Question about HP Designjet 5500 (42 in.) InkJet Printer
Designjet 5500 Main board faults
Hello I'm trying to repair some designjet formatter boards with various faults on, does anyone know any links to a site that has the board faults down to component level, or any information on circuit diagrams etc. Thanks
    Habit-Forming:
  • 53 Answers
If you want component level repairing...
just send mail to me which for matter board repair you want???
Posted on Jun 25, 2014
5 Suggested Answers
SOURCE: hp designjet 100plus
paste this address in your browser, you should get some help there.
http://welcome.hp.com/country/us/en/support.html?pageDisplay=support
Posted on Jul 17, 2008
dirinda89
  • 214 Answers
SOURCE: repair manual for designjet 820
Try this link. I clicked the download now button & it's active.
http://www.eserviceinfo.com/downloadsm/17339/HP_DesignJets%20500.html
If this helps you plz rate this for me. Thank you kindly.
Posted on Feb 10, 2009
  • 313 Answers
SOURCE: DesignJet 5500, cannot get it calibrated
lubricate the rod using WD-40 and syrine, and recalibrate
Posted on Apr 08, 2010
apkb29
  • 174 Answers
SOURCE: how can i install hp designjet 5500 PS on my com
You are doing some mistake.
All peripherals will attach directly to the main server or main system.
Then from the main system you attach the network switch and share the peripherals with other
system.
you connect the printer, plotter, scanner etc to your computer directly through the aproprite cable /
port.
Posted on Apr 15, 2011
0B0007
The error code means the vacuum fan is not detected.
Replace the vacuum fan. If that does not fix the problem, replace the Main Logic board. The fan can be ordered from: Designjet 5000 5500 Vacuum Fan and the PCA from: HP Designjet 5000 5500 parts
Jun 26, 2014 | HP DesignJet 1050c plus InkJet Printer
02.1.10 error plotter t610 and solution
The error code 02.1:10 means the plotter has a communications problem between the main logic board and the carriage PCA. The possible parts at fault are: The Carriage PCA, Trailing Cable, or the Main Logic Board, all available here: Designjet T610 Parts
You can watch this video to see how to remove the covers Designjet T610 Belt Replacement How To Video
The service manual is here: Designjet T1100-T610 service_manual
Sep 18, 2013 | HP Designjet T610 InkJet Printer
08:11 error in hp designjet t1100
It is either the formatter card...the connection to that card with the main PCA. or the main PCA. the formatter card is the part that you plug the ethernet or usb cable into. the main pca is the part that it plugs into. Both are pretty expensive.
Jul 27, 2011 | HP Designjet T1100ps Printer
Hp designjet 5500 power supply error 1
Possible that the main capacitor has leaked and so there is drop in the +B or the sub voltages. It is important to check the rail votages to the main board , remove SMPS unit an check.
see link below for tips on SMPS power supply
http://www.fixya.com/support/r5826301-working_switch_mode_power_supplies
May 12, 2011 | HP DesignJet 5500PS InkJet Printer
How can i install hp designjet 5500 PS on my com puter using network cable? My plotter (hp designjet 5500) do not have USB port instead it has netwok port from which one can install via the local network...
system.
port.
Apr 15, 2011 | HP DesignJet 5500PS InkJet Printer
Error 08:11
There is no communication between the Front Panel and the Main PCA.
You are going to need a qualified DesignJet tech to check out the cables
to the Front Panel and the Main PCA and to the formatter.
You could possibly need a formatter, Main PCA, Starwheel assemby, or a front panel.
Apr 10, 2011 | HP Designjet T1100ps Printer
HPdesignjet T610 error code 08:11
The 8 code is a formatter or front panel problem. Try reseating the formatter and its cables. Also reseat the front panel cable.
Basically it means that there is no communication between the front panel and the Main board. Turn the printer off and unplug it from the wall. Reconnect the cord and power up. If it still fails, the formatter or the main board or the front panel will have to be replaced. Get a tech to check it out.
Oct 31, 2010 | HP Designjet T610 InkJet Printer
My Hp Designjet T1120 fails to initialize. When mains is switched ON the Front Display Panel in the plooter illuminate without any display and the Power switch in the display panel flickers with green...
Reset the formatter & check,,
Hard disc & main PCA any one of them faulty.. Through light pattern we can estimate which part is faulty...Read carefully, understand the indications..
Led pattern: Power supply LED as 1
Formatter leds 3nos from left to right as 2,3 & 4..
* indicates "on"
# indicates "off"
& indicates "flashing"
* # # # ....Main PCA
* * # # ....Formatter
* $ # # ....Hard disc
* * * $ .....Main PCA or Formatter
Note down which LED are on.off & flashing,compare with above said indications find out the faulty part.. 11_19_2011_3_40_14_pm.jpg
Oct 11, 2010 | HP DESIGNJET T1120 44 Printer
My HP designjet 1055 cm plus keeps giving a system error of: 0000D8 005D0273. How do I fix this?
This could be one of two things. It's either a firmware fault or a problem with the JetDirect card in the back of the printer. First of all, power the unit off, remove the Jetdirect network card then power it on again. If the error is no longer present i would recommend replacing the jetdirect network card. If it's a 615 jetdirect then this could very well be the fault because they are very prone to causing spurious errors on various printers.If it still fails then it is more than likely to be the Firmware simm on the main control board.
Jan 25, 2010 | HP DesignJet 1050c plus InkJet Printer
Repair manual for designjet 820
GO ON LINE AND DO THE FOLLOWING TYPE
HP DESIGNJET 820 PRINTER SERVICE MANAUL DRIVERS
ENTER
WWW.HP.COM/DESIGNJET
ENTER
ROD
Feb 10, 2009 | HP Designjet 820 Printer
HP Designjet 5500 (42 in.) InkJet Printer Logo
62 people viewed this question
Seeker5211
Seeker5211
