Question about Refrigerators
Schreiber app6302 integrated fridge
On a Schreiber APP6302 the seal at the top of the door doesn't touch the fridge body but the one at the bottom does. The seal appears to be the same thickness all round. I cannot see any adjustment on the hinges.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 145 Answers
Sounds like the door has twisted
a quick fix is to place an object like a soccer ball
on the floor in front of the fridge while the door is still open
Pushing the top of the door slowly try closing it against the ball to twist the door straight
this is a trial and error aproach that does need a bit of force however it does often work and saves the alternative which is dismantling the entire door
Posted on Apr 15, 2014
  • 15 Answers
SOURCE: Hello FixYa The fridge light comes
Make sure the condenser fan is working and check the evaporator fan too!!
Posted on Aug 17, 2008
SOURCE: Smeg Fab 32 door problem
The Door on my SMEG Retro Fridge keeps opening on its own accord ? There's nothing inside poushing up against it so why does this keep happening ?
Posted on Dec 13, 2009
  • 66 Answers
SOURCE: I have a schreiber fridge
APM6855 Built in fridge freezer If Fridge is not cooling & freezer is ok then try a defrost by switching off for 24 hrs Then switch back on. it should be OK. If this does not work it is probably the door switch faulty , this should switch on the fan when door is closed. The fan is then controlled by thermostat sensor which switches fan off/on when required.
Posted on Apr 18, 2010
iwillfixforu
  • 619 Answers
SOURCE: Fridge Door seems to have dropped
The cam risers at the bottom hinge have gone bad. Get the model number form the fresh food section and you will be able to order new ones. Not expensive to repair.
Posted on May 16, 2010
caroldon
  • 17130 Answers
SOURCE: DIPLOMAT APP6302 FRIDGE
The no frost fridge has a compartment that collects the water while it keeps defrosting on a time cycle. I presume that the tray is clogged and full. you will need to access the rear to see to this. Also try to reduce the cooling on the thermostat, reduce the times you are keeping the door open. all of his will only create more frost into the coils to be defrosted. Please also see that the cooling/blowing fans in the freezer are not blocked, allow space for the air flow. Helpful I guess. Good day
Posted on Jul 05, 2010
Schreiber APM6852 Hi, I've cleaned my fridge today and defrosted the back of it, but now the light doesn't work in the fridge, I've changed the bulb, but still nothing! Have a turned the light off...
Most units use a door switch to turn the light on/off. Its usually located on the edge of the frame so the door closes on it to make/break the circuit. Switch could be bad or disconnected. Also your bulb may be bad, new doesn't not always mean good! Also look at the center contact in the bulb holder you may need to pull it up a bit for it to contact the bulb center pin. DO THAT ONLY WITH THE UNIT UNPLUGGED FROM THE HYDRO!
Aug 13, 2014 | Refrigerators
Schreiber fridge
I want the fridge glass for schreiber HTI 2121 model APM6514. Where can I get it please
Jan 13, 2014 | Refrigerators
My hygena/schreiber tall intergrated larder fridge has stopped getting very cold. I thought the thermostat had stopped working .As insructed I turned it off waited 30 minutes and turned it back on. I...
Check where the compressor is and right next to the compressor should be a fan .Check to see if fan is running ,if it is then check the final type coil to make sure they are clean .
Sounds like your unit is shutting off on high head pressure
Jun 22, 2017 | Refrigerators
Instruction manual for Schreiber apm6121 fridge
How do you clean drain drawer if fridge is integrated into unit?
Nov 03, 2010 | Refrigerators
My intergrated fridge app6302 light fitment has completely melted why would this happen. I have taken the bulb out is this dangerous and can i get a replacement fitment
DOOR IS OUT OF LINE ..
causing door switch not to operate - this leaving light on even when door is closed ..
normally door drops due to heavy milk bottles etc , maybe just need a new set of hinges ..
Oct 19, 2010 | Refrigerators
Jun 30, 2010 | Refrigerators
Door on my integrated Bosch fridge keeps opening
Seals rarely fail most likely needs hinges replaced,parts quite cheap
Jun 16, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
I have a schreiber fridge freezer. Display is showing H for fridge, freezer is ok. Can anyone help? Thanks Anne
Nov 15, 2008 | Refrigerators
Refrigerators Logo
127 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
