Question about Miele Novotronic Premier 500 Front Load Washer
Flashing light pre lava miele w820
2 Suggested Answers
SOURCE: i have miele w500 problem is the soak/pre-wash
hi, the problem you are having with the "soak/prewash" light flashing after the wash has started is a common fault on the meile washing machine. Its a water sensor problem. remove all srews and bolts from front of machine and open the front panel. you will see a red in colour pressure switch at one oclock, there will be a black tube attached to it, remove the tube and replace it with a new one, or reverse the tube in reverse and you will find that the water intake level will be less and the fault of the "soak/prewash" light will no longer flash, problem solved. 0868887054 DAVID ASHBOURNE. MEATH.
Posted on Nov 28, 2012
Lava stone grill
Cheers--Miele.com.au looks like next door :-)
Aug 02, 2017 | Miele Dishwashers
Miele w820 novotronic
A What-ty? Miele! Well Whatever it is called. You got a bad drain pump and it needs to be replaced!
Jan 16, 2014 | Washing Machines
I have miele w500 problem is the soak/pre-wash
Nov 14, 2012 | Miele Novotronic Premier 500 Front Load...
W820 washing machine
Some markets do have an internal fuse, if it has one it will be right where the power cord runs into the machine, if not then the issue will be with the main control panel.
Mar 10, 2012 | Miele Novotronic Premier 500 Front Load...
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
I just bought a Lava Glow Wireless Controller for my ps3, but i cant get it to connect to my system. what do i need to do?
With the playstation powered ON plug the USB Receiver in the Console into Input 1#. The Light on the receiver will flash rapidly. On the controller press the menu button. the led on the controller then will flash rapidly, press the menu button again while the LED on the Controler is Flashing. Once you have done this you should get a solid Light on the controler. Now your controler is set.
Jan 18, 2010 | DreamGear Lava Glow Wireless Controller...
Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Apr 25, 2009 | Miele Novotronic W1918A Front Load Washer
Miele novotronic w820
i havent changed one on this model but there useally much the same and qiute easy to do first take the back off the machine
at the lower half of the rear of the drum there is two prongs sticking out with wires on spade connectors a third earth wire in the centre remove these 3 wires they should just pull off but sometimes held on by nuts you will have to check yours then with the machine emty of water unbolt this is the element assembly is the reverse
Jul 26, 2008 | Miele Novotronic Premier 500 Front Load...
Miele Novotronic Premier 500 Front Load Washer Logo
22 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
