Question about NEC Dterm DTP 16D-1 Corded Phone
Trying to call an employees extention and it goes straight to intercom and he cant recieve any incoming calls on a dterm 80 phone
Need help getting his line back so he can use it
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 91 Answers
Not too clear on what's happening. Maybe the phone is set to call forward all. Usually CFA code is 41 plus ext. If the user happened to dial 41......, but forgot to dial 9 first for an outside line the phone could be forwarded to the twilight zone. In this case, dial 42 to cancel CFA, problem solved. If do not disturb in on, code 40 is the cancel code. This depends on your codes being at default, if your office codes were changed, say to make room for 400 series extensions, then who knows what will set and cancel CFA or DND. If you want the phone to ring instead of voice announce on internal calls, I'll have look for that later. I know it can be done in programming, but there's probably a code so you can do it yourself.
Posted on Jul 11, 2014
SOURCE: Nec DTerm Series i - Feature Light Flashing URGENT
Thankfully I have found a solution that has worked.
A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
To cancel this setting do the following
Lift the handset or press speaker
Dial the access code 4 + 2 (set as default)
Receive confirmation tone and restore handset or press speaker
I have found the manual at the following link to be the best resrouce ever - very easy to understand
http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Posted on Jul 08, 2008
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Posted on Sep 23, 2008
  • 16 Answers
SOURCE: I have a NEC ETW 16DC-2 phone that does not ring with calls
The telephone instrument you have can be used on the NEC Electra Professional Level I, and the Level II systems (and under some conditions the NEAX 2000 series). Codes for features are somewhat different based on the system. It is possible that your phone is in "Do-Not-Disturb" if other phones on your system actually ring when they are called via the intercom (on the Level I and Level II systems, initial intercom ring is a system wide setting). The cancel DND code is: Level I system: with telephone idle, press <FNC>, dial 60, press <FNC>. Level II system: with telephone idle, press <FNC>, dial 69, press <FNC>.
It is also possible that your ring volume is very low. To adjust, press <SPKR>, dial 601, then adjust volume using the up/down keys at the bottom of the phone (press <SPKR> when finished. If your system is programmed to access an outside line when you press <SPKR>, you will need to press the <INTERCOM> button first.)
If your system is set for voice intercom, people calling your phone can make it ring by dialing a "1" after your intercom number.
If you do all this and your phone still won't ring on incoming calls, let me know and we'll have to go into system programming to correct it.
Posted on Jan 12, 2009
SOURCE: NEC Dterm 80 calls won't go to voice mail
for us i just found this out.
1.Fwd B/NA
2.1 - 1:set-0:cancel
4.200
5.speaker
after 4 rings it goes to voicemail
this works for us.
i hope it works for others too.
turn this feature off
1.hit fwd b/na
2.0:cancel
3.exit
4.exit
should see the normal display then.
Posted on Jan 16, 2009
SOURCE: Make All phones ring when there is an incoming call
I have a DtermSeries E and the second line blinks but does not rings.
Posted on Aug 03, 2009
I have a NEC Dterm 80 phone system in our office. Not all phones will ring when there is an incoming call, and I want to set them ALL so that they will
Dterm 80 works on several systems, would be helpful if you mention what system you have. Programming lines directly onto a phone is done in system programming, not really something you can do yourself. If your IT person has the programming software, great. Very rare someone on site is tasked with knowing the phone system at that level, because it gets deep quick, and your working on the whole thing, not just one phone.
Jun 23, 2014 | NEC Dterm DTP 16D-1 Corded Phone
All extensions ring on oncoming call on NEC Dterm series i
.. I don't have a solution, I need a solution.
NEC Dterm Series I, through internal calls my phone flashes notifying me that I have a call coming through but it doesnt ring. I have tried the volume key ^, that didn't work. Can anyone help me?
Aug 27, 2012 | NEC Dterm DTP-2DT-1 Phone
My Intercom Extention shows busy. I have disconnected my Aneritech M7310 from the wall and reconnected, but I still can not dial out or receive incoming intercom calls. I have tried the #85 feature to try...
if the arrows constantly lit see if the intercom button is stuck down. sometimes junk gets down arround the button and doesn't alow it to release.
Nov 30, 2009 | Lands Phones
With the exception of not being to dial out, it sounds like your DND or do not disturb button is on,The feature can be turned back off by either pressing the DND button again or entering feature #85.
Nov 27, 2009 | NorStar M7310 Corded Phone
Jul 28, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Trunk to trunk transfers
The feature has to be allowed in class of service. you must than hit transfer, dial a 9 than the full number. you need to know how to program the phone system to change class of service. ldtsnj.com
Apr 07, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Answer outside calls from desk phones
go into program mode from operator phone.
goto MB 4-12 for key data
make sure you know the port of the phone
and what key you want to change and make
it a CO key
ldtsnj.com
Mar 30, 2009 | NEC Dterm DTP 16D-1 Corded Phone
I cant recieve incoming calls
Hi i put my sim in after i on my mobile there r invalidsim card earr came
Sep 08, 2008 | RIM BlackBerry Pearl 8100
NEC Dterm 80
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
Sep 29, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
150 people viewed this question
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
