1998 Mercedes-Benz SL-Class Logo
C
Coco Posted on Apr 14, 2014
Ticking sound No dash lights. Ticking is worse in cold weather
AAA BBB
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Apr 20, 2014
AAA BBB
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
477
Points
I have a 300SL and I encountered a similar problem. My dash lights were not coming on, the car was not starting and there was a ticking noise coming from the passenger side(near airbag) when I was trying to start the engine. I noticed that my ignition switch was slightly getting loose. There is an adjustable cover around the ignition key ( like one inch wide) that can be easily tighten by hand. The purpose of this cover is to hold the ignition in the proper place for the electrical contact. It also has a few marks on it which show you if it is properly aligned. By adjusting it to the proper spot, I was able to fix the problem and the car starts just fine right now. Sometime (once in 6 months) it gets loose again and I have to re-tighten it, but it only takes 5 seconds to do so. It seems like the ignition switch is very sensitive on these cars and the smallest misalignment of the switch can make the car not start.
I hope this helps.
I have a 2001 Grand Am and I have been having problems with a ticking sound that resembles when the turn signal is on.
Without hearing the noise sorry can't offer a solution, but yes it can be fixed, see the dealer for help or a shop that you trust if you can afford the dealer, which is the best source of expertise for this type of problem. It is you choice.
2answers
What does ticking sound after the car is shut off mean?
No idea
How you one guess at that,
without the vehicle ?
2answers
Ticking sound upon acceleration. worse when cold
When you start the car with cold engine the oil light indicator is on even after the engine started?
If the sound comes from the engine itself you could check the oil level with cold engine before start.
If oil level is ok ( between low and maximum marks on the dipstick ) then could be 3 posible causes:
1. Bad oil
2. Faulty oil pump
3. Worn camshaft bearing, worn crankshaft bearing, or faulty piston bolt.
It may help if you bring on some more details like since when is making that noise, in what circumstances appeared and so on.
Dash lights denali
SOUNDS LIKE YOUR INTERNAL HEATER RADIATOR IS LEAKING UNDER THE DASH GET ELECTRICIAN TO CHECK ....ELECTRICIAN IS BEST SUITED AS ALOT OF WIRING DISCONNECT AND RECONNECT INVOLVED IN REPAIRING THE PROBLEM
My 2001 mustang wont start in cold weather
sounds 2 things here. fuel pressure regulator or the idle air control valve. I an goingwith idle air control valve
5helpful
2answers
My 95 lancruiser is making a loud ticking noise when cold, it seems to diminish after driven for a bit - what can this be?
Motor oil thickens when cold- on very cold days, some grades of motor oil can be nearly the consistency of honey. It takes time for the oil to make its way from the oil pan to the top of your engine.
The ticking you hear is usually caused by the valve lifters running nearly "dry" - meaning that they are getting very little oil. As your Cruiser warms up, the oil thins and makes it "up top" much easier, so the noise decreases.
Make sure that you are following your manufacturers recommendation for the grade and viscosity of oil (example: SG SAE 10W30) for the temperatures you are operating your car in. In extreme cold weather environments, such as Chicago or Milwaukee, you may want to use an even "lighter" oil (example: 10W20 instead of 10W30) - you just have to be certain that when spring arrives, you go with the higher viscosity oil- your manufacturer normally covers this info. The grade (example: SG) is very important because it refers to the detergent content of your oil.
No vehicle manufacturer that I am aware of recommends a "straight grade" viscosity oil (example: SAE 30) in cold weather. Multi-grades, which act "lighter" in cold weather are called for.
The "W" in the oil viscosity designation means "winter" - it is the viscosity of that particular oil at 0 degrees F..... For example, "10W30" oil is as thick as an oil with a viscosity of 10 at 0 degrees F, and is as thick as an oil with a viscosity of 30 at 70 degrees F.
Pretty Cool, Huh?
It is not a good idea to use any oil thickening additive (STP, motor honey, etc...) in cold weather because they tend to add even more viscosity.
"The Court is out" regarding teflon additives such as "Slick 50" to your oil- the principle sounds good to me, and I have used them myself. Personally, a similar product has seemed to help tone down the "startup ticking" I myself have experienced.
Rough idle engine ticking
check for a lose spark plug lead or cracked elecrod insulation on spark plug
Ticking noise
A small exhaust leak can sound like a ticking noise during acceleration and can get better or worse as the system heats up. I had a similar problem when the engine was cold that was solved with a new exhaust manifold gasket.
2answers
Mitsubishi Expo 1993
If your gas lines were froze then there is obviously water in your fuel system which even once thawed could prevent your car from starting and may not run good if it does. With that being said it obviously has to be cold for your gas lines to freeze and cold weather is ******* your battery especially if it sits for a while. Turn on your headlights and see if they are working good as well as your dome light and radio. If they are not working good or at all charge the battery with a battery charger, even though you have tried to jump it. Your car will have a fairly small battery and the smaller the cold cranking amps your battery is rated for the worse it will be in cold weather, possibly even not turning your engine over. If you do all this and it does not work it may be your starter but my money is on the battery.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
