Question about Canon PIXMA MP980 All-In-One InkJet Printer
Error 5000 on canon mp980 - Canon PIXMA MP980 All-In-One InkJet Printer
5 Suggested Answers
komguy
  • 2306 Answers
SOURCE: Canon MP980 All in one printer - Error 6000
Error 6000 tells you that the paper feed roller is not turning, check for any foreign oblects in the paper path, a flashlight and small mirror is the best way to look.
Posted on Jun 19, 2009
pineworks
  • 4041 Answers
SOURCE: canon printer MP980 error code c000 what does it
HiHi this code is.
C000 indicates to remove the packing material.
Remove packing material so that the print head holder can move. Confirm that the printer
is powered off.
Disconnect the power cord from the printer or at the wall outlet or both
spacer.gif mp620_removepowercord.gif spacer.gif spacer.gif spacer.gifOpen the paper output tray and then lift up the scanning unit cover until it locks into position.
CAUTION: The orange protective tape may prevent you from opening the paper output tray
Pull the orange protective tape (A) in the direction of the arrow and remove the white plastic (protective material) (C).
    spacer.gif mp980_packingbeingremoved.gif spacer.gif spacer.gif spacer.gif After the orange tape and plastic have been removed, remove the print head packaging (if it hasn't been removed already). 1. Close the scanning unit cover.Reconnect the power cord and then power on the printer.
    Found this code on the net hope it helps you.
    All The Best: Pineworks
Posted on Jan 31, 2010
pineworks
  • 4041 Answers
SOURCE: service error 6000
Hi there it is ink error.
You can try to reset the cartages this may do it Please call back let us know if it worked for you, PLEASE.
  1. Start with printer off
  2. Press and hold resume Button (triangle in the circle) and click “Power” button. Green led should be on
  3. While holding the Power button, release the Resume Button.
  4. Without releasing the Power Button, click “Resume” button for two times and release Both Buttons.
  5. Click “Resume” for four times then soon click “Power” button, to confirm the selected action (reset counter absorber).
  6. Turn off the printer and turn on again
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
Posted on Apr 26, 2010
  • 284 Answers
SOURCE: My Canon MP980 is showing Printer Error code 6000....
error [6000] or light blinking 3 times is mean there is an error occurred in the LF encoder signal.
Posted on May 27, 2010
Where is the "scanner lock switch" located on a Canon Pixma MP980 printer? I cannot seem to locate the switch "under the hood" so I need assistance.
The scanner lock on the MP980 is on left hand side of the scanner unit. It's closer to the hinge of the document cover and almost centered between the scanner glass and the edge of the printer. If you lifted the entire scanner unit, you won't see the switch. You should be able to push the switch towards the open lock symbol with your finger or thumb. The Getting Started guide has a pretty good picture of where the switch is in Step One. The guide is available on the product page, http://www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_mp_series/pixma_mp980#BrochuresAndManuals , in the Brochures & Manuals section. The current link to the Getting Started Guide is http://gdlp01.c-wss.com/gds/2/0300001552/01/MP980_GS_EN-US_V3.pdf . After moving the switch, turn off the all-in-one. Then unplug the power cord to clear the error message from the printer's memory. After a few minutes, plug the power cord back in and turn on the printer.
If the error persists and the scanner is unlocked, the scanner mechanism may be damaged. If that's the case, your MP980 needs service. If the unit is under warranty, contact Canon. (If it isn't under warranty, you'll need to decide if the unit is worth the shipping and handling fees and the minimum $50 or so charge just to determine the problem at a service center. (That fee will be applied to the cost of fixing the printer, if you decide to have the technician continue to work on the unit.)
I hope this helps.
Sep 21, 2015 | Canon PIXMA MP980 All-In-One InkJet...
I have a Canon MP980 and Im having trouble with it because when I try setting it up an error code apears that says C000.
It looks like you incorrectly inserted an ink tank
http://canoncanada.custhelp.com/app/answers/detail/a_id/11015/~/lcd-error:-error-c000
Feb 28, 2011 | Canon PIXMA MP980 All-In-One InkJet...
Error 5100 displayed. what is problem? how do I fix it?
According to the Canon website there are three possible reasons for this error:
Issue: ERROR LCD: Error Code 5100
1. Press ON switch to reset the multifunction device 2. Remove packing material MP980 (I think this is referring to the packing materinal when you first open the printer) 3. The MP980 may require repair
Jun 02, 2010 | Canon PIXMA MP980 All-In-One InkJet...
My Canon MP980 is showing Printer Error code 6000. Have turn off machine and turned on again - no change - still showing.
May 20, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Service error 6000 on canon MP980. Printer error has occured. turn off ppower and then back on again. If problem persists see the manual.
Oct 31, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Jun 18, 2009 | Canon PIXMA MP980 All-In-One InkJet...
Canon PIXMA MP980 All-In-One InkJet Printer Logo
43 people viewed this question
old marine
old marine
