Question about Maytag MSD2756G Side by Side Refrigerator
Water in the bottom of MSD2754GRW
Our Maytag side by side has started having the water in the bottom of the freezer. Have not found the cause as yet, but from what I have found online, I'm guessing it has to do the the defrost line. There is also an issue with the cube ice not coming out, only crushed ice. I wonder if shutting it off for couple days will to clear frozen lines.
The problem was the defrost drain funnel was full and frozen. The issue of only getting crushed ice is still an issue. I need to investigate this more.
Posted on Jun 20, 2009
Side by Side Maytag SS-2, water is leaking into bottom of freezer side and freezing, eventually leaking out.
defrost the freezer and remove the ice . then with hot water & a turkey baster force water through the drain in the back // when clear the problem is over .. this is caused by algi build up in the bott om of drain line .. mm
Jul 10, 2011 | Maytag Refrigerators
Water on freezer bottom. I have a Maytag refrigerator, side by side, Model MZD2768GEW, seven years old. Recently I have found about 1/3 cup of frozen water on the freezer bottom. It is not comming from...
Here is a tip that will tell you where the water is coming from and how to fix it. The drain hole has froze shut and the water from the defrost will not drain out.
Water Running in Refrigerator from Freezer
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Aug 18, 2010 | Maytag Freezers
Water in the bottom of MSD2754GRW on the freezer side
Tinkertatt,,
I just found a puddle of ice on the bottom of my freezer. After researching on this site I determined the drain plug was stopped up. I UNPLUGGED freezer. I removed selves and mounting brackets. I then remover the metal condenser cover in the back. There was quite a layer of ice on the bottom and the hole was indeed stopped up. After some cleaning and thawing I put it back together and am hopeful that the problem is resolved. Not really an easy job and there are lots of sharp edges and very limited space to work. There are other more in-depth direction on this site if you look around. Good Luck
Sep 15, 2009 | Maytag MSD2756G Side by Side Refrigerator
Freezer malfunction
Drain hole is clogged behind the panel that covers the coils. I found a peice of solder blocking mine. Water was freezing on the bottom of the freezer and leaking out to the floor.
Aug 04, 2009 | Maytag MSD2756G Side by Side Refrigerator
Bottom of freezer has water dripping into it
A bad freezer door seal causes condensation that freezes at the bottom of the unit. I realize you said the drip pan was full of ice, but if the drain is clogged, that will happen. If that unit has the pan at the very bottom, condensation can also contribute to this.
Jun 17, 2008 | Maytag 25.6 cu. ft. Wide-By-Side...
Water in freezer
The defrost drain is frozen. It is located at the back bottom of the freezer. Use a hair dryer to thaw it out and when thawed run hot water through it to check. Afterward, spray some "Pam Cooking Spray" into the drain so the water won't stick. This can be caused by the controls being set too cold or something in the drain line.
Jan 19, 2008 | Maytag MSD2454G Side by Side Refrigerator
Defrost Problem
there is a drain in the middle of the defrost water collector and it is probably blocked - usually with ice. dry ot the tray and put very hot water in to melt the ice. you may have to do several times. do this until water flows away freely
Jul 25, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2756G Side by Side Refrigerator Logo
228 people viewed this question
Top Maytag Refrigerators Experts
Marvin
Marvin
John Tripp
John Tripp
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
