Question about Whirlpool Washing Machines
How much is the control panel of model AWO/D 43115/1
My washing machine control panel is not working properly and it F08 appeares in the timer screen may be the control panel problems. so i would ask how much the price of this control panel?
5 Suggested Answers
  • 343 Answers
SOURCE: i have a whirlpool awo 3751 washing machine when i...
You most probably have a faulty water inlet valve...Not an uncommon problem..They can sound ok, but when you check the detergent drawer there will only be a trickle..Replace the inlet valve...Good luck...Nomess
Posted on May 24, 2010
blueextc3221
  • 15935 Answers
SOURCE: FLASHING F08 ERROR
F9 is an Overflow Condition error. If the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door may remain locked, and the Drain Pump may run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. Unplug the unit to service. You will need to check to following:
1. Check the drain hose and make sure it is not plugged or kinked.
2. Check Wire Harness connectors to the Drain Pump, Pressure Switch, and Central Control Unit (CCU).
3. Check/Clean Drain Pump Filter of foreign objects
4. Check for Drain Pump Failure.
5. Check the Inlet Valve for proper shut off
6. Check the Pressure switch for proper operation.
1. Check the drain hose by removing it from the standpipe and pull a vacuum on it with a shop vac. It could be that you have an obstruction somewhere. You may have to check the drain pump and the drain hose just prior to the drain pump as well. This is the hose that attaches to the bottom of the tub. This area can get clogged with debris
2. Unplug the washer and remove the kick plate and top panel. Check for any loose connections at the drain pump, pressure switch (located in the right rear of the machine), and the CCU (located in the center rear of the washer behind the wash tub). You may have a loose or dirty connection somewhere. If you remove any connectors, make sure you write down where they go. It's best to only remove ONE connector at a time when checking the CCU. On the pressure switch, make sure the air hose is still attached. This is usually a clear or black rubber hose. With the air hose off, loose, or leaking, the switch will not work and the tub will continue to try to fill. The pressure switch can be checked by removing the the large connector plug from the front of the CCU at the very LEFT. Readings across pins 1 to 2, 3 to 4, 4 to 5, and 4 to 6 should ALL read 0 ohms.
3. The drain pump. Remove the clean out cover on the pump and check for debris. Make sure you drain the water from the drain lines, pump and hoses PRIOR to removing the cover. Otherwise, you will have about a gallon or so of water to clean up. The shop vac method works great for this. If the pump is running and clear of foreign matter, the pump is probably not the problem. A meter reading across the pump motor windings at the connector plug should be about 15 ohms.
4. The inlet valve. If the inlet valve would fail in this manner, the tub would be trying to fill with water all the time and not shut off (even with the washer turned OFF). You need to ask yourself if you find standing water in the tub when not in use. Replace the water inlet valve if this is the case. Readings across the HOT and/or COLD solenoids should each read about 800 ohms.
5. The suds error. This occurs when air from too much detergent gets into the drain line. If you are using HE detergent (which is great, because on the newer models NOT using HE detergent voids your warranty), but HOW MUCH are you using? Some things to consider:
a. Do you have soft water? This can actually cause the soap to suds better making the need to cut back on how much you use.
b. Look at the detergent container. Is it double or triple concentrated? Some detergents are sold as extra concentrated which means you need to cut back on the amount you use. Not doing so can cause the water to over suds.
c. What size loads are you using the detergent in? Running small loads with the same amount of detergent can also cause over sudsing.
Rule out the simple common sense things first. If everything else checks out and your problem still persists, you may have a failed CCU or pressure switch
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
  • 6277 Answers
SOURCE: Need a user manual for
I'm so sorry but this forum is not able, nor in a position, to supply any type of manual, parts list, installation instructions, electrical or schematic diagrams direct; it's just made up of ordinary guys and gals, probably at home and from all over the world, with experience of addressing problems and giving guidance for free on the web ;-0)
Also members on Fixya are not 'affiliated' to, or representative of, any manufacturer at all, just using their experience gained probably over many years.
Manual
You will need to type into your search engine/web browser '(make model number) washer manual' and you should be presented with a number of sources from which you can either download for free or have to pay a nominal amount.
