Question about Honeywell Heating & Cooling
Noma model ew7507ce
Hi my 2 year old noma model ew7507ce dosen't work. After plugging it message pop up in the window "prob". I try to turn heat on, after few times it came on and immediately turn it self off. It made clicking sound.Help, please
    Sergeant:
  • 230 Answers
There is a thermal disc inside the heater that will tell the heater if it is getting too hot to shut down. When the disc cools off then the heater will start up again. After a wile the disc gets weak or it gets stuck open not allowing the heater to turn on. You will need to replace the disc or purchase a new heater as parts for those are not easy to find.
good luck
Posted on Apr 14, 2014
3 Suggested Answers
  • 10 Answers
SOURCE: Air and heat not working!
check to see if thermostats take batteries pull the cover off and check and change them if they do. if they don't take batteries there will be a wire hooked to terminal C on the t stat. if they are new t stats they need to be programmed for your equiptment in order to work. some new digitals have a 5 minute delay after you set them. when it's in the delay HEAT or COOL will flash off and on, if it is actually calling for either one the words will be solid.
Test the thermostat: TURN POWSER OFF TO FURNACE. either at breaker box or switch mounted on furnace. make sure the door panels are all on furnace cause there is a door switch on the bottom panel that cuts power if it isn't pushed in.
while you have the cover off the t stat if the
batteries didn't fix it take wires from R and W and wire nut them together. the heat should come on after you return power to furnace
and/or making sure the power is back off
take wires off R G and Y terminals and wire nut them together AC should come on. if they do come on you have a bad t stat. if not you are losing voltage somewhere. either at the breaker box or furnace. a fuse could be blown on the circuit board on the furnace. if the fuse is blown you have a short in the stat wire. also check the fuse on that furnace switch we talked about earlier. if you have a volt meter take the bottom door panel off furnace making sure you push and hold that door switch in with a piece of tape. see if you have 120 volts going into the transformer the wires to test will be black and white. if so check to see if you have 24 volts accross the other two wires on the transformer if so see if you have 24 volts on the terminals R and C on furnace board. if so put a jumper wire on R and W heat should come on. if not it's the circuit board. any where you lose voltage is the part that is bad.
Posted on Aug 08, 2009
  • 3 Answers
SOURCE: Powers on, no heat
I have this model heater and it quit working as well. I took it apart to find that the plastic bosses that the safety switch mounts/screws to melted and the switch fell into the bottom of the heater rendering the heater useless.
FYI, The safety switch removes power from the heater when the heater is laying on it's front or back incase it gets knocked over while it is on.
This is a serious defect. These heaters should be recalled.
Posted on Jun 28, 2010
Noma oil filled heater manual model EW7507CE
Re. my problem with the NOMA EW7507CE, there is no power, no read-out, nothing. Tried different plug-ins, no evidence of power!
Jan 23, 2013 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
Noma ew7507ce manual
Timer is not identified.
Noma is a recognized brand name that is licensed to many different product manufacturers for a variety of different products including timers.
Check resources below:
1) Add a comment with clear description of timer, and/or post a photo on flickr and include link to photo
2) Open following link to see various Noma timers and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html
http://waterheatertimer.org/images/NOMA-logo-1200.gif
3) If you have different product than a timer, for example an oil-burning radiator or electric baseboard heater then re-post question on fixya with clear description of product for possible research and information
Oct 03, 2011 | Solar Noma 7 Day, 6 Event Outdoor Timer -...
When is bake mode, the oven heats and will shut off with an F3 error and blinking time. Totally unpedictable; works some times and not others with or without issues.
Disconnect the power supply for few minutes, say 15 minutes and then turn it ON. Do you still see the same error message. If yes, kindly revert with more information :-
1. Make and model of the oven?
2. How old the oven is?
Let me know,so that we could proceed.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Jan 06, 2011 | Microwave Ovens
Hi i my computer suddenly started to shutdown and turn on again after a fev seconds.some times it goes in to windows but soon after crashes.it has wrked for over a year and this was a home built...
Try these....
Overheating problem in your PROCESSOR!
Check the temp in your BiOS and the setting of your processor!
Check also the power supply and upgrade it to hifgher wattage!
Clean your processor HEAT SiNK, dust and dirt might have acumulated!
Check the HEAT sink position, if its flatly fitted on top of procie, and scrape the old silicon paste between ur proci and heat sink and put a NEW ONE!
Encountered this kind of prob.. the prob is in the PSU unit(Power Supply Unit)!
These might help you!
Nov 07, 2010 | ASUS P5QL PRO Motherboard
Error 99 message keeps popping up
Instead of taking battery out, open and close battery department to reset camera.
Sounds like you have a major fault, you should raise this with Canon and prob send for repair
Jun 02, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Operating Noma LV1064 Timer
Try Googling (noma)(LV1064)(manual) without parens for instructions.
Sep 14, 2017 | Watches
Kenmore Microwave Turns itself on randomly
22 years old and you are complaining that it starts andomly, you got way more than your moneys worth for heavens sake loosen up and buy a new one. Help the economy out.
Feb 24, 2009 | Frigidaire GLMB209D Microwave Oven
Heating & Cooling Logo
138 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
