Question about Shakespeare Surf Fishing Rod and Reel Combo
Need to re-asemble a synergy steel reel - Shakespeare Surf Fishing Rod and Reel Combo
3 Suggested Answers
SOURCE: Cannot open Shakespeare Synergy Steele 2001s fishing reel
alright man......i had the same problem. it just takes a little bit of elbow grease, bot it does twist open, it's just harder than hell to get it to twist off. I took a towel and laid it over the reel, and lightly tapped on it with a hammer to loosen it up a bit.
Posted on Apr 29, 2009
SOURCE: im trying to open the front top to my 4001s
smack dat ***** wit a hamma!
Posted on Jun 27, 2011
My hozelock auto reel has stopped locking. Have tried pulling it all the way out and then releasing but it does not solve the problem.
40 meter Hozelock auto reel would not lock when winding back into the drum.
1, Make sure the Hozelock hose has fully retracted into the drum.there should be no tension on the hose reel spring.
2, Use a Black & Decker Workmate.
3, Carefully opened the side cover taking out all of the Torx screws (10 in total) remove handle.
4, Turned the reel over and placed the auto reel onto the Black & Decker Workmate.
5, Placed a socket into the Workmate vice then line up the centre shaft bolt on the auto reel onto the socket, this will hold the steel spring in place so that I could undo the 2 security Torx screws. Slowly remove the 2 screws- there will be a little spring tension when removing the 2 screws, take care.
6, Lever up the centre shaft up out of the reel to expose the internal hose reel, take note the rotation of the plastic cog inside the cover.
7, Remove the brake locking arm from the side cover.
the arm had broken in half, I used a soldering iron to weld the two halves of the brake lever back together.
8, Rebuild in reverse order.
8, When rebuilding the auto reel use the ratchet and socket to tension the steel spring, I unwound the hose out of the drum then slowly wound the spring using the ratchet and socket. This wound in the hose onto the drum up to the hose stop then a couple more turns on the ratchet for a little more tension.
9, Whilst holding the ratchet keeping the tension on the spring. Replace the 2 security screws on the centre shaft .
10, This link on Youtube I found very helpful (46 sec into video) you can see the internal working and the brake lever.
Apr 24, 2015 | Hozelock 2490 Auto Reel 20m Hose 12.5mm
User manual
can not get control panel to work on hydro massage spa
model ALCOY Aqua4fun
style gold
Sep 21, 2013 | Shakespeare Surf Fishing Rod and Reel...
Mums Synergy 3105 has lost handsfree funcationality
http://safemanuals.com/user-guide-instructions-owner-manual/BT/SYNERGY%203105-_E
Above is your manual ..handsfree starts p.15.
Hope it helps!
Jan 10, 2010 | British Telecom Synergy 2110 Cordless...
Think it may be a line tension problem. every
Wow, I can't believe that. That reel is very simple and shouldn't do that. I would guess that it's a problem with the line. Usually a real like that comes with line. Sometimes line is bad and it's very twisted due to being the last on the spool before it's put on your reel. I would suggest you buy some quality line, like Trilene or Stren and use about 6 lb test. I like the limp kind (read the box and it will tell you what type you are buying). Limp line means fewer twisting/tangling problems. Good luck. Alley
Jul 26, 2009 | Sport & Outdoor - Others
Battery and mains charger needed
To purchase battery,
http://www.gmkbatteries.co.uk/Cordless_Phone_Battery/BT/SYNERGY%202110/x/4/3/true.html
I can also check a place to purchase mains's charger.
But,
Check the price.If you purchase charger and battery, the price would be more than the price for the new phone.
Check the price - Only 9.9 B.Pounds.....
http://www.inest.co.uk/products/BT_Synergy_2110_DECT_Cordless_Phone.asp
I Hope i might have helped you to take a decision.
Thanks for using Fixya.
May 11, 2009 | British Telecom Synergy 2110 Cordless...
BT PHONE MODEL SYNERGY 3100 DIGITAL CLARITY
http://bt.custhelp.com/cgi-bin/bt.cfg/php/enduser/cci/bt_adp.php?p_sid=KEyO-6Fj&cat_lvl1=1243&cat_lvl2=1899&cat_lvl3=1897&cat_lvl4=1918&p_cv=4.1918&p_cats=1243,1899,1897,1918&p_faqid=11935
this is the manual for synergy 3100
Apr 06, 2009 | Lands Phones
Mar 24, 2009 | Shakespeare Surf Fishing Rod and Reel...
Shakespeare Surf Fishing Rod and Reel Combo Logo
26 people viewed this question
Top Shakespeare Sport & Outdoor - Others Experts
Bill Eager
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Are you a Shakespeare Sport and Outdoor - Other Expert? Answer questions, earn points and help others
