleaning operation and can be switched of via remote button under flap, labelled AUTO CLEAN.
Mat
Posted on Jul 20, 2009
  • 13 Answers
SOURCE: ERROR CODE BLINKING,THE AIR CONDITIONER DOESNT WORK
it is happening due to blower motor not giving the signal to pcb pls check their is a return signal wire in blower motor is broken or motor is defective.
Posted on Jul 20, 2010
One year old Panasonic Split system only blowing air
The compressor may possibly still be working but has no more freon. Ths may be caused by a leak.
Nov 16, 2013 | Panasonic Single Split Wall Mounted Air...
Hitachi split ac ace cutout how to go to standby mode
Its very simple to remove that red light glowing on the AC, just switch-off your AC with your remote, but don't turn off the switch that resides with in the plug, remove filters wash gently and dry under shade and place them again in the AC, now keep it without turning-off the switch for 30-60minutes this is called stand by mode. Now take the remote open the panel and press the button that is situated in 4th row and 3rd column. By doing this the red light will be turned off and enjoy your AC.
Apr 17, 2012 | Heating & Cooling
Hi, I have a Daewoo air conditioner split (model dsb-070L/dsb-091L/dsb-070LH/dsb-091LH, I'm not sure about the exact model number). The remote is not working anymore, and I don't know why;...
Hi Josematamoro
Did you find a solution to your problem. I have the same problem and not sure what to do. I have contacted a airconditioning maintenance person who said he would try and look for the part to fix it.
Cheryl
Jul 31, 2011 | Heating & Cooling
Air conditioner doesn't run when I use the remote start
If your AC doesn't come on when you first start the car regularly, it shouldn't now unless they have done something I don't know of.
Jun 06, 2011 | Pontiac Grand Prix Cars & Trucks
The phone is suddenly behaving weirdly. sometimes the keys doesn't work sometimes sometimes the touchscreen doesn't sometimes it switches off on its own. how to repair it i don't know
hello there.. i think that's a phone problem that you yourself cannot fix. you need to go to a service center to let them check what's causing the problem.
but before you do, kindly answer the following questions i have for you:
1. did you recently download any types of application to your phone?
2. did you drop your phone?
May 19, 2011 | Samsung B3410 Cell Phone
Hello my problem is that my lg ac is not automatically starting when power comes back .please tell me solution how ac can turns on after electricity comes back .thanks
Unfortunately there is no way to make it come on after the power outage without physically pushing the "on" button on the remote or the indoor unit.
It is a big problem with many on the split type A/C units.
heatman101
Apr 30, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Air conditioning unit remote control problem
when something is broke you can never break it worse so dig in and look for a stuck button or broken piece of plastic lodged in between the buttons or
you may want to go to: harmony web site and see if your model of a/c is supported these remotes are rather expensive us$129-$499 but much less than replacing the A/C and can control 225,000 devices made by 5000 different manufacturers just about any device under the sun. on the website under device choose home automation then climate control your brand then model number to see if your A/C is there. If you decide to go this route I would reccomend to check all the other devices you have also.
Apr 14, 2008 | Heating & Cooling
Try turning of the power to the unit.Wait 60 seconds and try it again.This may reset the unit.
Nov 24, 2007 | Heating & Cooling
Panasonic DMR-ES20
For the remote to work, make sure "video" is selected (instead of "tv"). It's the little button on the remote under the red button at the top that turns on the TV ("TV/Video")
As for the split screen, I've had that happen numerous times (when I lose power or revert to default settings). YOu have to go to Setup, Display, and select 4:3.
I hope I have helped you. I'm having other problems - with the audio. Some channels have no audio (maybe 3 or 4) and 2 channels are in SPANISH!!! (??) Weird that it's not uniform. I even tried reverting to default settings (and got that split screen!), but didn't help. It "jumped" a few times to the input type screen. I'm thinking some chip got fried or something. I've had it almost 2 years, and guess that's the "built-in" obsolescence!! :-)
Sep 26, 2007 | Panasonic DMR-ES20EG DVD Recorder
Heating & Cooling Logo
160 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
