Question about Konica Minolta 2 Pack Bizhub C-250 C-250p C-252 Tn-210m Magenta Toner
C352 TCR Toner Supply for the Cyan Imaging Unit.
  • Konica Minolta Master
  • 6,696 Answers
4 Suggested Answers
  • 13 Answers
SOURCE: Reset Chip on Konica Minolta 8031 Imaging Unit
I can provide you with a programmer to reset the chip. They are only about $500-$700. Still interested?
Posted on Sep 13, 2009
  • 13 Answers
SOURCE: Large Toner Streak... Bad Imaging Unit?
Check to see if you waste toner recycling for the cyan is working or being blocked. Check the transfer bias roller next to the cyan drum. Return you cyan imaging unit for a warranty replacement. Check for obstructions to the cyan developing unit. Check that the cyan IU was put into the machine properly. Check for toner leaking from the entrance to the developing unit or from the toner cartridge.
or, call a qualified KonicaMinolta tech to check out and service your machine.
bendarden
  • 984 Answers
SOURCE: install imaging drum Bizhub c352
The best way to solve your problem is to download the official Konica troubleshooting solution manual. It will tell you how to pinpoint and fix every problem reported to Konica. CLICK HERE
Posted on Jun 08, 2012
While doing printing after 6 or 7 print, the error code c2552 appear in konica Minolta c220, I have open the front door, after that error gone, Again same problem coming after 6 or 7 print.
C2552 Abnormally high toner density
detected Cyan TCR Sensor
• TC ratio in the developing machine, which is
determined by Toner replenishing amount control
mechanism, is 12 % or more for a given number
of times consecutively.
1Clean the TCR Sensor window on the
underside of the Imaging Unit if dirty
2 Reinstall Imaging Unit
3 Change Imaging Unit
4 Change PWB-M
5 Change PWB-MFP
Jan 24, 2017 | Konica Minolta Office Equipment & Supplies
How to solve error C-2552 in Konica bizhub c253
Lets start with the code description.
Abnormally high toner density detected cyan TCR sensor
• TC ratio in the developing machine, which is determined by Toner replenishing amount control mechanism, is 11 % or more for a given number of times consecutively.
There are a couple of things I would try before replacing the Cyan Imaging Unit. Try taking out both the imaging unity and the toner and re-installing them. Restart the machine and see if the error goes away. It may be necessary to replace the imaging unit if the error persists. If replacing the unit is required and doesn't solve the problem, it could be that you need to replace the pcb (printed circuit board) and you probably need to call a qualified service tech out to take care of this for you.
Let us know how this works out for you and keep us updated on your results.
Feb 19, 2015 | Konica Office Equipment & Supplies
What s error code c-2554 of konica minolta bizhub c253?
C 2554 Abnormally high toner density detected Magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit if dirty,reinstall imaging unit or change imaging unit.
Aug 06, 2013 | Konica Minolta Bizhub C253 Copier
Error c2556 in konica minolta bizhub c 200
C - 2556 Abnormally high toner density detected yellow TCR sensor.
Clean the TCR sensor window on the underside of the yellow imaging unit if dirty.Reinstall imaging unit or change imaging unit.
Apr 01, 2013 | Office Equipment & Supplies
Error 2554
C - 2554 Abnormally high toner density detected magenta TCR sensor.
Clean the TCR sensor window on the underside of the imaging unit,reinstall imaging unit if neccessary change the imaging unit.
Feb 28, 2013 | Konica Minolta 2 Pack Bizhub C-250 C-250p...
Error code 2557
C-2557 Abnormally low toner density detected black TCR sensor.The TC ratio in the developing machine wich is determined by toner replenishing amount control mechanism is 5% or less for a given number of times consecutively.
Relevant electrical parts:imaging unit K,toner supply motor C/K ,mechanical control board or MFP control board.
Perform image troubleshooting procedure if image density is low.
Clean the TCR sensor window on the underside of the imaging unit if dirty.
Check the toner supply motor operation.
Remove and reinstall imaging unit K. or change the imaging unit.
Last solution turn ON the copier open the front door ,enter in service mode,select sistem1 or 2 ,select IuU Unit,select Unit K ,select new release press start and after job is completed close the front door,turn OFF the power,wait 2 minutes and turn ON.
Feb 11, 2013 | Konica Minolta Bizhub C220 Color Copier
What is c2559
C2559: Cyan TCR Sensor adjustment failure
or
Change Imaging Unit
Jan 20, 2013 | Konica Minolta 2 Pack Bizhub C-250 C-250p...
Sep 12, 2009 | Konica Minolta Office Equipment & Supplies
C2557 error message
If is a BW 350 go to service mode ( stop 0 0 stop 01) counter apecial part counter reset drum and dev switc off the very quiqly service mode function run f8. Did you replaced drum and developer?
Aug 11, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
Biz Hub C250 - code error C2551
Ahhh, you must be the same Macdaniel I emailed for clarification a short while ago.
C2551 relates to the Cyan imaging unit, the machine thinks the toner level inside the Cyan imaging unit is low.
Opening and shutting the main front door is the reset procedure. However if this doesn't work you should try the following
Remove the Cyan imaging unit, give it a bit of a shake and then refit.
Experience tells me that the above only works on occasion and you will probably require a new imaging unit. They are available for around £250.
Please be aware that the fault could also be down to a circuit board being defective, but this is less common.
Regards
Taminol
May 22, 2009 | Konica Minolta bizhub C250 All-In-One...
Konica Minolta 2 Pack Bizhub C-250 C-250p C-252 Tn-210m Magenta Toner Logo
60 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
