Question about Cosco Juvenile Cosco Funsport Playard
THE LEG AND COTTER PIN CAME APART FROM THE CENTER SPROCKET
THE PIN HOLDING THE LEG INTO THE CENTER SPROCKET CAME OUT. HOW DO I GET IT BACK TOGETHER?
  • paul182 Apr 15, 2014
    i FIXED THIS MYSELF. i HAD TO HOT GLUE THE PINS INTO THE TUBES, AND UNSCREW THE BOTTOM PLATE, THEN TURN THE TUBES 90 DEGREES PUSH DOWN INTO THE SLOT AND ROTATE BACK 90 DEGREES. NOT EASY BUT IT WORKS. THEN SCREW THE PLATE BACK ON.
  • RJ Hall Jun 20, 2015
    @Paul182: Brilliant! THANK YOU!!
From Paul182 himself: I FIXED THIS MYSELF. i HAD TO HOT GLUE THE PINS INTO THE TUBES, AND UNSCREW THE BOTTOM PLATE, THEN TURN THE TUBES 90 DEGREES PUSH DOWN INTO THE SLOT AND ROTATE BACK 90 DEGREES. NOT EASY BUT IT WORKS. THEN SCREW THE PLATE BACK ON.
Posted on Jun 20, 2015
Pel job 250 track removal procedure
First step is to remove any tension in the track by loosening off any adjuster rollers or springs.
the normal method to remove tracks on a machine is to remove a pin about the middle of a front sprocket in the track and then back the machine along the track until the undone part falls to the ground
jack the machine off the track and work on the sprocket. Replacement is to tie the end of the track back onto the drive sprocket and drive forward until the track is on top of the sprocket. undo the tie and retie it to the front sprocket and continue to slowly drive forward. eventually the ends of the track will be almost together. One end will be on the ground and the other end will be just above it . Use some method of holding the two ends together so that the pin can be reinserted.
If it is a small machine and runner tracks you may be able to undo a pin in the middle at that top and just lay the ends back wards and forwards. fix the sprocket and then pick the ends up and rejoin.
Feb 20, 2015 | Cars & Trucks
Cotter pin removal
That is called a C clip. use a small flat blade screw driver to back it off the shaft in one of the dimples on either side of the center.
May 08, 2013 | Garden
Are motorcyles usually this cantankerous? Now the chain came off. I put it back on, but need to know how to take out the slack so it can be driven safely to town (30 miles) to get a new rear tire.
Loosen the bolt on the rear axle after removing the cotter pin holding the bolt in place. Adjust the chain tension by rotating the adjuster cams on the left and right side of the wheel. See diagram below. Set the two adjusters evenly to keep the wheel inline on the swingarm. Retighten the axle nut and put the cotter pin back in place. Have the parts department look at the rear sprocket. Chances are the sprocket is worn out also. If it is, the front sprocket will be worn out also. Worn out sprockets will cause your new chain to wear out quickly. Please rate my answer. Thanks.
Aug 15, 2010 | 2004 Suzuki DR 200 SE
Cant get the rotor off of a 99 , any suggestions
Remove the brake caliper, and caliper holder if it goes over the rotor. If it's 2 wheel drive, remove the center cap, take out the cotter pin. Remove the nut holding on the rotor. If it's 4 wheel drive, once you remove the associated brake parts, spray some WD-40 around the studs and the center of the rotor, try striking the rotor with a rubber hammer. Often the rotor will rust to the hub, on the 4 wheel drives. The 2 wheel drives, have the rotor with the hub for the bearings together, the 4 wheel drive has a "top hat" type rotor.
Mar 10, 2010 | 1999 Dodge Ram
Mf 135 leaking transmission fluid through cotter pin at bottom of transmission.
I have the same cotter pin in a hole under my 130 - I've got blow apart pics for the whole thing and they show the cotter pin just sitting there not holding anything in so I just assumed it was there for the purpose of letting oil out!!
Oct 05, 2009 | Puzzle Massey Ferguson Tractor
How to remove links from band
This band is put together with cotter pins. To remove the cotter pins look at the edge of the band. The end of the pin that comes out is split and looks like a screw. The end that is solid is the end you want to push from. Use a small punch to push the pin out. The split end is the bigger end of the cotter pin so it needs to come out and go back in the same way it came out. Make sure you remove an even number of links on each side so the watch sits on the wrist the right way. You also have a micro adjustment on the clasp. To adjust the clasp simply use a punch to press the spring bar in the clasp in until it moves. This is a spring bar so be careful it doesnt jump out if the clasp comes apart.
Sep 22, 2009 | Festina 16177-4 watch Watch for Men
I need to adjust a Casio AMW320rd-1A9 STAINLESS WATCH BAND. ADVISE PLEASE
Sep 19, 2009 | Watches
Need pitman arm replaced and idler arm replaced
The idler isn't bad, Remove cotter pin going through the nut, take off nut, you need a seperator tool to pull apart the arm from the center link, once that is done, remove the two bolts holding it to the frame, remove arm, installation is just reverse.
The pitman arm is a little more to it. Do the same, remove cotter pin, take off nut, and seperate it from the rod, now there is big nut holding it on to the bottom of the steering box, take that nut off (some are a real pain), you will need a pitman arm puller to get it off. Note the position of the arm, need to put new one in same place, pull it off slow, sometimes seals will come with it, put seals back in same way, if they come out. Put some grease on splined shaft, tap new arm on until you can get nut on, tighten up with nut. Hopefully you have any problems. Good luck.
Mar 24, 2009 | 1997 GMC Jimmy
We just bought amana washer pulled the yellow shipping cord with one long cotter pin,,,,,,,,,filled washer and it will not spin has humming noise like something is holding it where is the location of other...
There should be 4 - 1 near each leg.... all with yellow tags. Don't discard the pins - as the unit should be re-secured if moved in the future.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Feb 01, 2009 | Washing Machines
Cotter pins to hold rear wheels in place--Emergency !!
you shouldn't have to pry them apart most cotter keys should drive staight in
Aug 21, 2007 | Cosco Deluxe Comfort Ride 01-834 Stroller
Cosco Juvenile Cosco Funsport Playard Logo
583 people viewed this question
Top Cosco Juvenile Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Cosco Juvenile Baby Gear Expert? Answer questions, earn points and help others