You could also try the manufacturer's web site direct ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Posted on Aug 13, 2011
kevin_getz
  • 1031 Answers
SOURCE: F08 EROR ON AWO/D 45135/1
http://www.managemylife.com/mmh/questions/227051-error-codes
Posted on May 22, 2012
I have a whirlpool awo/d5706/s that I went to restart yesterday and now there's no power.
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Push start switch may need to be tested with a multi meter for continuity OHMS should show a closed circuit when pushed in or turned on.
The start switch on some top load washers is often part of the timer and is activated by pulling out on the timer knob. Although not normally available as a separate part, the switch can be tested for continuity with a multi-meter. You will need to remove power from the appliance and then locate the correct timer contacts as noted on the wiring diagram. On some electronic controlled models, the start switch is a momentary contact type switch located on the control console. You can test this switch for continuity with a multi-meter when the push button is held in
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
By the way my advice is free cuz God is good!
All washing machines use a motor that is responsible for spinning and agitating during the cleaning cycle. Many top load brands use a reversing motor which means the motor spins in one direction for agitating and another for spinning and draining. If the motor does not start, but makes a humming or buzzing noise then it may be defective. To verify if the motor is at fault, remove the drive and /or pump belts and then try to start the motor again. On direct drive models, you will have to disengage the pump and the direct drive coupling to the transmission. If the motor starts, then the problem is with the transmission or the pump and can be further diagnosed by reconnecting each one individually. If the motor does not start or continues to hum or buzz, then it will need to be replaced
Lastly CONTROL BOARD
If the control board does not provide the proper voltage to the drive motor, fill valve, drain motor or door lock then the washer may not start. The main control board on most washers is complicated and difficult to diagnose without proper test equipment and procedures. You can visually inspect the control for signs of electrical arcing or burned or damaged components on the board. You should use caution when replacing a control board as sometimes the burned components are caused by external component failures.
Jun 22, 2015 | Whirlpool Washing Machines
HOW TO REPLACE WHIRLPOOL WASHING MACHINE VALVE MAGNET for AWO/D8500
Do not attempt to just replace valve components this is not a proper repair, just replace the complete inlet valve
Nov 16, 2014 | Whirlpool Duet GHW9150P Front Load Washer
What is F08 error means in Ariston washing Machine
You did not specify model!
F08 - Heater relay cannot be activated
  • Check wiring
  • Check pressure switch and connections
  • Tap relays as they can jam on new boards
  • Check electronic control PCB
  • Check heating element
Dado
Jun 21, 2014 | Ariston Technologies Washing Machines
Whirlpool awo 9663 wont start cycle
This can be due to failure of motor components or the control panel as there is no communication for the drive . Check the motor to panel wiring, check the panel for failed component
Jul 05, 2012 | Whirlpool Washing Machines
Need a user manual for a Whirlpool Front Loading washing machine AWO/D 43115
Manual
John C.
Aug 13, 2011 | Washing Machines
F08 FAULTCODE ON WIRLPOOL WASHING MACHINE WHAT DOES IT MEAN.
Hi.
F08 is heater error. Test heater and wiring to central control unit.
  1. Read impedance and ensure that the heater has continuity.
  2. Check heater contacts for leakage to earth.
  3. Check continuity on the wiring between heater and control board.
  4. Replace either heater, wiring harness or control module.
Jun 07, 2011 | Whirlpool Washing Machines
I have a whirlpool awo 3751 washing machine when i close the door set the program press the start button the machine appears to start and the time reduces but there is no water going to the machine i think...
May 20, 2010 | Washing Machines
My washing machine has just finished a cycle and an error message has appeared F-08 , cannot get machine to start
If it's Hotpoint or Creda,
F08: Heater control or NTC (Thermistor) temperature sensor problem.
Jan 24, 2010 | Washing Machines
F-08 Error message keeps appearing
Error code F08 indicates that the heater relay cannot be activated.
Check connections on
1--pressure switch.
2--heater element.
3--control module.
If you still cannot get it to work, then you are probably going to have to call an engineer.
Please rate my solution.
Thanks.
Nov 22, 2009 | Hotpoint Ultima WF860 Front Load Washer
Washing Machines Logo
59 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
