Question about Mitsubishi VS-50609 50" Rear Projection Television
No picture after hooking up DTV box, Heart Beat sound
Hooked up the digital box, worked for awhile, then later that evening after the TV was off for some time, it won't give us any picture. We have a sound like it has a heart beat (really!). Tried running the DVD player thinking that it might only be the antenna imput, still nothing. Any suggestions on where I should start? No response from front panel or remote except to turn the set on/off.
  • gpalumbo3 Jun 18, 2009
    Moved the box to another TV as my first solution and swapped the box that was hooked up to another TV. No change. The box that was on the non-working TV works fine on my other Mitsubishi (real old fold out type projection TV). Problem is not the DTV box.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 181 Answers
Uninstall the DTV Box and scart leads completley. If the box id new take it back to the store and ask them to connect it to one of their TVs or u connect to another TV in your House. The retailer may swap it if faulty. Other than that, Tap the DTV Box 3 or 4 times on the top, blow out all the connections or use a vacuum cleaner this will clear dust and re connect and re install.
Posted on Jun 18, 2009
Amplifier in protection
That thump beat was called motor boating and is amplfier oscillation. It means that a driving transistor in the audio output circuit is bad. You will have to send this in.
Apr 21, 2014 | Car Audio & Video
Do not know how to get regular T.V. hooked up to this system
try using the red White cables from back of tv to back of dvd player/receiver. Do the same with DTV/dvr or cable box. not sure if cable box has red and white cable outlets, however the DTV-DVR does, The quick patch is from TV to back of dvd (input audio)side,....that should work
Sep 26, 2009 | Coby DVD-937 5.1 Channel DVD...
PS2 won't work with magnavox dtv converter box
first off make sure u have the box turn off
this is what i would do:
i would get a short coaxile cable and splitter and hook them up to your tv
........................TV.........................Coax input
.........................|..............................Coax Wire
......................../\.......................................Coax Splitter
....................../...\.......................................Coax wire from ps2 and dtv box
...............PS2......DTV box......................
Hope this helps
Apr 28, 2009 | 1991 Honda Accord
Dtv converter box, no PS2
you need to hook up the ps2 directly to the tv not the converter box the converter box is only for digital Chanel's that will go off air on june 12 but if you have cable or satellite then you don't need a converter box this is only for free Chanel's with they don't requires subscription to cable or satellite your playstation should work with out the box try to hook it up directly to the tv not the box
Apr 28, 2009 | Video Game Consoles & Games
Frame periodically freezes on Vizio 37'' TV
Your statement is confusing. Why? because you stated " This tv is hooked up to an Antenna with a Booster", then you said it's connected to Cable Tv. I will answer this both ways for you.
If your on an Outside Antenna or Rabbit Ears, even with a booster, if the signal is not good prior to getting to the antenna then a booster only amplifies what it see's and that may be as we call it, "garbage". In a HDTV the freezing can happen when that situation is at hand, however if you are on Cable and we know the signal is clean ( we hope? ) then the problem is with the software in the set and should be looked at by a service center, or if it's right out of the box then I would exchange it.
In digital technology there's no maybe, it's yes or no! If the signal is not what's required, then you get what your experiencing now, IF, there's nothing wrong with the set, and there may be. I just repaired another brand doing the same thing and it was the Main Control Module. So, I hope I helped you in isolating the problem. Please keep me posted...
Feb 26, 2009 | Vizio SV420XV 42 in. LCD TV
Connecting samsung home theater to samsung lcd tv and direct tv
Need to get more granular on this, Does the volume work HT remote, for like radio, cd, ipod audio? For you to use the tv audio through the HTB the tv's audio settings should be on the "fixed" output option. This gives a line level to the Amp independant of the tvs volume adhjustment. Otherwise you will need to adjust tvs volume 75% or so before the audio amp will reproduce a good volume. Turn down audio amp prior to making any adjustments. Let me know thx
Nov 23, 2008 | Samsung SCH-a650
Emerson Television
With a cable or DTV converter box hooked up, the only channel the TV will find is channel 3 or 4 (depending on how the box is set). Make sure the set is on the right channel and you should be OK. Also make sure the cable is good. If you have several TV's connected to the same source you might have a bad cable or splitter somewhere in the chain. Hope this helps!
Nov 15, 2008 | Televison & Video
Mitsubishi VS-50609 50" Rear Projection Television Logo
89 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
