Standard duplicator Error sc05-22 What kind of problem?
Error E 01
The complete error codes for RZ220 Duplicator can be found at.
http://mfpdoc.com/?mod=free&chap=erc&brand=Riso&model=RZ220
Jun 13, 2014 | Riso RZ220 Duplicator
Kindly give the product key of microsoft office standard 2007, full version
Dear Sir, this site is only to provide you support for fixing the problem. You should buy original product from microsoft.Duplicating the product is illegal
Jun 30, 2010 | Computers & Internet
When i push copy on my DVD burner it says,Target Overflow,what do that means becouse it wont let me burn nothing its a[ TEAC 1 1 DVD/CD duplicator]
It happens to me also ALL the time with mine. I have a 7 disc duplicator machine I do for weddings and special events. And it's a real pain and costly to have that come up when you need the project done soon. My solution is to change the brand on the master disc. Burn another copy of the master disc on your computer to another brand and then use that brand as the new "master" in the duplicator. (1 sollution)
"Target Overflow" basically means that either sometimes the master disc has too much information on it to burn than the disc you want to copy can hold, or sometimes a CD may be in by mistake instead of DVD. If you have a Dual layer DVD disc you want to make copies of and you only have the basic 4.7GB standard DVD blank disc..it's not enough storage space on the disc to burn so you will see that error also. It should really say "not enough space to burn) lol..but I guess that's asking too much.
Sometimes all is correct with the DVD size and it'll come up for no reason (usually the master disc is still spinning and hasn't stopped but you've already pressed the "Copy" button, it's not "ready" so an error of "target overflow" will come up)
I've had mine for 6 years so I've done alot of testing and trial and error to come to the above conclusions.
I find that these brands work for the best "thorough" burns.
Recommended:
Verbatim
SONY
Ritek
Ridata
May 08, 2010 | Teac 1x1 DVD/CD Duplicator, DVW/D11A/KIT...
Mobile is getting heated when charging with a duplicate charger.? Is it the problem with the charger or mobile?
it is the problem with the charger...in duplicate chargers, ratings and standards are not followed properly for example if ur mobile battery needs some 10A and 7V(only for example)duplicate charger may give less or more the required ratings...this ll end up in heating ur mobile....
it is always recommended to use branded charger...
Apr 05, 2010 | LG KU990 Viewty
Riso 3770 error code T3
A T3 error code is indication of some kind of problem associated with the clamping mechanism. Most of the time, what happens is that there is a magnet attached to a flag on the rear side of the drum and it has fallen out of place. If you can find the magnet, reattach it with a strong adhesive.
Check for smooth operation of the clamp by hand as well and lubricate if necessary.
Mar 14, 2010 | Riso RZ310 Duplicator
Our Standard SD650 Duplicator has error code SC07-30. The paper tray is jammed in the down position. Need the reset code to clear the error
Through my own efforts & online research. Your service team never responded. I paid for live chat assistance which was not provided, and was then directed to email assistance which has been a complete joke. Please fully refund all fees charged to my credit card. I will look for other solutions to tech problems in the future.
Dec 11, 2009 | Standard Registar SD650 Color Copier
T20-414
Check the paper ejection unit that is a T20 code T02 code would be a standard tray lift issue.414 is not listed in the book for eather code
Apr 13, 2009 | Riso RZ310 Duplicator
Duplicates
what software are you using? If no then try to use excel. You can list down the # and perform a column check to the #
Aug 30, 2007 | Microsoft Office Standard for PC
Computers & Internet Logo
David Payne
David Payne
