Question about HP Laserjet P3015X Printer
HP p3015 paper tray won't go back in - HP Laserjet P3015X Printer
3 Suggested Answers
  • 199 Answers
SOURCE: need part number for Back paper stay\stop in 2nd tray
try on this link -
http://www.precisionroller.com/all-supplies-and-parts-for-hp-color-laserjet-3800dtn/products.html
Posted on Jun 26, 2009
  • 100 Answers
SOURCE: hp c6180 won't print from 4x6 photo paper tray
If you put regular paper in the tray as it is asking does the printer use the regular paper to print the picture? If so, be sure the 4x6 photo paper tray (with photo paper) is pushed all the way in, and when you select print there should be an option (probably hidden in a submenu) to select the photo tray as the paper source. If you are printing from Adobe Acrobat, I have not found a reliable way to get the c6180 to use the photo paper tray. I hope this helps.
Posted on Jul 20, 2012
How do you remove paper stuck in the back of a P3015 printer?
If the paper is jammed in the fuser, sometimes the only safe way is to remove the back door to gain better access. Open the back door, on the right side you will see a white arm that attaches to the door and disappears into the printer. Pop it off the shaft if is clicked to. Then remove two screws from the back door. Lift the lower panel that covers the paper drawer and pry on each side of the lower back door. Once those catches release, pull the back door off by pulling the bottom of the panel towards you and the top will pop out. When reinstalling the door, make sure to reattach the white arm to the door before closing the door. Failure to do that can result in that arm getting broken,.
Oct 13, 2016 | HP P3015 Laser Printer
Tip
Moves repeatedly input tray 1
LaserJet P3015 is loud and you start to use the tray 1 moves repeatedly input tray and roller if all papers using loads very quickly leaving stuck in the fuser. the tray 2 works fine.
on May 26, 2011 | HP Laserjet P3015X Printer
My HP laserjet p3015 wont print from tray 2 on its own. I have to press ok twice to bypass other instructions and then it will print
Hi is your document you are trying to print matching paper size that is in tray 2? sometimes you have a word document that is set to print to tray 2 but the paper in tray 2 is not the right size so hit Ok twice to confirm the size. also the adjustments on the tray may need to be fixed
Feb 08, 2015 | HP Laserjet P3015X Printer
How do I fix the "phantom" paper jam on HP P3015?
Just had one today that would throw a open rear door error. Turned out that the flag in the back of the fuser was dislodged.
Sep 29, 2014 | HP Office Equipment & Supplies
How do I fix the "phantom paper jam on P3015?
Do you have an error code? Usually if you get a jam error and there is no paper in the printer it is because the printer was unable to pick the paper out of the tray. Try printing from the drop down manual tray to confirm that the printer itself works. If it does, then clean the roller in tray 2 with a damp cloth and make sure you dry it completely.
Sep 29, 2014 | HP P3015 Laser Printer
How do I put the paper tray back into my HP LaserJet P3015 printer
Make sure that you did not lower the duplex tray. Look into the printer where the paper tray goes and make sure the path is clear. The duplex tray is dropped by pushing on a green lever on the left front of the duplex tray. Simply push the tray up until if clicks and locks in place. This is the only reason I have run into with clients as to why they cannot insert the paper tray.
Sep 13, 2014 | HP Laserjet P3015X Printer
59.50 error
This is a main motor issue. Remove the toner cartridge and the paper tray and turn on the printer and see if it comes to asking for cartridge and paper. If still get the error, you can remove the fuser using the instructions at the link below and see if you can turn the big fuser gear by hand. If not then the fuser is preventing the motor from turning.Hope It's resolve all Your Printer Problem,
Or Still having Problem Then follow Us For:-
HP Support
Apr 22, 2014 | HP P3015 Laser Printer
HP 3015 tray 3 open
Ckh cassette present switch as shown in fig.. switch broken, bent, misplaced as well as cassette switch trigger broken or bent..
dma8p8d+0vrbcgllecaaaaasuvork5cyii= 93ed81bf-3630-4b48-a344-63df5841aef8.jpg
Apr 17, 2014 | HP P3015 Laser Printer
Hp P3015 printer
What you need is the 500-SHEET Laser jet Tray CE530A, It automatically print on two different types of paper such as plain paper and glossy brochure paper without manually loading paper trays for each print job. And Save time and improve the performance of individuals and work teams with the increased paper capacity of this 500-sheet paper tray from HP. With more sheets of available paper, users spend less time refilling paper trays. I hope to hear from you soon.
May 11, 2013 | HP Office Equipment & Supplies
Hp c6180 won't print from 4x6 photo paper tray
Jul 15, 2012 | HP Photosmart C6180 All-In-One InkJet...
HP Laserjet P3015X Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
