Question about Baumatic BWE40 Wine Cooler
The cooler makes a constant humming noise. It just starys at 18 degrees. It is off at present. Thank you.
The wine cooler was taken off the extension lead and plugged in to the mains. The humming noise is constant and the machine is noisy. It just stays at a constant 18 Degrees Thank you. fawzia.mallal@gmail.com
2 Suggested Answers
  • 2427 Answers
SOURCE: Baumatic BW18 wine cooler; at
the soft humming your hearing could possibly be the compressor stalling.. this can come from a lack or freon. Now this is the first thing you should check as its one of the most common issues in all refrigerant systems.. to do this there is a check port that you connect a guage too and it will give the freon pressure. More than likely you will find it very low and needs re gassing.. before having it regassed I'd suggest that you have it checked for leaks as well ,, (it ran out of freon rather quickly no ??) have a technician come in and check these as he will have all the right tools and stuff needed for for the checking of gas pressure, the dye to check for leaks as well as the freon to regas it.. and if needed the solder to fix any leaks..
Posted on Sep 17, 2010
Whirlpool 22" wine refrigerator wwc287bls. Makes a high pitched sound pretty much constantly (compressor seems to run constantly too)
Howard, We're sorry to hear about your Wine Cooler making a high pitched noise. Our Wine Coolers are handled by a different department. Please call 800-263-2629 for assistance.
Jun 13, 2017 | Whirlpool Refrigerators
Just plugged in my new 12 bottle Danby wine cooler and it hums, LOUDLY. Any idea why?
it might , it has a compressor and that would make more noise under a strain . refrigeration units strain when the box is warm. let it run and bring down the temp of the box and then see how much noise it is making . 12 hours should do it.
Jan 30, 2016 | Danby DWC1233BL-SC 12 Bottle Wine Cooler
I have a Haier BC112G. It is not cooling at all. Temp panel works, so I can set the thermostat up or down, but nothing happens and it just goes back to room temp after that.
Our magic chef wine cooler (mcwc50dbt) when temp is set on digital panel at 45-50 it jumps immediately back to 70 degrees constantly
Sep 25, 2013 | Haier BC112G Wine Cooler
Aficionado hvt18dfbb is running but NO TEMP CHANGE
There is no compressor on these units. These units use a Peltier cold/hot module where the cold side faces the heat sink and the fan exhausts the heat side. Another fan sends the cool side into the frig. I have the same unit, I am experiencing the same issue. I was looking to change out the Peltier modules (about $7 each) and try that. I did find a replacement Control Board is about $45 and if the Peltier change doesn't work this may be my next step.
Nov 08, 2012 | Haier HVA052ALL-8S 52 Bottle Aficionado...
Wine cooler doesn't cool
I recommend that you maybe add more details to your question so it will be easier for Experts to understand the question and answer it.
Oct 06, 2012 | Kalorik WCL-20629 18 Bottle Dual Zone Wine...
COOLER IS GETTING POER BUT NOT COOLING. TEMPERATURE CONSTANTLY SHOWING 72 DEGREES.PLEASE SUGGEST TROUBLE SHOOTING. #K0700305460011335 MODEL: OW0912H6H
Check the lint trap behind your cooler to make sure it isn't clogged... I had the same problem and after vaccuming the lint trap, my cooler started cooling again
Feb 06, 2010 | Oster 12-Bottle Wine Cellar - Black
Noisey, loud shrill
If you just got the unit you should contact your dealer for warranty service. The only noise you should hear is a slight hum of the compressor and the soft blowing noise of the condenser fan. It sounds as if the evaporator fan on this unit is toast. That is also why is it having a hard time maintaining temperature. The temperature indicated is actual air temperature sensed so it will go up and down a couple of degrees above and below setpoint but when operating correctly the product temperature will be very stable.
If the servicer does not fully understand the new digital system, make sure he/she contacts the factory technical assistance rep. at 800-428-6644.
Jul 16, 2009 | Marvel (6SBARBSG) Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Cuisinart Private Reserve wine cellar
It is normal. The goofy thing about this wine cellar is that once the ambient temperature is above 70 degrees - which is actually a low room temperature - the fan works constantly. You would have to make sure the wine cellar is in an area that stays below 68 degrees (brrrr) for it to shut off sometimes.
-Tha Mp3 Doctor
Sep 13, 2008 | Cuisinart ICE-30BC 2 Quart Ice Cream Maker
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Baumatic BWE40 Wine Cooler Logo
Top Baumatic Refrigerators Experts
Sal DeAngelo
Colin Stickland
Colin Stickland
Electric Dime
Electric Dime
Are you a Baumatic Refrigerator Expert? Answer questions, earn points and help others
