Question about Speed Queen Dryers
Model ne3513w Instructions to replace heater element
    Problem Solver:
  • 15 Answers
Most element are in the rear ,inside the dryer,make sure it is unplugged from the power ,remove the back,most are on the right rear,look at the vent exit in the back,it is an oblong looking tube,the element is inside this box on most,remove the screws,the element will be burnt in the lines running thru in a spot or 2,best I always found was to take it to the dealer,along with the make and model of the dryer,take notes or pictures of all of this as you take it apart,to make sure putting it back goes easy and correct.
Posted on Apr 14, 2014
Water heater blinks 7 times. I don't get any hot water. Model # is MITW4056FBN
Hope this helps..I have also attached a link that may be useful.
No Hot Water
REASON REMEDY No power Check fuses or circuit breaker, replace or reset. Check with utility if necessary Wrong wiring connections at heater terminal Correct according to manufacturer's instructions Leaks around heating elements (1) Tighten element (2) If necessary, clean and replace with new gasket Loose wiring connection Locate loose connections. Clean carefully (remove all oxidation). Reconnect properly Lightning Inspect: (1) fuse (or circuit breaker). (2) Heater elements, and (3) thermostat, replace if necessary, see "grounding instructions" below High voltage Check utility for correction Short Locate short circuit and correct Wrong piping connections Reconnect pipes to proper fittings according to manufacturer's instructions Undersize service wiring Check with utility co. or electrician Improper calibration Replace thermostat Faulty thermostat Replace Faulty thermal cutout Replace Open thermal cutout Reset Top heating element burned out Replace
http://www.bradfordwhite.com/sites/default/files/product_literature/48494-A.pdf
Jan 13, 2018 | Water Water Heaters
What does code h1 indicate?
H1 ie a HEATER fault, which usually occurs after the fill and just as the machine is about to start heating the water, when your machine detects that the heater has gone "open circuit" . This is probably a failed heating element(There is a break in the wire inside the element) . I can't be specific because you don't mention the model number, but washing machine heater elements are usually available on eBay or from your local white goods supplier fairly cheaply (You will need a model umber to make sure you get the correct one). Replacement is not too difficuly. There are many many YouTube videos available with instructions
Sep 25, 2015 | Samsung Washing Machines
How to fix a heater zwg 7120p
You will have to purchase the heating element which for your model might look something like the one shown on this site.
Washing Machine Heating Element with Sensor
The instructions to replace this should come with it.
If not then try to download instructions from here which is usually similar for most European front loaders like yours.
How to replace washing machine element front mounted in Bosch washer
Sep 02, 2014 | Zanussi Washing Machines
Start shut down
follow this steps and use the Voltmeter, and fix it. God bless you
oubleshoot a thermostat:
  1. Shut off power to the heater at the electric panel and post a sign warning others not to turn it on.
  2. Unscrew and remove the electric water heater access panel.
  3. Using a small screwdriver, turn the thermostat dial counterclockwise to lower the temperature, or clockwise to raise it. If the water heater doesn't maintain the proper temperature, test the thermostat.
  4. Disconnect one wire to the upper thermostat to test it. Set a multimeter to RX1 (resistance times 1) and touch a probe to the thermostat terminals as indicated in the owner's manual. Depending on the model and the terminals tested, the tester should show infinity ( open) or about 0 ( closed).
  5. Test the lower thermostat in the same manner.
  6. If necessary, replace the thermostat. Unscrew it from its mounting and install one of the same model, size, and rating. Once you install it, adjust the thermostat following instructions in your owner's manual.
Test and replace a heating element:
  1. Turn off power at the electric panel and post a sign warning others not to turn it on.
  2. Remove the access panel on the electric water heater.
  3. Disconnect one of the element wires and set a multimeter to RX1000 (resistance times 1,000). Touch one probe to an element mounting bolt and the other to each element terminal screw, in turn. If the tester displays anything but infinity ( open circuit), replace the element.
