Question about Ramsond 12,500 BTU 1 Ton Ductless Mini Split Air Conditioner & Heat
Leaking water from the inside unit - Ramsond 12,500 BTU 1 Ton Ductless Mini Split Air Conditioner & Heat
    Problem Solver:
  • 8 Answers
When the air gets cooled it also gets dehumidified, on the inside unit there should be a condensate drain. Check the drain to see if its clogged, also check to see there is a drain, I have seen units installed by "pros" who have forgot to intall it
Posted on Apr 15, 2014
My AC unit leaks water inside
Isidro, If it's a window unit you will need to tilt it up from the inside. Thank you and please leave me feedback. Clean around the bottom of any debris so it can drain on the outside.
Jul 12, 2016 | Panasonic Heating & Cooling
How do I fix leaking dehumidifier?
units that leak some times are a total loss but not allways , sometimes its just not being used on level surface (water seeks level allways) , there are lots of ports inside that need to be kept clean for all the units water to drain out , look inside with a flashlight to see if any buildup is obvious that might be cleaned off ? if not a last effort is to remove cover to see 1st hand what cause is(remove power plug 1st) , rust /mold/dust are all common things to find inside that affect units operation
Jun 29, 2014 | Kenmore 50 pint Dehumidifier w/Electronic...
Why is my keurig 560 leaking water from the base
Most likely the water lines inside your unit are leaking. If you can take the bottom of B60 off and look inside the unit. Usually, the line that comes off the water pump is leaking at the T connector. If not leaking there look for other signs of leaking while the bottom is off. You can call Keurig 800 number to see if your unit is still under warrenty. Hope this helps.
May 28, 2014 | Keurig B60 Coffee Maker
Kenmore elite 596.735 .water leaking from rear of water filter unit.
What is the complete model number of your unit? Look inside the refrigerator section.
Oct 21, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Leaking from inside unit
What is leaking? If it is water, you need to find the drain pipe leading from the inside unit to the outside of the house, and open up the obstruction in it. You could push a wire up through it, or send some compressed air up it. The drain pipe is probably near the ground next to the foundation or in the ceiling of an outside porch.
If this is a window unit leaking water you need to clean the obstruction out of the drain pipe or hole on the outside of the window, probably at the bottom outside rear of the unit.
I wasn't sure from your question if it is leaking water, or leaking refrigerant gas. If it's the gas you probably need to call an A/C repair service.
good luck,
genetuck
Jan 15, 2011 | Carrier Heating & Cooling
Water leaks from the roof unit
This is condensate (which of course is water) that is coming from your unit. This is very normal ... Is it leaking inside or running across the roof and down the side of your unit? If it is going inside, there is a drain in your roof unit that is clogged. You must clear the clog. Remove the cover and inspect the base. Turn the unit off first.
Sep 19, 2010 | Dometic Rooftop RV Air Conditioner
WATER LEAKING
Water should come out of the back of a wind unit when it is humid out, usually a drain hole. If water is leaking inside from a window unit, check that the outside drail hole is not clogged or maybe it is not tilted downward enough outside (Usually a very slight tilt down toward the outside to help the water drasin out the back outside). Also, if you have excess water forming, you may need to clean the coil. For central air units water should be drippng outside the home via a pipe or tubing and if the drain tube or pipe is clogged with scum that forms inside the pipe water will back up and overflow in the house near the heater/air conditioning unit. Also, some units have a pump to pump the water out and it may not be working.
Aug 07, 2010 | Heating & Cooling
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Water leaking inside freezer and refrigerator.
you have a clogged drain tube in the freezer compartment. it is frozen with ice and as the unit goes in to a defrost cycle the water has no place to go. you can fix it the easy way, just unplug the unit and let it defrost. this will take care of your issue.
Oct 19, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
Ramsond 12,500 BTU 1 Ton Ductless Mini Split Air Conditioner & Heat Logo
100 people viewed this question
Top Ramsond Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
Are you a Ramsond Heating and Cooling Expert? Answer questions, earn points and help others
