Question about GE PT916 Electric Single Oven
Light bulb burning out GE PT916 Electric Single Oven
Light bulb burning out frequently
aborcass
  • 2651 Answers
SOURCE: F3 Error Code - GE Electric Oven JTP18
all ge codes f3 are saying ot replace thermal sensor, you can check the harness connecting them for a pinched or burnt wire i guess, as far as getting a part number , you can enter complete modle number her e and look for the sensor, i checked just the partial number you gave and a few different ones showed up
http://www.searspartsdirect.com/partsdirect/index.action
Posted on Apr 23, 2008
SOURCE: GE OVEN SINGLE ELECTRIC JKS05BW
I have the same problem. Mine is a self-cleaning oven. But I'm just preheating it 450 and it did it. Then this AM it did it while broiling.
Posted on Aug 24, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile Convention Light Bulb Not Working after Replacement
With a volt meter you must verify power to the door light switch and the light socket.
You can also unplug the oven and do this with a meter set for continuity.
Posted on Feb 21, 2009
  • 360 Answers
SOURCE: GE Profile convection with light bulb burning out
Multiple possibilities.
  • Being used as a night lite. (continuous use)
  • Not using a light bulb designed for use in a oven.
  • Inexpensive bulb. (very low lamp hour rating).
  • Oven door slamming.
  • Over voltage condition.
  • (My favorite) Light bulb swapping Gnomes.
Please take the time to give this solution a fix ya rating.
clarkco
Posted on Feb 22, 2009
  • 108 Answers
SOURCE: ge oven turns off by itself, and sometimes gives
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor F2
Note: Also see fan thermal switches Indicates that oven is over temperature in one of the following modes within either a cooking or clean mode of operation.
· Control senses oven temperature above 650 degrees F with the door circuit in the unlock mode.
· Control senses oven temperature above 935 degrees F with the door in the locked mode.
· Stalled cooling fan or airflow problem. · Look for welded relay contacts. (Heating elements on in off mode).
· Look for open thermal switch in lock motor circuit. Switch is normally closed and will open if area overheats due to fan not operating. Look for cause - fan thermal switch not closing, fan stalled, etc.
· Look for high resistance in the oven temperature sensor circuit due to high contact resistance (poor terminal crimp, deformed terminals, loose connection) or intermittent solder joint on control or intermittent oven temperature sensor.
· Look for electrical noise interference in the oven temperature sensor circuit (Ham radio, cordless phone, etc.).
Posted on Nov 11, 2009
Over the Range Light Stopped Working
It is a good chance that the bulb (s) have burned out. I would think they would last longer than that but things are not as good as they used to be. Unplug the microwave before removing the bulbs. Especially if they are the screw in type. GE usually has two bulbs in there and they could be the halogen type that just plug in or the screw in type.
Mar 28, 2014 | GE Profile JTP18 Electric Single Oven
Problem with light
Repair the bulb holder and refit the bulb with cover.
Aug 29, 2017 | Maytag 30" Built-In Single Electric Wall...
Hi, I have a GE Profile oven that needs a light bulb replacement. It is NOT a standard 40W appliance bulb as stated. What bulb is it?
What is the model number for your oven reply with it and i will give you the GE part number for that light bulb
Sep 17, 2011 | GE Profile JTP18 Electric Single Oven
What type of light bulb to use in oven?
According to the parts breakdown it uses a standard 40 watt appliance bulb,it say for the part# to buy locally so its a standard bulb since ge never even issued a specific part# for it
Aug 01, 2011 | GE Profile JTP18 Electric Single Oven
clarkco
Feb 22, 2009 | GE Profile JTP18 Electric Single Oven
Feb 17, 2009 | GE Profile JTP18 Electric Single Oven
Installing a new lightbulb
it screws off, make sure you replace it with an appliance bulb.
Feb 20, 2008 | GE JKP20 Electric Single Oven
Light out
For a fluorescent bulb just get the numbers of it and the length and diameter and go to Lowes or a hardware store and pick it up.
May 08, 2007 | GE SCB1001KSS Stainless Steel Electric...
GE PT916 Electric Single Oven Logo
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
