Question about Swintec 2640 Electronic Typewriter
Turn on and it has a continuous beep - Swintec 2640 Electronic Typewriter
  • 24 Answers
Most typewriters have a "power on system test" or POST routine. Beeping means that it fails the test. With the power off, try moving the carriage all the way to the left and turn it on. Some typewriters, if the carriage is not right over the left sensor, will fail the POST. Most typewriters will check things like, "Is there a ribbon installed?" "Does the Daisy Wheel home?" and will move the carriage left to right to make sure that the sensors recognize the left and right limits. There are other checks of course, but those are the ones that are easily fixable.
Posted on Apr 23, 2014
Acer Aspire 7720 beeps after awhile
If it continuously beeps after every while, must be you have some alert on software running on background, check , could be temp alert, or if you have any antivirus software, it also leads to beeping whenever it finds a virus(sometimes). Hope this helps.
Dec 15, 2013 | Acer Aspire 7720 Notebook
When i turn on my lenovo g585 lap it start with one beep and comes the display and go boot with continuous beep sound and stuck the lap
Hi...
Gives continuous beep sound , When my laptop switch on (Lenovo G585). No display but leds (power & battery) were blinking.
Sep 10, 2013 | Lenovo G585 Laptop
T6520 emachine won't turn on, lights and fan work. Beep code
Hi, you are having a problem with your add on cards, try to pull out everything that you have add on to you PC, then try to put 1 by 1 and try to turn on. If it beep once its OK, but if it's continue then the add on cards are the defective.
Oct 08, 2012 | E-Machines eMachines Desktop PC
Gateway laptop wont turn on just beeps continue
How Many Beeps you hear ?
1 Beep Continues > Problem in RAM
2 Beep Continues > Problem in RAM or Mother Board
3 Beep Continues > Problem in Base of RAM is Not Same
4 Beep Continues > Problem in Time System
etc.
i Recomended to you to see at zylone81.indonesianforum.net/forum/ for to know Computer and laptop Problem from Beep sound.
Jan 06, 2012 | Gateway NV5929u PC Notebook
When I turn on my pc monitor goes blank and computer starts beeping. As long as it's turn on it continue to beep. These are short often beeps
the beeps indicate a cpu or memory error. it would help to know what mb you have and if you replaced anything recently
Jan 29, 2011 | Computers & Internet
My computer cannot boot because of long beep
beep code usually means a basic function was unable to start. A basic function might be reading memory, displaying video, or being able to send information to a hard drive. The most common problems that cause beep codes are memory and heat-related failures caused by a build-up of dust in critical cooling areas. Use the beep code tables in this document to help find what hardware component is causing the problem. This might reduce the time required to find the hardware component that needs adjusted, reseated, or replaced. WARNING: HP recommends that these steps be performed only by someone with experience in working on computer hardware. Incorrectly handling sensitive internal components can further damage the computer and can introduce the risk of personal injury. Using the correct environment for working on computers (ESD precautions and tools), use the following steps to isolate and fix the problem:
  1. Turn on the computer.
  2. Listen to the beep code and write it down. Write down the number of beeps before each pause, if the beeps are long, short, high in tone, or low in tone. You can use the other sections in this document to look up the beep code description. The beep code and its description can be used for further Internet research if needed.
  3. Note which fans are spinning, not spinning, or making strange noises. It might be possible to prevent the beep code by setting the fan speed to a higher setting in the BIOS setup utility or by cleaning the cooling fins and vents.
  5. Check the case fan and power cable.
    1. Turn off the computer by holding the power button for five seconds.
    2. Disconnect the power cord and then disconnect all external cords from the computer.
    3. Remove the side panel to open the computer.
    4. If the case fan was not spinning, make sure the case fan power cable is connected to the correct pins on the motherboard. Replace the fan if it was making excessive noise or was not spinning. If you had to plug in or replace the fan, replace the side panel, plug in the power cord and turn on the computer. If the beeps continue, continue to the next step.
  6. Disconnect the power cord and remove the side panel and perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
    1. Clean cooling components that have become clogged with dust. If beeping continues, continue to the next step.
    2. Remove a memory module. If the computer stops beeping, the memory module might be bad, is the wrong type of memory for the motherboard, or was not fully seated or connected. Reinsert the memory into the socket to see if a connection was the problem; otherwise replace the module. Remove each memory module, replacing the one that was previously removed. If beeping continues after checking all the memory modules, continue to the next step.
    3. If the computer has a graphics adapter, remove it. If the beep code changes or continues with the same beep pattern after removing the graphics adapter, the adapter might still be good. Reseat the graphics adapter into its socket and continue to the next step. If the beep code goes away, the graphics adapter might be bad. Try reseating the graphics adapter, making sure it is fully locked into the connector on the motherboard. If problems continue, replace the adapter.
    4. Remove a PCI card. If the beep code goes away, the card might be bad. Try reseating the card into its connector on the motherboard. If problems continue, replace the card. Remove each PCI card, replacing the one that was previously removed. After checking all cards, if beeping continues, continue to the next step.
    5. Disconnect hard drives and CD or DVD drive cables (IDE and ATA) from the motherboard socket. If the beep code goes away, the cable or socket is probably bad. Look for bent pins inside the IDE socket on the motherboard and straighten any bent pins. Try reseating the cables into the connectors. If problems continue, the drive itself might be bad and might need replacing. Disconnect each drive cable, replacing the one that was previously disconnected, until all have been checked. After checking all connections, if beeping continues, continue to the next step.
    6. At this point, the problem is probably the motherboard or processor. Make sure any jumpers on the motherboard have not fallen off their pins and into the case. Make sure jumpers are set correctly. Otherwise, have the computer serviced by HP or by a qualified service center.
Jul 15, 2010 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
3 beeps
Please Try this :-
:- Perform each of the following tasks, in order, until the beeping stops. Before starting each task, unplug the power cord and remove the side panel. After completing a task, replace the side panel, connect the power cord, turn on the computer, and ()listen for a beep code. NOTE: If removing or disconnecting a hardware component prevents the beep code, that component is probably causing the problem. However, a failed motherboard might produce beep codes associated with a component other than the motherboard.
Remove a PCI card.
May 12, 2009 | Intel Motherboard
HP P4B-MX beep
HP P4B-MX is Award Bios
Award and Phoenix BIOS:
1 short beep: Normal
2 short beeps: CMOS error
1 long and 1 short beep: DRAM error
1 long and 2 short beeps: Video card error
1 long and 3 short beeps: Keyboard error, or video card error
1 long and 9 short beeps: ROM error
Long continuous beeps: DRAM not installed correctly, bad memory, or incompatable
Short continuous beeps: Bad power supply
Jan 19, 2009 | HP (5185-6477) Motherboard
6 Beeps, 5 short beeps and 1 long beep
try to change ur RAM..if not worked then there might be some problem with ur graphics card..
Dec 11, 2008 | NEC Versa FX Notebook
Swintec 2640 Electronic Typewriter Logo
130 people viewed this question
Top Swintec Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Anthony Karuku
Are you a Swintec Office Equipment and Supply Expert? Answer questions, earn points and help others
