Question about Salter Stainless Steel Electronic Bathroom Scale
Error message on my salter kitchen scale - Salter Stainless Steel Electronic Bathroom Scale
evista_win
  • 10 Answers
SOURCE: my salter 1004SSDR kitchen scale won't show any
Your salter scale has a 15 year warranty. I would call the customer service number 1-866-843-3905 and ask them why it won't zero to weigh anything. They may replace your product.
Posted on Sep 10, 2009
SOURCE: The display on my salter bathroom scales is
I held the two arrow and set buttons together for a few seconds and it cleared
Posted on Oct 20, 2009
SOURCE: E appearing on display of Salter kitchen scale
i have the same problem- did you manage to fix it??
Posted on Dec 29, 2009
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Posted on May 23, 2010
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
My Salter Model 2001 kitchen scale, shows an 'ee' on the screen. This error code is not listed in the manual. Any suggestions?
"EE" means that the scale has been overloaded. Try placing a small weight (i.e. 250g block of butter) on the scale and then turning the scale off and then on again with the small weight still on the scale. What this does is to try and re-calibrate the scale. If this doesn't work then I am pretty certain that the scales will need to be replaced. The scales in question do have a 15 year guarantee and you can try contacting Salter Housewares directly if you have your proof of purchase.
EE showing on screen
Sep 12, 2014 | Salter 2001 electronic kitchen scale
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
'out 2' error message shows on a brand new Salter Disc Electronic scale.
Below is a solution for the "Out2" error on the Salter scales.
I have a Salter Model 1400. It was dropped and started to display the "out2" error on the LCD display. I looked for solutions on-line but could not find anything which showed a solution. With no solution in hand I figured I would at least try to find out if my scale was salvageable. I removed the screws, there are two below the 9V battery, two under the footpads, two under the "model sticker", and two larger screws holding the scale plate to the base. After all the screws are successsfull removed, the case of the scale comes apart easily. I started looking at the small circuit board and looked for damage, and also tried several things, turned on and off the unit while it was apart but still saw the "out2" error. I then removed the circuit board, there are many screws holding it down. Looking at the LCD display, I noticed that there must be proper contact between the LCD display and the copper contacts on the circuit board, or nothing is displayed. Perhaps, "out2" is an indication that it can not display "out" anything because after it was dropped the LCD display moved enough that it no longer aligned with the contacts on the circuit board. I noticed that there is quite a bit of "play" or area of movement around the LCD display and the case. There were no cracks or damage so I assume that the loose LCD display is common even with a scale that was not dropped. I was able to align the LCD display, by moving it several times and realized that after pressing the ON button, I no longer saw the out2 error. So I decided to put something in between the LCD display and the case so that the LCD display would not move and therefore would align. It took some playing around, but I eventually took a very small piece of papertowl, about the size of my thumbnail and rolled it up and placed it between the LCD display so it made the LCD display snug and would no longer move around. I screwed on the circuit board, and voila, no more out2 error! It started working perfectly.
Jan 19, 2011 | Salter 2001 electronic kitchen scale
My salter 1004SSDR kitchen scale won't show any real weight - just stuck on '5000' which is the max weight in grams, won't switch off, crazy
Sep 09, 2009 | Salter 9007 Glass Lithium Digital Scale
Negative weight on Salter Stainless Steel Kitchen Scale
make sure the battery your getting is a good one longlastig and if that doesnt work then how nout the motor
Aug 21, 2009 | Salter 2001 electronic kitchen scale
Mar 31, 2009 | Salter 2001 electronic kitchen scale
Salter Stainless Steel Electronic Bathroom Scale Logo
21 people viewed this question
Top Salter Health & Beauty Experts
traccie
Level 1 Expert
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
