Question about Mattel Power Wheels Hot Wheels Dune Racer
Power wheels dune racer wont move back left tire spins
Left rear tire spins but car won't move
How do i know if the wheel or the tire needs replacing?
If you have the tyres at the rear exchange on the wheels you will seperate them which should tell you whether the wheel or the tyre is at fault.
I would guess the tyre!!!
Jun 23, 2015 | 2006 Hyundai Sonata
Tip
Keep your tires in good lasting shape
Did you ever see the statements in the tire dealer shops stating a specific tire model will last approx. 50-75,000 miles/
This will never happen unless you have your tires rotated every 7500 miles, the front tires wear excessively compared to the rear tires in 90% of the cars/trucks.
Why? Because the front tires in most cases are the drive tires(front wheel drive) causing the front tires to ocasionally spin causing excessive wear and also the front tires are the ones that guide your vehicle down the road, when you turn the steering wheel you are turning the front tires to make the car go in the direction you want thus causing more excessive wear to the front tires, in order to get even wear from front to back tires one must move the front tires to the back tires at 7500 mile intervals, making sure the tires only get rotated to the same side of the car each and every time, if you move a right rear tire to a left front position, severe damage may occur so please keep them same side rotations.
Also have your wheel alignment checked at a tire shop each time you bring it in for a wheel/tire rotation as pot holes, hitting curbs,etc all can effect the way the tires wear if the alignment goes out.
on Jun 06, 2010 | Chevrolet Malibu Cars & Trucks
Will not move forward or reverse. Transmission is engaged, but no power to wheels. Help???
did you recently take the back tires off? if you did then you left out the keys that hold the tire to the transmission axle, other words the axle is spinning but not grabbing the rim, hope this helps
Jun 02, 2015 | Garden
What would cause my Aztek to make loud grinding, groaning and now sounds like something is broken in the rear while driving?
My hunch would be rear wheel bearings. Lift and spin each wheel listening for noise is all I can suggest at this point.
Mar 02, 2015 | Pontiac Aztek Cars & Trucks
Rear wheels wont spin
make sure u didn't lose a spacer or that they are in the right locations
Nov 13, 2013 | Yamaha V Star 1100 Classic Motorcycles
I HAVE A 2010 NISSAN MURANO...I HAVE A LOUD NOISE COMING FROM MY CAR THAT SOUNDS LIKE A JET ENGINE TAKING OFF/WINTER TIRES ON A CAR...I REPLACED MY 2 FRONT TIRES BECAUSE IT WAS NEEDED AND ACTUALLY THOUGH...
That most likely is a bad wheel bearing my friend. Jack each corner of the front and see if the wheel and tire will "shake" by trying to move the top of the tire in and out. On rear wheel drive vehicles, the rear axel will move in and out or op and down. If you spin the rear tire you may hear the grinding noise. Change that bearing where it moves or is noisy.
Nov 03, 2017 | Nissan Murano Cars & Trucks
Power wheelchair won't turn right, back tire squeals
Have you completely disengaged the wheel locks? Check for worn wheel bearings.
Apr 19, 2013 | Invacare Health & Beauty
Brakes freezing in reverse and back right tire won't move by hand when jacked up
Sounds like you have a stuck caliper, they run $35-50 for the rears on that vehicle, They are not that difficult to replace, just be sure to bleed the brakes well after replacing it and check for leaks. If it has been like this for a long while. I would inspect the brake pads, and rotor while your there and replace them if they are worn.
May 11, 2012 | 1997 Plymouth Voyager
Mattel Power Wheels Hot Wheels Dune Racer Logo
229 people viewed this question
Top Mattel Toys Experts
Nikki  Mclean
Nikki Mclean
ray gallant
Are you a Mattel Toy Expert? Answer questions, earn points and help others
