Question about Hoover HDC7FM Dryer
Hoover 410 Apollo clothes dryer throws 10amp fuse
This machine has not been used in 8 years and it's internal components are like new. When I try to start the machine it turns off the 10amp circuit breaker and I cant see anything wrong in the wiring.
Thank you,
My machine problem was resolved by changing the heater element to one from an old machine.
Posted on Jun 19, 2009
Hoover apollo deluxe dryer
Can you give a model number?
Jan 30, 2014 | Dryers
Hoover apollo deluxe timer
Probably a new timer... Which will probably cost almost as much as a new machine
Dec 27, 2013 | Dryers
Hoover Clothes Dryer Apollo 100 D6176
Most electric dryer problems not heating are due to the heater coil circuit being broken. The wiring can be replaced by the coil kit being purchased from an appliance parts store. Need make and model numbers. Follow directions in package.
Oct 13, 2013 | Dryers
How do I change the belts on a Hoover "Apollo Deluxe" clothes dryer approximately 1995 vintage
Remove the top cover by removing the screws at the back of the machine and sliding the cover off forwards. Now you need to obtain access to the complete circumference of the drum to fit the belt. Depending on your machine you can either remove the front of the dryer, or release the rear bearing support so that you can slide the new belt over the drum and under the bearing retainer, which may entail removing the back cover as well. The belt then just slips over the motor pulley and you need to check on the belt tension, usually done by adjusting the motor or the tensioner.
Apr 28, 2011 | Dryers
My Hoover Apollo 401 dryer is not heating, is this an element or could there be a fuse or some other problem
their is no fuse, heater coil is defective, a common problem, or this is not common, over heat safety sensor has tripped
Dec 19, 2010 | Dryers
Hoover Tumble Dryer trips out
Hi
Thanks for using FixYa. It seems to be the issue with the Thermal Fuse going bad and needs to be replaced. It is mounted to the exhaust duct inside the back cover panel. Whenever this fuse goes bad it'll either trip the circuit breaker or the dryer wont heat. You can also check it for continuity with an ohm meter, no continuity means the fuse is bad and you need to replace it. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Hoover HW5 513M Front Load Washer / Dryer
Hanging Hoover Apollo Deluxe dryer unit from the wall
you will need to get a wall mount bracket. I found a couple on ebay for about $30.
Sep 30, 2009 | Hoover Dryers
Hoover Apollo Delux not drying properly and takes ages. Outlet air is hot but my wife says it's not drying as well as it used to. The front filter is clean but is there an inlet filter that I'm overlooking...
T^o much lint in duct work, causing moisture and not allowing cloths to dry. Vacuum out duct work in dryer and from dryer to outside of home.
Jul 17, 2009 | Dryers
Not getting hot
Sounds like the heating element has broke. If it spins and doesnt produce heat its best to call someone out, or buy a new one. If nothing works, check fuses and connections
Apr 13, 2009 | Dryers
I have just started to fit a new hoover nextra 8 washer dryer following the instruction to the letter. When tipped up to remove internal packing, the base was missing, the internal packing did not exists...
photograph everything
contact the dealer with photographs
contact hoover with photographs
do not attempt to self repair, they are demons on warranty exclusions
Aug 22, 2008 | Hoover Washing Machines
Hoover HDC7FM Dryer Logo
259 people viewed this question
Top Hoover Dryers Experts
Tim Whalen
John Tripp
John Tripp
Are you a Hoover Dryer Expert? Answer questions, earn points and help others
