Question about Epson LX-300+ II Matrix Printer
Setting custom size (tear off) paper
I want to print an 8.5 x 2.38 paper in epson lx-300 II but there's no option to set-up a custom size. somebody mentioned about IBM ProPrinter II driver or something like that but i cannot find the file anywhere. anyone have it? I desperately need to print this page... thanks
I have some problem, but now have solved
1. replace your original epson lx-300+II driver by IBM ProPrinter II from windows installation driver.
2. in control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> chek create new and fill new paper size and don't forget give a name (ex. 8.5x6)--> save form
3.In printer and faxs right click IBM Proprinter II-->choose properties--> click device setting tab --> change tractor feed, manual paper feed and upper paper tray feed to new name (8.5x6)
4. Good luck
Posted on Jul 29, 2009
Hi don,
i have the same problem.
i don't know the codes you mentioned.
can you help with this.
i am using visual basic 6 to print a 8.5" x 6" paper size.
my printer is an Epson LX-300+II
i have the paper size t 8.5"x 6" but the printer won's stop after 6"
i really need your help.
please email me
Joseph, jcloribel@gmail.com
Posted on Jul 03, 2009
Any Printer you can use Goto server properties, as above mentioned set the papersize put it as default for your printer in windows Printers settings and dont set any size measurement in your VB code. any attempt made to change the papersize or scalesize in coding vb change it as default. So rely on windows printers setting what you need. the vb take it from windows dont bother about any codings
Posted on Dec 31, 2009
Why not giving continously print (epson lx 300+)
Posted on Jul 17, 2009
    Genius:
  • 1,018 Answers
Normally this is done by using printer command codes.
Are you trying to do this through a custom application or an application like Word?
What datastream emulations does your printer support. For example ASCII, Extended ASCII, PCL or Postscript.
It's pretty straight forward programming, do you need help with it?
Don
Posted on Jun 18, 2009
  • 2 more comments
  • Don  Farrell
    Don Farrell Jul 04, 2009
    J,
    Sorry I did not see your append to this post. Yes, I can help you.
    Don
  • Don  Farrell
    J,
    Don
  • Don  Farrell
    Don Farrell Jul 08, 2009
    Sent sample test file to Joe. Don
  • miztaa May 19, 2011
    send me i have the same problem here.. after the print end , the roller still continue and waste paper..
    New Friend:
I CRY
Posted on Jan 08, 2013
I have similar issue, either configuring the printer (epson lx-300) with windows drivers or ibm generic, the margins doesn't work properly.
I followed what fikrifaza said, and the printer works but even if i change the margins (from control panel-->printer and fax-->choose IBM Proprinter II ---> click File-->server properties--> click form tab--> ...) like zero or whatever, it doesn't work. The margins stays always the same.
Posted on Dec 11, 2009
In EPSON LX-300+ printer need to set up the page size,i could manage to set up the paper size,but it was countinuous paper,so it has line to tear off.,but after finishing the printing in one page,next...
First check what paper size u want, then set the same size in the printer menu. Next go to Printer properties paper setting change it there , then advance change the size, printing preference again check both the options to the prefered size.
Your printer must work now with all these options
Feb 17, 2011 | Epson LX-300+ II Matrix Printer
Custom size doesn''t present on your driver on Form to Tray Assigment in
Hi, I can't understand what "Custom size doesn''t present on your driver " means. the drver is just the piece of sofware used by windows to make your printer work. Custome size setting should have nothing to do with the driver.
Feb 23, 2008 | Epson LX-300 Matrix Printer
Custem size paper are not creat
am using an Epson LX-300+II dot matrix printer in Windows XP. I am
trying to print checks that are tractor feed 8.0" x 3.66". I added the cusotm
paper size in the print server and it is saved correctly, however, when I try
to print, the print properties dialog does not show the paper size. In fact,
there are many paper sizes in the print manager that do not show up in the
list of available paper sizes.
Apr 13, 2010 | Epson LX-300+ II Matrix Printer
Epson LX-300+ II
just change the page length setting in printer .just press pause button and switch on the printer and change the setting accordig to the page size it is bettreif you take online help from epson service call center they will guide you how to set the page length.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Feb 22, 2010 | Epson LX-300 Matrix Printer
How can i add paper size of tally printing in lx-300
if you want change page setting in your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size.....
you can map your tally printer paper size in system .....go to printer and faxes ... file..>server properties ...>select create a new from ...> change the name as you wise and change the paper setting and click ok ........
while you give print change paper size to your created paper size and check
Dec 19, 2009 | Epson LX-300+ II Matrix Printer
After Printing a bill in a 8inch paper, for the Second bill its not getting retract automatically
for this you have to change some settings of your printer ..... to get the all settings of your printer press font button and switch on the printer (before take setting make sure that you printer loaded with paper ) goes through the instruction printed in the paper to change the settings ........ change paper size to you bill paper size and enable the tear off option ........ hope it solve your problem ..................
Dec 17, 2009 | Epson LX-300 Matrix Printer
How to set half half size paper
Look for a latch on the right side tractor drive. This will unlock it so you can slide it sideways on its rail. Set it approximately where it should be, load the paper, then adjust it so you have a slight amount of tension across the paper. I think the rest is software.
Jun 25, 2009 | Epson LX-300+ II Matrix Printer
Setting of new paper size from epson lx-300 +II
your solution works fine with me, but the problem is i can't able to save the settings on the printer. so everytime i need to print on that given custom sized paper type, i need to manualy select it from advance tab on printer properties before i have a good print-out..
Anyways,Thank you very much.
Apr 13, 2009 | Epson LX-300+ II Matrix Printer
Configuration of page length
Most of these older printers use a special key to enter setup...usually upon power-up. Have paper inserted, because that is where it prints it's configuration.
It will probably use some of the feature buttons to change the paper size and tear-off options. Sorry I can't help with a manual, but I hope this helps.
B)
Apr 08, 2009 | Epson LX-300+ II Matrix Printer
Small Height Paper Size Problem
here's an option for you to consider.... hope it helps!!!!
set it to 3.6 and make your adjustment on the page margins.
Feb 28, 2008 | Epson LX-300+ II Matrix Printer
Epson LX-300+ II Matrix Printer Logo
3,273 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
