Question about Kitchen Appliances - Others
THE WATER KETTLE 12PP1758 DONT WORK
I turned the watter kettle on it worked fine and hour later i try to re heat the water and it wouldnt work anymore . the light doent turn on either . i try to switch plugs but it wouldnt work. help please
  • 17 Answers
SOURCE: Red light's on... but no hot water!
OK, inside the unit there are three items, the heating element, thermostat, and thermal fuse.What has happened is the element got too hot and the thermal fuse opened.There is no reset button.In some cases you may run across a defective heating element or thermostat but its not common.The fix would probably be replacement of the thermostat and thermal fuse.For this, you would have to contact a small appliance repair center in your area.
Posted on Nov 07, 2007
SOURCE: How do I clean the contact points between kettle and platform?
PROBLEM:
My problem was similar for the Cuisinart KUA-17.  I clicked down the on switch and it stayed down.  However, the light and power together seemed finicky.  That is, the light came on if I positioned the kettle in the base correctly, but then it sometimes went off without triggering the switch to pop up.  When the light went off while the switch remained down the water never boiled, but when I was lucky to position it such that the light remained on, the water did boil and the switch popped up ... as it should have.  It seemed to be getting more and more finicky and difficult to position correctly ... so I took it apart.
SOLUTION:
First of all, the base has screws that take a triangle screwdriver which I don't have.  So I found a small flat-headed screwdriver (like one you'd use for glasses) that just fit along one side of the triangle.  I was able to get three base screws out this way and since I expected to need to do this again in the future, I used my dremel to grind a larger flat-headed screwdriver slot in each.  It's been about a year and a half since I fixed it last time and this time I was glad I had the slots.
Once you get the plastic base off, you'll see the mechanics of the switch.  There are two wires that both turn on the light and power the heater element.  Where the wires connect to the switch mechanism, there are two metal tabs that stick out in opposite directions from the center.  When the switch is pushed down, you can see these two tabs move.  They are each moving to touch a contact and complete the electrical circuit.  My problem was they were not making a good contact.  The contacts are hidden behind the tabs.  All I had to do was bend the contacts one millimeter closer (i.e. as little as possible) so that they would make a good contact.  The only other trick was I had to remove the switch mechanism from the bottom of the kettle to do this.  Then I just used the same small flat-headed screwdriver to bend the contact as in the picture below.
Posted on Mar 11, 2009
  • 3 Answers
Just a bit of clarification; the lights and heating element are both downstream of the thermal protection ( I had mine apart and had a look). Therefore the lights would be off if the thermal protection had kicked in.
Lights on but no heat means element has a problem. Could be loose wire but more likely burnt out. If you have a tamper proof TORX bit you can take the bottom cover off and check for continuity through the element. Isolate the lights from the element so your meter is not accidentally seeing continuity through the lights.
Posted on Apr 12, 2009
SOURCE: the kettle lights up but won't heat up
Too funny, but I solved the problem by returning the Kettle, all
the correct lights came on but it would not boil....so purchased a
different one.
J.
Posted on Apr 13, 2010
  • 9 Answers
SOURCE: When the kettle is switched on, the light comes on...
sounds like the element has died. If it's still under warranty, take it back. If it's not under warranty, contact an electrician or appliance repair person. Unless it's an expensive kettle though, it's probably not worthwhile fixing, as elements can sometimes be as expensive as a new kettle
Posted on May 23, 2010
My Breville kettle does not beep anymore when the desired temperature has been reached.
Might not work, so don't cuss me if it doesn't, but have you tried demineralizing it? Pour it full of white vinegar, let it heat to about 160-180 and then turn it off and let it soak for a couple of hours. The vinegar will dissolve any mineral deposits on or in the heating system. Mineral deposits are the bain of electric water heating systems of all types. Drip coffee makers, 95% of the time, a premature ***** is due to mineral deposits. It also destroys house hot water heaters.
Aug 27, 2011 | Breville BKE820XL Electric Kettle
I turned on the cordless electric kettle without water! the metal rod inside the kettle turned black? was it burnt? i tried boiling water again and it worked. but is the metal rod toxic or not? can i still...
Yes, if your worried, use a fine emory paper to clean off the tarnish from the heat scorch. You may have shortened the life a little on the element but it is fine as long as it is not spalling, of flaking.
Mar 24, 2011 | Microwave Ovens
When I turn on to start heating the water ... it clicks on and off and now over time will not heat water. Power is coming to it... I have clean it in and underneath ... worked once and now again will...
Chances are the heating element has been fading until it can no longer operate. You can try to have the heating element replaced or replace the unit.
Nov 09, 2009 | Bravetti EK119H Electric Kettle
It wont turn on
press the reset button on the back
Nov 12, 2007 | Samsung YP-K3 MP3 Player
Nov 06, 2007 | Kitchen Appliances - Others
Kitchen Appliances - Others Logo
153 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