  4. If necessary, set the multimeter to RX1 and touch the probes to the terminal screws. If there is any resistance reading at all ( closed circuit), then the element is good. If not, replace it. Both upper and lower elements are tested in the same manner.
  5. To remove the element, first drain the heater.
  6. Disconnect the remaining element wire. Remove the mounting bolts holding the element in place. Remove the element.
  7. Replace the heating element with one of the same model, shape, and rating. Make sure you also replace any installation gaskets.
Test and replace a high-limit cutoff:
  1. Disconnect power to the heater at the electric panel and post a sign warning others not to turn it on.
  2. Remove the upper access panel and push the reset button.
  3. Replace the access panel and turn the power back on. If the water is hot, the reset was the problem. If not, you'll need to turn the power off again and reopen the access panel.
  4. Use a multimeter to test the cutoff terminals for continuity. If faulty, replace with an exact replacement part.
Some elements is in Short circuit, test the procedure before
Oct 09, 2013 | Water Heaters
4 blinks / high temperature shutdown
some elemente is in short circuit. test the follow steps and fix it. God bless you
Oct 09, 2013 | Reliance Water Heaters
No hot water volume at shower until power is turned off and on to unit
follow this steps and fix it. God bless you
Oct 08, 2013 | Noritz 6.3 Gallon Residential Tankless...
I NEED TO REPLACE THE ELEMENTS ON A AO SMITH MODEL EES 52 917 ARE THEY SCREW IN OR BOLT IN
1) Copy following link to identify element type, and see step-by-step instructions:
http://waterheatertimer.org/How-to-replace-water-heater-element.html
2) Almost all elements today are screw-in type instead of bolt-in.
Literature shows EE series is standard 1-1/2" screw-in ... assuming your model matches literature.
3) Buy generic element from local hardware.
If elements burn out frequently, then install lower wattage.
Feb 04, 2013 | Water Heaters
I need a new bottom element
Elements are available at local hardware.
Look at label on side of tank for wattage.
Typical element is 4500 watts.
Open following link for instructions how to replace element:
Jun 24, 2012 | Rheem Water Heaters
I replaced the heating elements(2) and switiches(2) on my Rudd electric hot water heater. Model PES 40-2. The switghes came with several wiring diagrams.(universal) Can I get a diagram specific to my...
Residential water heaters USUALLY follow same diagram unless water heater is wired for other purpose. Multiple diagrams on instructions show available options. Take photo of wiring before removing wires on any electrical device.
Upper element.
Black wire from top of heater connects to #1 top left screw.
Red wire from top connects to #3 top right screw.
Blue wire from upper element connects to #4 middle screw on right side
Red wire from lower element connects to #4 middle screw on right side
Yellow wire from upper element connects to #2 lower left screw
Black wire from lower thermostat connects to #4 lower right screw
Upper element: Yellow and Blue wires connect to either screw
Lower element: Red wire from top connects to either screw
Lower thermostat: Black wire from top connects to top screw
Short wire between lower thermostat and lower element
http://waterheatertimer.org/images/Water-heater-wiring-w-numbe.jpg
http://waterheatertimer.org/images/Thermostats-numbered-divided-500.jpg
http://waterheatertimer.org/How-to-wire-water-heater-thermostats.html
Sep 18, 2010 | Whirlpool Water Heaters
Replace Heater Element for Whirlpool Model GU 1200XTLB1 Dishwashr
Look inside the dishwasher to see where the heating element terminals are. If they are in front you might be able to change it but if the element is in back, you will need to have the dishwasher pulled out to install the element.
http://tclaundryrepair.com/
Feb 20, 2009 | Whirlpool GU1200XTLS Stainless Steel...
Dryers Logo
137 people viewed this question
Top Speed Queen Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
danoyachtcap
danoyachtcap
Are you a Speed Queen Dryer Expert? Answer questions, earn points and help others
