Question about Dishwashers
Kenmore elite dishwasher will not shut off - Dishwashers
    Sergeant:
  • 230 Answers
There is a timer inside the door, and if it is not working properly the timer can get stuck on a cycle and not end until you change the cycle yourself or turn it off. You will need to replace the timer for the dishwasher to work properley again
Posted on Apr 14, 2014
SOURCE: Kenmore Elite Dishwasher Problem
I had this same problem so I took the front panel off to access the thermal fuse.  What I found instead was that food had become lodged in the door latch which was keeping the door safety switch from operating properly.  I took a thin screwdriver and removed the food from the cavity.  Since you did not have the problem in your first five years the cavity just might be the problem since that is about the amount of time it took me to get too much food stuck in mine as well. This solution took five seconds and requires no disassembly.
Posted on Nov 10, 2008
iwillfixforu
  • 619 Answers
SOURCE: lights do not come on kenmore elite dishwasher
There is a thermal fuse on this model located on the control board. Remove control panel and you will see it attached to the board with 2 wires going to it. part number is 8193762. Hope this helps.
Posted on Feb 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: Kenmore Elite 665-16959000 dishwasher - soap door
It appears your dispenser wax switch has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
mikadot
  • 2113 Answers
SOURCE: kenmore elite dishwasher
If you had a fault in your neutral wire the voltage may have raised to near 220 volts and fried the circuitboard. Replave the circuitboard or replace the thermistor on it. Double check the voltage and the connections where it is wired under the dishwasher.
Posted on Nov 19, 2013
skistockli
  • 73 Answers
SOURCE: Reset sequence for Sears Kenmore Elite 630.1630?
You can reset this exact dishwasher by following the directions. Its not unplug for 40 minutes.
Posted on Dec 02, 2013
Starts but no water, then shuts off
start by removing water line and see if it is blocked with dirt or something. if it is then that could be the problem. if not I would replace the water inlet valve.
Apr 09, 2014 | Kenmore Dishwashers
My Kenmore Elite Ultra Wash Dishwasher keeps shutting off before entering the cycle. I have repositioned dishes, even emptied it, changed cycle and tried everything. When I press the start light flashes...
I too had problems with the Kenmore Elite (aka Bosch). The issue was solved by replacing the Lock Sensor on the door. After replacing the sensor the dishwasher has been working. Hope this helps.
Oct 08, 2013 | Kenmore Elite 24" Built-In Dishwasher with...
Kenmore elite dishwasher stops in mid cycle green clean light flashes 8 times pauses and then flashes one more time
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle. see the diagram
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/electronic control.
May 23, 2013 | Kenmore Dishwashers
Water not getting to dishwasher
Hi jorrico943
Check in the back of the dishwasher where the water feed comes into the machine. You will see a soilnoid that has the water connection to it...shut your water off and remove,clean, or replace the solinoid it sounds to be defective or dirty.
Sep 20, 2012 | Kenmore Elite HE4 Electric Dryer
I have a kenmore elite model# 665.16263402 and it just wont work i have tried changing the soliniode but nothing. it acts like it will start but then only run for 3-5secs and shut off
try checking your float switch, the first thing any dishwasher tries to do is pump out whatever water may be in the tub,
if it is shutting off your looking for why
make sure the float switch is not hung up look by the water soloniod to make sure it is sitting on the switch correctly
Oct 22, 2009 | Kenmore 24 in. 16032 Built-in Dishwasher
Kenmore elite
the time is flashing 42 on my kenmore elite front loader but when u presss the buttons noting happens
Jul 21, 2008 | Kenmore Elite 45986 Front Load Washer
Dishwashers Logo
61 people viewed this question
Top Dishwashers Experts
